ibnukoel
PostPosted: Nov 10, 2011 - 04:19 AM
hey guys.. i have program to use SPI to read SDCARD.. but i don't know the data is flow.. any body tell me how this data flow in SPI mode,, and where i can acces the data.
information:
i will build my mp3 player project. so the data will be used to generate the PWM to make the sound.
DO1THL
PostPosted: Nov 10, 2011 - 07:24 AM
Two options come to mind immediately:
1) ask the guy from which you got the code.
2) have a look at the data sheet to learn how SPI works.
Sorry if i failed to understand your question correctly.
PostPosted: Nov 10, 2011 - 09:28 AM
Tell us more about that. Is it the same FatFs that everyone else here uses or something else? If something else have you considered using FatFs as there's loads of people here who could help you with using it.
ibnukoel
PostPosted: Feb 05, 2012 - 12:38 PM
#include <avr/iom16.h>
#define FOSC 6400000
#define DI 6                         // Port B bit 6 (pin7): data in (data from MMC)
#define DT 5                        // Port B bit 5 (pin6): data out (data to MMC)
#define CLK 7                     // Port B bit 7 (pin8): clock
#define CS 4                        // Port B bit 4 (pin5): chip select for MMC
void ini_SPI(void) {
     DDRB &= ~(_BV(DI));                     //input
     DDRB |= _BV(CLK);                     //outputs
     DDRB |= _BV(DT);                     //outputs
     DDRB |= _BV(CS);                     //outputs
     SPCR |= _BV(SPE);                     //SPI enable
     SPCR |= _BV(MSTR);                     //Master SPI mode
     SPCR &= ~(_BV(SPR1));                    //fosc/16
     SPCR |= _BV(SPR0);                    //fosc/16
     SPSR &= ~(_BV(SPI2X));                    //speed is not doubled
     PORTB &= ~(_BV(CS));                     //Enable CS pin for the SD card
char SPI_sendchar(char chr) {
     char receivedchar = 0;
     SPDR = chr;
     while(!(SPSR & (1<<SPIF)));
     receivedchar = SPDR;
     return (receivedchar);
char Command(char cmd, uint16_t ArgH, uint16_t ArgL, char crc ) {
     SPI_sendchar(0xFF);
     SPI_sendchar(cmd);
     SPI_sendchar((uint8_t)(ArgH >> 8));
     SPI_sendchar((uint8_t)ArgH);
     SPI_sendchar((uint8_t)(ArgL >> 8));
     SPI_sendchar((uint8_t)ArgL);
     SPI_sendchar(crc);
     SPI_sendchar(0xFF);
     return SPI_sendchar(0xFF);                // Returns the last byte received
void ini_SD(void) {
     char i;
     PORTB |= _BV(CS);                    //disable CS
     for(i=0; i < 10; i++)
       SPI_sendchar(0xFF);                // Send 10 * 8 = 80 clock pulses 400 kHz
     PORTB &= ~(_BV(CS));                 //enable CS
     for(i=0; i < 2; i++)
       SPI_sendchar(0xFF);                // Send 2 * 8 = 16 clock pulses 400 kHz
     Command(0x40,0,0,0x95);              // reset
idle_no:
     if (Command(0x41,0,0,0xFF) !=0)
     goto idle_no;                        //idle = L?
     SPCR &= ~(_BV(SPR0));                //fosc/4
int read(void) {
    int i;
    uint16_t ix;
    char r1 =  Command(0x51,0,512,0xFF);
    for (ix = 0; ix < 50000; ix++) {
        if (r1 == (char)0x00) break;
        r1 = SPI_sendchar(0xFF);
    if (r1 != (char)0x00) {
    return 1;
    //read from the card will start after the framework
    while(SPI_sendchar(0xFF) != (char)0xFE);
    for(i=0; i < 512; i++) {
        chars[i] = SPDR;
        SPDR = SPI_sendchar(0xFF);
    SPI_sendchar(0xFF);
    SPI_sendchar(0xFF);
char chars[512];
    ini_SPI();
    ini_SD();
    sei();
    read();
that is the code with CVAVR
thx..
it using fat32 mmc
haker_fox
PostPosted: Feb 05, 2012 - 11:17 PM
Hello there!
I strongly recommend you to pay attention to FatFS as it's been mentioned earlier.
There are a lot of projects for AVR using the filesystem. It might help you in a short time.
Good luck!
