vision01
PostPosted: Sep 06, 2011 - 08:01 PM
Hi, I have just installed AVR Studio 5 and i am trying to run a simple example project from help files.
Now when i debug, I get a message
No Source Available
The source code cannot be displayed.
Call Stack location:
AVRGCC1.elf! no-debug-info
What is causing this problem and how do i fix it?
PostPosted: Sep 06, 2011 - 09:10 PM
If you had mentioned which example, then someone here might actually test the same project. W/o that information we can only guess: My guess at the most straight-forward reason is that the project was actually built without debug information.
1. Tell us what configuration you are building
2. Right-click the project, select Properties
3. Click the Toolchain tab, then select the AVR/GNU C node in the tree, and the Debugging sub-node
What do you have in the Debug Level drop down?
vision01
PostPosted: Sep 06, 2011 - 10:01 PM
Thanks for your response. I am using this example from the Getting Started help files. It is based on atxmega128a1 device using AVR Simulator.
* AVRGCC1.c
* Created: 9/4/2011 5:07:40 AM
#define MAXINT 200000
unsigned int t=1000,k=0,l=5,pn=2; unsigned int primes[t]; primes[0]=2; primes[1]=3;
while (pn<t||primes[pn]<MAXINT)
for ( k = 0; k < pn; k++)
if(l% primes[k]==0)
goto otog;
if(k==pn) primes[pn++]=l;
otog: l+=2;
The debug level in tool chain is Default -g2.
PostPosted: Sep 06, 2011 - 10:04 PM
Oh, come on! For someone to test out that example they would have to browse through them all to be able to fin the same exapmle, and set it up in the same way... Rolling Eyes
It has a name. Tell us that.
The quality of the answers you get is highly correlated to the quality of the question you ask.
Apart from that: Tell us (exactly) how you start debugging.
EDIT: Looking closer at your source code, it has no "real-world" effects at all. I suspect that the optimizer threw most of the code in your main() out.
Either make your code do something meaningful (in an AVR context),or turn off optimization (and live with the consequences of that). Also read this.
vision01
PostPosted: Sep 07, 2011 - 12:40 AM
It doesn't have a name. It can be found at Help>Getting Started>New Project>
I made a new project and copy the code there to the project as instructed in the help.
Optimization is set to NONE.
PostPosted: Sep 07, 2011 - 01:17 AM
My Help menu does not have a "Getting started" item.
Could you tell us exactly how you set up the new project?
Repeat: Could you tell us exactly how you start debugging?
("exactly" means: Tell us every step you took, citing menu selections etc verbatim.)
Another option might be that you zip up the complete project directory tree and attach the zip file to a post here, and someone might be willing to take a look at it.
This might seem tedious for you, but without that we'd have to resort to guesswork and the chances that we are in the same ballpark as you are are slim. You won't be helped, and we will have wasted our time testing something other than what you have on your machine. Your call..
vision01
PostPosted: Sep 07, 2011 - 02:28 AM
In AVR Studio 5, if you select help>View help or Ctrl+F1 the help page opens in browser. The heading of the help page says AVR Studio User Guide. On the left sub menu, 3rd option is Getting started. That's how i got there.
I selected File>New>Project. Then selected C Executable Project, then selected Device and okay. Named the project AVRGCC1.
Then i opened AVRGCC1.c from the solution explorer and copied the code from the example to this file.
Then i debugged it using Debug>Continue and Debug>Start Debugging and Break. Both gives the same message of No Source File.
I have uploaded the project directory in rar format.
PostPosted: Sep 07, 2011 - 07:50 AM
I downloaded your project and when I debug it works like a charm.
So this does not seem to have to do with the project per se.
What is the path to your project folder? Are there any special/national characters in that path? If you take a copy of the copmplete project and place it at e.g. C:\ , does it work better there?
vision01
PostPosted: Sep 07, 2011 - 09:44 PM
I moved the project to C: so that the new location became C:\AVRGCC1\ but still got the error.
Also i tried debugging the Example project "Sensor Data Visualizer" on my UC3-Xplained Board using AVR-Dragon Debugger. First i selected 'Start Debugging and Break'. Then 'step in', 'step over' but when i 'step out', i still get No Source error. The error says that there is no .elf file, though i can see the file in solution explorer.
