Posted: Jun 06, 2011 - 08:37 PM |
I’m sorry to say that, but to me it seems that gcc developers are living in their own word, and it’s a problem to communicate with them.
I'd say that on the list there is more focus on the internals of the compiler, the run-time lib and so on. There is less traffic on "How do I do this with an AVR?"-type questions. It's just different cultures. And when you try to talk on e.g. the avr-gcc list you should have done your reading up.
Here on AVRfreaks the culture is less rough in this respect. (Not that we do not bash the self-inflicted-clueless or the people trying to get school work done with no effort on their on...)
By and large, the people on the avr-gcc/avr-libc/AVRDude lists are just as nice, helpful and polite as here on freaks. Just somewhat different cultures. It always helps to read through old threads or go through a few digests in a mailing-list-archive to get the feel for the way to move in a certain social environment. Remarkably like Real Life [tm], if you ask me... |
Posted: Nov 21, 2011 - 06:17 AM |
Does GCC really copy the vtable to RAM for every instance of a virtual class? Or does it just create a single copy of the vtable in RAM?
Josh |
Posted: Nov 21, 2011 - 07:10 AM |
| Josh! I have not checked, but I would be surprised (to say the least) if it created a copy for every instance. Why would it? I've heard of no C++ compiler that creates v-tables per instance. |
Posted: Nov 21, 2011 - 03:25 PM |
Interesting, I kind of assumed that, but some of the posts made it sound like a majority of their RAM was being taken by vtable copies... I'm not sure this is a huge deal for a microcontroller (at least not for my project), I have maybe 4 distinct classes that have 1, or maybe 2, virtual methods; all my other classes use static dispatch.
If all the work was done to add this GCC feature, would it save me all of 16 bytes of RAM (4 16-bit vtable entries for 4 classes)? I assume there is also a 16-bit vtable pointer that is copied into RAM for each instance, I would think this could add up much more quickly. |
Posted: Nov 21, 2011 - 03:39 PM |
Yes, it is a part of the "object structure"(i.e. what the this-pointer is pointing to in a called (non-static) member function).
Another way of saying this is that a virtual function call is actually equivalent to something like this (for a call from a member function to a virtual member function):
this->vtable->func(this, parameter1, parameter2 ...)
Yup.
Yup.
Alo: Apart from the RAM consumption, this might be an issue with code size / execution time (if RAM access is more compact or faster than flash access). |
Posted: Nov 22, 2011 - 06:54 PM |
Is the vtable pointer actually variable between instances? Could it technically be implemented as?
MyClass::vtable->func(this, param1, param2 ...)
I could see going to the work to make the vtable pointer stay in flash being worth the work, more than the vtable iteslf... |
Posted: Nov 22, 2011 - 07:40 PM |
For the technical aspects you will have to dive into the C++ frontend: http://gcc.gnu.org/viewcvs/trunk/gcc/cp/
(Intrinsic) named address spaces are only mentioned as a language extension to C++, see ISO/IEC DTR 18037, Annex F.2, which is not imlemented in GCC.
PR43745 does not imply to expose named address spaces to the user, yet "bits" of named address suppport in GCC's C++ front end are missing, of course.
As PR43745 is 1 1/2 years old now and no one even managed to supply a small example that shows the problem, I'd guess that PR is bug-rot and can be closed? |
_________________ avr-gcc News • ABI • Options • 4.8-Windows • Inline Asm
Posted: Nov 22, 2011 - 09:31 PM |
Yes, AFAIK it must be or the polymorphism would not work. The point is that when you have a pointer to a superclass it is not known what subclass the object (pointed to) actually is. Thus each object has to be able to inform about where the applicable vtable is.
Sketchy example:
class Super
public:
virtual void foo() = 0;
class Sub1
public:
virtual void foo() {...}
class Sub2
public:
void main(void)
Super * objects[10];
for (int i = 0; i < 10; i++)
if (rand() > 0.5)
objects[i] = new Sub1();
objects[i] = new Sub2();
objects[i]->foo();
There is no way to tell at compile time what objects will be created. Thus the compiler must generate code that at run-time determines what foo() is called. Thus every object needs to have information making this possible. Although the C++ standard says nothing specific about how this is to be implemented, but leaves it open to the implementers, the only variant I've seen/heard of is for every object to have a pointer to it's vtable. (With multiple inheritance it might be a little more involved, but the principle about every object knowing still holds.
This is also, at least conceptually, closely related to RTTI. |
Posted: Sep 03, 2012 - 05:54 AM |
Posted: Sep 03, 2012 - 06:40 AM |
Greg,
The best place to start that research would be to find out if you really need polymorphism. Are you actually calling all of those virtual member functions through a pointer to a base class instance ? Throw in a few examples of how you need it. |
_________________ Sid
Life... is a state of mind
Posted: Sep 03, 2012 - 06:50 AM |
Chauncey!
Since he mentions a "despatcher" I would speculate that it is "the Run() function" that is virtual.
On e of the school book examples of polymorphism in action. |
Posted: Sep 03, 2012 - 07:02 AM |
Sure. Schoolbooks are useful in the appropriate context - the school - but in reality too much abstraction for a simple problem comes at a cost at more than one level.
I think I read somewhere the other day that some Atmel guys had recently implemented the bubble sort algorithm in assembly. That's a joke if there ever was one. |
Posted: Sep 03, 2012 - 08:06 AM |
JohanEkdahl wrote:
Chauncey!
One of the school book examples of polymorphism in action.
This is correct.
I have been converting a small project to cpp mainly as a learning exercise.
I have a small executive where application processes are implemented as state machines in c functions. the despatcher calls the applications processes via an array of pointers to functions where the argument to the function is an event for each application process. this is very straightforward in c.
I have converted all my queues, timers and other support functions to classes. The design is cleaner and the memory usage is reduced!
I am having a look at what would be involved in converting some/all of the application processes to be classes. Although there are some advantages in the application processes the despatcher seems to consume heaps of ram for vtables.
the concept is...
class base
virtual void run(event);
class procN: public base
void run(event)
// do the stuff for user process N
base procTable[] = {pointers to proc1.. procN}
events are delivered by indexing procTable[] with the pid and calling run()
If there is a simpler method I am interested to know it.
The approach outlined above is way expensive with RAM usage. |
_________________ regards
Greg
Posted: Sep 03, 2012 - 09:24 AM |
So is the whole vtables in flash thing brouhaha? If it's not something that actually affects working, concrete examples of real application code on AVRs why does anyone care? And when those folks turn up saying "C++, bloat, "hidden RAM", etc" ask them for their concrete example of where it's happening too.
I'm sure there are areas of the compiler with a stronger justification for research/engineering than some navel fluff examination if that's what this is? |
Posted: Sep 03, 2012 - 10:21 AM |
OK, let me rephrase: A scheduler is for me an excellent example of where C++ virtual functions really helps make for nice, redable, optimized-for-maintenance code. |
Posted: Sep 03, 2012 - 06:16 PM |
gregd99 wrote:
the concept is...
class base
void run(event)
Whether a less expensive approach is simpler or not depends on how big N is.
But even for non-small N you still have to create and add each process to your array - and apparently keep a mapping between each process and its place in the array.
gregd99 wrote:
How are these "events" created ? How is the "pid" for any given event determined ?
It would be easier to suggest a simpler solution if you posted more code.
To me, it depends on how complicated the alternative would be. Adding abstractions doesn't necessarily make the code easier to read or maintain.
I also look at whether or not I can afford the cost of making the code "easier".
If the code actually is easier - to me, that means simpler - why would that come at a cost ? Code that actually is simpler tend to generate smaller binaries. |
