Posted: Nov 02, 2011 - 12:29 PM |
The avr-gcc currently in widest use is the 4.3.3 in WinAVR so surely it's still there in that?
Yes, but this thread is about 4.6 and LTO.
Melbourne asked: why not using the old fashioned portable way as an alternative to LTO
You say: use --combine instead
I say: --combine does not exist as an alternative to LTO (because it is replaced by LTO)
Posted: Nov 02, 2011 - 12:45 PM |
Oh right I get your point - I was simply responding to the recent posts without taking into account the thread title (or previous contents). Sorry about that  |
Posted: Nov 02, 2011 - 12:50 PM |
melbourne wrote:
At the risk of being repetitive, if you want smaller binaries through smarter linking, just use standard C.
LTO/non-LTO does not affect the C standard. From the users' side it pretty much like any other optimization option.
That is, #include your source files into a single compilation unit.
This mechanism is standard, cross-platform, portable, and has worked for the past 30+ years: R included the mechanism in the first versions of C, K& wrote about it. It works with all versions of WinAVR.
No, it does not work for library code. You do not want to drag in libraries like libc or libm as source.
And encapsulation is was not on topic 30 years ago but might be on-topic today.
Personally, I'm a little irritated when I see people using non-standard, platform specific work-arounds for something that is already well supported in standard C: it makes my work as a cross-platform maintenance programmer just that extra bit more difficult.
It's not non-standard. It's just a feature that don't affect the language standard or you build scheme.
Moreover, you need not change the sources (which you will do when dragging them into one source file just to mimic LTO).
You do not want to hack sources to emulate each and every optimization feature.
If you mean by standard "use paradigms popular in stone age and never think about or change them" you correct, of course. |
Posted: Nov 02, 2011 - 01:06 PM |
| I tested zillions of parameters and tricks to reduce the size, and using one big .C or the --combine does not give the best results for my project (~16K binary). So YMMV. |
Posted: Nov 17, 2011 - 08:04 AM |
Why do that when --combine -fwhole-program exists?
Please refer to the original post. If there is something you do not understand, please post here again.
I'm staggered at the suggestion that you would drag sources into one source file, and by the accompanying suggestions that you would change/hack sources.
The whole point is to use the standard C "include" mechanism, which was designed for the purpose, to include portable code.
If you think LTO (and encapsulation) is more modern than "include", you've never understood Pascal. Your ignorance explains, but does not justify, your childish insult.
Thank you both for your thoughtful and insightful responses. It's good to see the level of maturity and care that you bring to your contributions here. |
Posted: Nov 23, 2011 - 05:01 PM |
| Okay, can someone fill me in with what's going on with avr-gcc? I exchanged an email with Thibault North who maintains the package for the Fedora project, he didn't know why or when the XMEGA support was pulled from the upstream (FSF) release of gcc. He told me other Linux distros use these patches against gcc 4.5.1. I thought the AVR patches were already in the upstream. Fedora's policy is to use upstream code exclusively. I've tried to bring those patches forward into 4.6.1, but so far I am unsuccessful. Does anyone have a working patch set for 4.6.1 they can share? |
_________________ I like cats, too. Let's exchange recipes.
Posted: Nov 23, 2011 - 11:28 PM |
The original question it *not* about some AVR application, it's about building avr-gcc as canadian cross.
How can you think it's even possible to include all files? The compiler gets what it gets, it's up to the user if he wants to include all headers, it's no choice for the compiler. |
Posted: Jun 05, 2012 - 10:26 PM |
What means "pulled from"? "Removed"? If so: xmega support went upstream for 4.7.0, see PR52261 and the GCC 4.7 Release Notes. At no point in time xmega support was removed from GCC.
What is the problem? |
Posted: Jun 06, 2012 - 01:26 PM |
Those patches relate to a previous version of Atmel's AVR Toolchain (3.3.x or less) which is derived from avr-gcc 4.5.1.
I wouldn't be surprised at all to discover that patches originally targeting 4.5.1 would be difficult to graft onto 4.6.1 -- especially for a target audience that doesn't have any interest in hacking the internals of the compiler, but rather wants a compiler that "just works".
The newest version of Atmel's AVR Toolchain (3.4.0) is derived from avr-gcc 4.6.x. Currently, it is only possible to obtain Atmel's AVR toolchain 3.4.0 integrated within Atmel Studio 6. All the necessary source code patches are included inside that binary distribution.