I have already reinstalled AVR Studio, but now it has started to look like something is wrong with my installation of windows as you can run it fine.
PostPosted: Sep 07, 2011 - 10:05 PM
Well, it turns out that after playing around with this a wee bit (doing some tests of code snippets not at all related to your problems), looking at the disassembly and perhaps some other manouvres ... I have the same problem. "Start debugging and break" does not have the expected effect (and the effect it had when I started up).
One possible explanation might be that I at one time had two instances of AVR Studio 5 running (one was on it's way to exit directly from a debugging session). The other was just started (by double-clicking a .avrsln file.
Or it might not be that: I fiddled around a wee bit with the small test code (commenting out and in code, changing code order, rebuilding for each change and testing to start debugging), and suddenly it started working again.
PostPosted: Sep 07, 2011 - 10:28 PM
A wee bit more testing starts to reveal things, it seems:
The project is a junk project where I test all sorts of small C and AVR-related stuff. At this time it looks like this:
#include <util/atomic.h>
unsigned char data[3000];
struct CD_TYPE
     int title, artist;
     int year;
     double cost;
//structure declaration
struct CD_TYPE xyz;
void delay_ms (unsigned char del)
      unsigned char x;
      while (del > 0)
         for (x=0; x<10; x++) asm ("nop");
         del--;
        ATOMIC_BLOCK(ATOMIC_RESTORESTATE) {
           PORTB = 0xFF;
      delay_ms(2);
(Yes, you will recognize stuff from thread I have recently participated in...)
Now notice the ridiculously large array. If I remove that then starting debugging works as expected. Leaving it there makes the program go into an endless loop in what seems to be the startup code from avrlibc (run before main() is "called").
The disassembly (from the start to after the part that loops endlessly looks like this:
--- No source file -------------------------------------------------------------
00000000  RJMP PC+0x001A      Relative jump
00000001  RJMP PC+0x0029      Relative jump
. <more vectors than you want to see here>
00000018  RJMP PC+0x0012      Relative jump
00000019  RJMP PC+0x0011      Relative jump
0000001A  CLR R1      Clear Register
0000001B  OUT 0x3F,R1      Out to I/O location
0000001C  SER R28      Set Register
0000001D  LDI R29,0x04      Load immediate
0000001E  OUT 0x3E,R29      Out to I/O location
0000001F  OUT 0x3D,R28      Out to I/O location
00000020  LDI R17,0x0C      Load immediate
00000021  LDI R26,0x00      Load immediate
00000022  LDI R27,0x01      Load immediate
00000023  RJMP PC+0x0002      Relative jump
00000024  ST X+,R1      Store indirect and postincrement
00000025  CPI R26,0xC2      Compare with immediate
00000026  CPC R27,R17      Compare with carry
00000027  BRNE PC-0x03      Branch if not equal
00000028  RCALL PC+0x001E      Relative call subroutine
00000029  RJMP PC+0x0052      Relative jump
0000002A  RJMP PC-0x002A      Relative jump
--- C:\\Users\\Johan\\Documents\\AVRStudio\\SizeTest\\SizeTest\\Debug/.././SizeTest.c
0000002B  PUSH R29      Push register on stack
0000002C  PUSH R28      Push register on stack
0000002D  RCALL PC+0x0001      Relative call subroutine
My observations show that the loop at addresses 0x00000024 to ox00000027 is looping endlessly. Throughout this looping R17 is constantly zero and R27 is constantly 0x08. The strange part is that R26 goes to 0x0A and then wraps to zero. Another way to express this would be to say that the C register goes from 0x0800 to 0x081A and then wraps back to 0x0800. This happens at the Store indirect and postcrement instruction at 0x00000024.
I suppose that this is the loop that zeroes statically allocated variables with no explicit initialization.
It is a fact that the loop never ends. My brain is still in flu-mode and I can not make it tell me if this is a bug in Simulator, or the expected behavior when the tool chain is fed such crap as a ridiculously large statically allocated variable.
Anyway, when you get the message about no source - do you have an option there to "show disassembly"? If so, then what are you seeing there. A loop very similar to the one I point to?
What does your avr-size report tell you on the consumption of different memories?
My test code above was built and simulated for an ATmega88.
HTH!
