NeilAlexander
PostPosted: Jul 11, 2011 - 06:36 AM
1. After downloading and unpacking the latest .iso image for the support CD, both "make menuconfig" and "make" gave me a bunch of "permission denied" errors before quitting. It looks like a simple Linux permissions problem, but nothing I have done so far has resolved it. Ideas?
2. I have written a little program to flash one of the on-board LEDs by writing alternating 1's and 0's to the LED's file, with intervening nanosleeps. If I just run it, it crashes with a "Segmentation fault". If I run it as "su", it works fine. Do I have to do all of my physical I/O as "su"?
Thanks in advance,
Neil
hce
PostPosted: Jul 11, 2011 - 07:07 PM
1) Do a find . -type d -print 0 | xargs -0 chmod 755 followed by a find . -type f -print 0 | xargs -0 chmod 644. That should sort out all the permission issues. If you get permission denied while performing that, reset the file owner of the file to your user using the chown command.
2) Check which users have write access to the character device. You should also check if your open call returns a valid file descriptor, and not an error code.
NeilAlexander
PostPosted: Jul 12, 2011 - 12:54 PM
Thanks, hce. I tried that but I still get the following:
for "make menuconfig"
/bin/bash: package/config/mconf: Permission denied
for "make"
/bin/bash: package/lzma/lzmacheck.sh: Permission denied
/bin/bash: package/sed/sedcheck.sh: Permission denied
/bin/bash: .//toolchain/dependencies/dependencies.sh: Permission denied
make: *** [dependencies] Error 126
By the way, it should be "-print0" rather than "-print 0"
hce
PostPosted: Jul 13, 2011 - 08:38 PM
Correct, -print0 it is. The former was a typo by me.
NeilAlexander
PostPosted: Jul 14, 2011 - 03:32 AM
Also, did you mean to set 755 on files (not directories?) and 644 on directories (not files)? What is the downside of setting u+x permission on files that aren't executable?
A related question: In my system, right-clicking on a file shows properties which include a MIME type. Shell scripts and executables generally have the MIME type "application/x-executable", whether or not they have +x permission set. Is this MIME type interpreted by Linux as being equivalent to +x permission?
hce
PostPosted: Jul 14, 2011 - 04:49 PM
Directories needs to be executable to be able to go into them, files do not need to be executable. There is nothing limiting you setting file permissions to 755, you are still able to read them.
hce
PostPosted: Jul 14, 2011 - 04:51 PM
I guess your distribution looks at the start of the file to figure out its contents. Shell scripts typically start with a hashbang, to indicate what shell should be executed to run the script.
NeilAlexander
PostPosted: Jul 15, 2011 - 01:49 AM
Thanks again, hce, and my regards to all the citizens of Oslo. I notice you helped me way back on 2009, so you are delivering great service to the AVR community!
hugoboss
PostPosted: Jul 15, 2011 - 02:13 AM
No sane linux distribution would ever assume an executable MIME type as +x. That would be very very bad for a number of reasons. It's the kind of thing Windows does.
NeilAlexander
PostPosted: Jul 19, 2011 - 01:22 AM
Smile