I haven't downloaded and installed Atmel Studio 6, so I do not have a copy of those patches myself. Otherwise, I would have been perfectly willing to post a copy of them for you to use. |
Posted: Jun 06, 2012 - 02:00 PM |
| Thanks for the updates, and for anyone looking for those patches in Studio 6, they are located here: C:\Program Files\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\source\avr |
Posted: Jun 06, 2012 - 03:07 PM |
The patches are supplied here:
http://www.avrfreaks.net/index.php?name ... 947#959947 |
Posted: Jun 06, 2012 - 06:00 PM |
Fedora 17 still does not have XMEGA support in the avr-gcc package: (I built the Fedora source RPM on EL6)
avr-gcc (Fedora 4.6.2-1.el6) 4.6.2
Copyright (C) 2011 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Known MCU names:
avr1 avr2 avr25 avr3 avr31 avr35 avr4 avr5 avr51 avr6 at90s1200 attiny11
attiny12 attiny15 attiny28 at90s2313 at90s2323 at90s2333 at90s2343
attiny22 attiny26 at90s4414 at90s4433 at90s4434 at90s8515 at90c8534
at90s8535 attiny13 attiny13a attiny2313 attiny2313a attiny24 attiny24a
attiny4313 attiny44 attiny44a attiny84 attiny25 attiny45 attiny85
attiny261 attiny261a attiny461 attiny861 attiny861a attiny87 attiny43u
attiny48 attiny88 at86rf401 ata6289 at43usb355 at76c711 atmega103
at43usb320 attiny167 attiny327 at90usb82 at90usb162 atmega8u2 atmega16u2
atmega32u2 atmega8 atmega48 atmega48p atmega88 atmega88p atmega8515
atmega8535 atmega8hva atmega4hvd atmega8hvd atmega8c1 atmega8m1 at90pwm1
at90pwm2 at90pwm2b at90pwm3 at90pwm3b at90pwm81 atmega16 atmega161
atmega162 atmega163 atmega164p atmega165 atmega165p atmega168 atmega168p
atmega169 atmega169p atmega16c1 atmega32 atmega323 atmega324p atmega325
atmega325p atmega3250 atmega3250p atmega328p atmega329 atmega329p
atmega3290 atmega3290p atmega406 atmega64 atmega640 atmega644 atmega644p
atmega644pa atmega645 atmega649 atmega6450 atmega6490 atmega16hva
atmega16hvb atmega32hvb at90can32 at90can64 at90pwm216 at90pwm316
atmega32c1 atmega64c1 atmega16m1 atmega32m1 atmega64m1 atmega16u4
atmega32u4 atmega32u6 at90usb646 at90usb647 at90scr100 at94k atmega128
atmega1280 atmega1281 atmega1284p atmega128rfa1 at90can128 at90usb1286
at90usb1287 m3000f m3000s m3001b atmega2560 atmega2561 |
Posted: Jun 06, 2012 - 06:07 PM |
| You have applied all these?
C:\Program Files\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\source\avr\gcc>dir | grep xmega
10/05/2012 16:51 28,668 301-gcc-xmega-v14.patch
10/05/2012 16:51 7,830 404-gcc-atxmega_16_32_a4u.patch
10/05/2012 16:51 3,069 405-gcc-atxmega64_128_192_256a3u.patch
10/05/2012 16:51 2,202 408-gcc-atxmega384c3.patch
10/05/2012 16:51 1,304 410-gcc-atxmega128a4u.patch
10/05/2012 16:51 1,339 411-gcc-atxmega64d4.patch
10/05/2012 16:51 2,343 413-gcc-atxmega64_128_b3.patch
10/05/2012 16:51 1,375 414-gcc-atxmega64b1.patch
10/05/2012 16:51 1,376 416-gcc-atxmega64a4u.patch
10/05/2012 16:51 1,390 417-gcc-atxmega128d4.patch
10/05/2012 16:51 3,745 419-gcc-atxmega16c4_32c4_128c3_256c3.patch
10/05/2012 16:51 1,344 420-gcc-atxmega384d3.patch
10/05/2012 16:51 1,391 424-gcc-atxmega192c3.patch
10/05/2012 16:51 1,335 426-gcc-atxmega64c3.patch
Posted: Jun 06, 2012 - 06:39 PM |
| binutils won't build for me with the patches applied, it fails on gas/config/tc-avr.c and bfd/elf32-avr.c with
‘BFD_RELOC_AVR_7_LDS16’ undeclared
Something appears to be wrong with the patch 503-binutils-avrtc193-tiny.patch. It builds fine if I omit that patch. |
Posted: Jun 06, 2012 - 08:25 PM |
The patch is incomplete: It adds new relocs in bfd/reloc.c but does not supply the induced changes to the auto-generated files. Notice that the new relocs are introduced in comments (sic!) that must be parsed by the generator tools!
Run make headers in bfd. |
Posted: Jun 07, 2012 - 12:53 PM |
| That fixed it. Here's an updated binutils patch that fixes the issue. |
Posted: Jun 07, 2012 - 01:09 PM |