PostPosted: Sep 09, 2011 - 10:35 AM
Surely this depends where RAM "wraps". Remember that the AVR registers R0..R31 appear at addresses 0x0000 so if you start at 0x0060 or 0x0100 or wherever and keep writing 0 from that address onwards and then the address wraps round to 0x0000 the code will start over-writing the same R0..R31 that are being used as loop variables to do the clearing. I built your code in AS5 for mega16 and got:
00000060 <__do_clear_bss>:
  60:   1c e0          ldi   r17, 0x0C   ; 12
  62:   a0 e6          ldi   r26, 0x60   ; 96
  64:   b0 e0          ldi   r27, 0x00   ; 0
  66:   01 c0          rjmp   .+2         ; 0x6a <.do_clear_bss_start>
00000068 <.do_clear_bss_loop>:
  68:   1d 92          st   X+, r1
0000006a <.do_clear_bss_start>:
  6a:   a2 32          cpi   r26, 0x22   ; 34
  6c:   b1 07          cpc   r27, r17
  6e:   e1 f7          brne   .-8         ; 0x68 <.do_clear_bss_loop>
So if this starts writing over R17/26/27 it's not going to be fun!
vision01
PostPosted: Sep 11, 2011 - 05:54 PM
Until now, I have tried almost every example project provided for UC3-Xplained board. Building the project and programming the board with the hex file works and and code executes fine. But debugging opens the same 'NO SOURCE AVAILABLE' windows. This is happening with every example project that i try to debug. Tried with optimization and without. Tried with all debug levels. The problems persists!!
harry4516
PostPosted: Sep 12, 2011 - 08:14 PM
as I know this is a bug in AVR Studio 5.
It is a timing issue between the debug editor and the reset time of the device.
I have exactly the same problem. If I restart the debugger 100 times, than it may happen that it works for one or 2 times.
Hopefully this will be solved soon, in the meantime I use AVRstudio 32 or AVRstido 4, which are working.
donblake
PostPosted: Sep 17, 2011 - 01:18 AM
Are you really seeing NO SOURCE AVAILABLE or are you seeing No disassembly available? If the later, see my reply in this thread.
Don
harry4516
PostPosted: Sep 22, 2011 - 08:42 PM
it shows "NO SOURCE AVAILABLE "
hemmerling
PostPosted: Sep 23, 2011 - 07:46 PM
I refer to the original starting posting:
I got the same message with my first demo project.
It happens after "Start Debugging and Break" in Atmel Studio 5, using my valuable JTAGICE3 for debugging.
Solution to avoid the message: Atmel Studio 5, project properties "Toolchain / AVR/GNU C Compiler / Optimization" - Set the "Optimization Level" to "None (-O0)".
Besides that with optimization, irgnore the error and go to the proper source file and continue debugging. A typical reason & consequence is that the first breakpoint is unavailabe ( = no red breakpoint bullet, where you expected as you set it before ), or the reason is that the location where "Start Debugging and Break" is expected to stop ( = first instruction of/in main() ) does not exist as code, due to code optimizsation.
It's the same effect like with the message "The breakpoint will not currently be hit", see
http://8515.avrfreaks.net/index.php?nam ... cdbe706e91
Sincerely
Rolf
http://www.hemmerling.com
SCADA Expertness - Quality Intensification for IT + Automation
PostPosted: Sep 23, 2011 - 07:53 PM
That's actually a terrible "solution"
See FAQ#4 and for more detail my tutorial:
Optimization and the importance of volatile in GCC
-O0 should be avoided like the plague (it's really only there for the compiler authors to be able to do some internal checks)
hemmerling
PostPosted: Sep 23, 2011 - 07:56 PM
a)
Well really terrible for debugging ?
Is it a must to have code optimization during debugging ?
b)
I named the guilty party, and how to avoid it, and why it does not much care if it happens.
Sincerely
Rolf
PostPosted: Sep 23, 2011 - 08:05 PM
If you want the thing you debug to represent what you plan to deploy then "yes". As I say in the article - throw in a temporary volatile if there's something you really need to watch.
hemmerling
PostPosted: Sep 23, 2011 - 08:29 PM
Hmmm.. how can you "throw a breakpoint" into a volatile variable ?
Maybe if you need a breakpoint at a specific point in the code, and want to be shure that it is not deleted by the optimizer, address a volatile variable at that point ?!
Sincerely
Rolf
PostPosted: Sep 23, 2011 - 08:34 PM
Admit it - you haven't read the article have you?
Bottom line: debug C+Asm
hemmerling
PostPosted: Sep 23, 2011 - 09:01 PM
Guilty Sad.
Please point me to the article Smile.
I will read immediately.
Sincerely
Rolf
PostPosted: Sep 23, 2011 - 09:37 PM
I gave the link above. Wink
hemmerling
PostPosted: Sep 23, 2011 - 10:04 PM
I just read in the paper XMEGA-tutorial from the official World-Tour workshop
Change project optimization.... Choose None (-O0 ). This is to be shure that the code associated with the breakpoint, is not optimized away by the compiler.
So my advice was compliant to the offical Atmel ASF Team mind Smile.
But to be honest, as my sample project grows, I get the error "No Souce Code" even I setup the compiler optimization to -0O.
So it was not a final solution.
Sincerely
Rolf
PostPosted: Sep 24, 2011 - 12:21 PM
Yes but to be honest they don't actually seem to have the first idea and -O0 is the "babies" way of debugging. Why not try the way the grown ups do it. The compiler only optimises away pointless code so if you cannot place a breakpoint it's because what the code is doing is pointless.
PostPosted: Oct 03, 2011 - 04:31 PM
Well I've just been bitten by this bloody "no source available" thing in AS5. For the benefit of the developers I then dropped to a command prompt and used "avr-objdump -S projname.elf" and it showed me the source. So the problem isn't that the ELF doesn't contain it - it's that for some reason the debugger cannot "see" it.
BTW I'm offered a "Browse to find source" link but clicking it does not produce a file browser?!?
Oh and this was a project that previously had one .c file. Someone sent me a new one. I removed the original file. Added the new one. Then rebuilt - maybe this is relevant?
Kraal
PostPosted: Oct 04, 2011 - 08:33 AM
Hello to all,
I had the same problem during the ATMEL Hands on tour (XMega), and I was the only one with this problem on 20 person. We tried to reinstall completely AS5 + ASF on my winXP 32bit, still it was not working.
But we found that the "No source available" has something to do with the fuse settings and the bootloader. If the bootloader was selected by the reset, then we get this message, but if the application was selected by the reset, then the debugging could start, however not breaking in main, but in an obscur asm file (can't remember which one).
But the ATMEL rep. there could not understand either where the problem was exactly, they think it's a bug in AS5/ASF/JTagICE3 (circle the correct answer Smile)
And of course the optimization had to bet set to -O0, if I wanted to be able to debug...
Best regards,
Kraal
PostPosted: Oct 04, 2011 - 09:19 AM
How very curious - I eventually cured it last night by copying the source .c file into a different place and re-building. Nothing to so with fuses, bootloader or anything like that.
It does seem a pretty serious problem though - a debugger that cannot debug is hopeless.
Kraal
PostPosted: Oct 04, 2011 - 09:40 AM
Hi Clawson,
Can you please explain what you meant by relocating the source file ?
I can understand that the reset vector is altered by the fuse settings, but I don't know how the JTAG manage the bootloader and the application, and the starting point of the program (i.e. main() ).
Best regards,
Kraal
Have a nice day,
Kraal
PostPosted: Oct 04, 2011 - 10:36 AM
Someone sent me a .c file. I downloaded it to my E:\, I then used File-New Project in AS5 and let it create AVRGCC4. Unfortunately, though I didn't want it, it created an AVRGCC4.c and added this to the project. So I right-clicked that and used "Remove" to remove it then I right-clicked the project and used Add-Existing Item and pointed it to the file in E:\. Apparently it copied the file to C:\AS5\AVRGCC4\AVRGCC4\. When I built this then clicked the Debug&break icon I got the no source message.
I just tried to recreate those steps (by first removing the file from the project and deleting it from the \AS5\... location) but this time it works.
God you gotta love this reliable software - it's not even deterministic when trying to recreate the bugs!
Maybe I'll try creating a whole new project which will inevitably be AVRGCC5 I guess?
EDIT: Oh yeah, that reminds me - this lack of libm.a is really bugging me. I now recall that another step I took was to add libm.a to be linked (because the C file uses math functions).
EDIT2: Nope it worked this time with AS5. So whether the debugger can "see" the source or not would appear to be completely random?!?
awalker
PostPosted: Oct 18, 2011 - 01:43 PM
@ clawson, I am a beginner with AVR and dont follow your last post on this issue! I am experiencing the same issue when i optimise the program which i have to do. What would u recommend? Should i just switch to AVR studio 4.18?
PostPosted: Oct 18, 2011 - 03:23 PM
Until this kind of issue is fixed then yes.
KreAture
PostPosted: Nov 25, 2011 - 10:24 AM
This issue has nothing to do with optimization levels at all.
It's a bug, it has to be.
I notice it varies on my computer (which has a SSD disk) from day to day with no changes in projects. Some days I can start debugging fine, others I get no source available and everything is very slow.
Simple projects with single files and a simple counter on a port can give this error. It has the code, it has the elf and yet it has issues talking to the debugger and claims that the debugee does not support setting breakpoints at runtime (while in stopped/paused mode).
It also does not "run/pause" to start of main but instead defaults to disassembler and the resetvector. Same code, chip and debugger in Studio 4 works as expected with no slowness and no errors.
There must be a statefull- or timing-bug in the way the different modules of avr studio 5 is communicating...
PostPosted: Nov 25, 2011 - 10:26 AM
If you have .elf files where it does/doesn't occur try avr-readelf on them. Is the difference single (\) or double (\\) path separators?
See this thread for details:
KreAture
PostPosted: Nov 25, 2011 - 10:31 AM
You are right regarding the -g flags however.
Especially when using multiple projects within a solution and compiling libraries. Often the default -g2 is lost in studio 5 and it reverts to -g0 causing issues with debugging.
Another thing to check, which has to do with the debugee reset timing is what clockrate you use on the debugger (for example the ice). Too low clockrate will actually cause issues due to the reset-timing.
Too high clockrate causes issues due to the ratio between internal clockrate and the debug signal rate.
On my sistem it works best if I stick between 1/4 and 1/6 F_CPU.
PostPosted: Nov 25, 2011 - 11:46 AM
Just to say this is not a debugger timing issue - I see it all the time (well most of the time) when simply using the Simulator.
KreAture
PostPosted: Nov 25, 2011 - 04:23 PM
I thought the simulator loaded like the debugger module? They appear to talk via some local tcp or such? That would allow same issue to affect both.
peter9999
PostPosted: Dec 12, 2011 - 11:30 AM
Yes it is a timing problem. I installed AS5 on a fresh W7-Installation, created a new fresh projecht wit the AVRGCC1.c, built it and tried to debug.
The Issue then sometimes occured, sometimes not, without any changes!
In my "normal" working OS (W7 too) it normally doesnt´t work, and sometimes rarely works.
deancs
PostPosted: Dec 13, 2011 - 01:13 AM
I'm seeing this same issue (no source available) while trying to debug a xmega128A1 with an AVR Dragon in the latest version of AS5. I don't have the same issue with the Simulator. No problems with AS4.
Have been back and forth with Atmel support who were unable to reproduce the issue or provide any answers. They left me with:
"We recommend you to test with AVR studio 5.1 (target release date : last week of December 2011 as of now)"
ikare
PostPosted: Dec 19, 2011 - 12:49 AM
No Source Available
I had same problem with AVR Studio 5.
I was trying to debug Atmega128 @ 16MHz with AVR Dragon
JTAG clock was 200kHz (default).
After ramping up the clock up to the max (avr studio reduced clock to 1,82MHz) debugging session was completed without any problem.
Hope it helps Very Happy
Skwit
PostPosted: Jan 24, 2012 - 03:23 PM
Don't know, if this is still active: I had the problem to. I moved my program code from the start of the flash at 0x0000 up to 0x0200, because I wanted a bootloader to live at 0x0000.
(I joined the .hex-files together afterwards with screc_cat but wanted to debug my program at 0x0200.)
So I inserted the directive ".text" at "0x0200" in the "Memory"-Tab of the project settings. Compiled like a charm, the .lss-file showed me my code at the right place.
In the debugger it showed "Running", then "Ready" on the lower left corner. No cursor on the next instruction. If I hit PAUSE, I got the "No Source Available", no "Browse to Find Source" and "Show Disassembly" only showed "No dissassembly available".
kind regards,
Christian
"It compiles! Ship it!"
