loutek
PostPosted: Jun 04, 2011 - 02:20 PM
Hi all, I want to read a multiple ADC input without using interrupt.CPU running at 8 Mhz
I use this sub:
uint16_t Read_ADC (uint8_t ch)  {
ADMUX = (1<<REFS0);   //AVCC as ADC Voltage Reference
  ADCSRA = (1<<ADEN) | (1<< ADPS2); //enable ADC, prescale 16
ch = ch&0b00000111;
ADMUX |= ch;
  ADCSRA |= (1<<ADSC);
  while (!(ADCSRA & (1<<ADIF)));
  ADCSRA |= (1<<ADIF);
  return ADC;
read the input value and in main:
int main() {
   DDRB = 0xFF;
   uint16_t ADC_result = 0;
   int i;
    USART_init();
   adc_Init();
   while (1) {
      for (i = 0; i < 3; i++) { //start the scan...
         ADC_result = Read_ADC(i); //and read the result
         switch (i) { ...then i use the value to do something
But nothing happens.
However if I remove the for loop and
ADC_result = Read_ADC(0);
i can read the ADC value.
Any suggestion?
thank you
PostPosted: Jun 04, 2011 - 02:23 PM
Not enough context. Show more of the code and explain "nothing happens" and how you are observing that.
loutek
PostPosted: Jun 04, 2011 - 02:48 PM
By now i just want to read a voltage on ADC0 and ADC1 and turn on/off a led.
nt main() {
   DDRB = 0xFF;
   int i;
    USART_init();
   adc_Init();
   while (1) {
      for (i = 1; i < 3; i++) {
         switch (i) {
         case 1:
            if (ADC_result < 120) {
               PORTB = 0x01;
            else if (ADC_result > 150) {
               PORTB = 0x00;
         case 2:
               PORTB = 0x01;
               PORTB = 0x00;
no led is turned on/off
Thank
PostPosted: Jun 04, 2011 - 05:06 PM
But this reads ACD1 and ADC2.
loutek
PostPosted: Jun 04, 2011 - 07:11 PM
@koshch
you're right... But not working at all
for (i=0; i 2; i++)
i'll try another solution...
Visovian
PostPosted: Jun 04, 2011 - 08:43 PM
deleted
Visovian
PostPosted: Jun 04, 2011 - 08:58 PM
ch = ch&0b00000111;
ADMUX |= ch;
Error, look here
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=107120&highlight=
loutek
PostPosted: Jun 27, 2011 - 10:19 AM
Thank you all...
Ok... Reading other posts it is better to use interrupt.
So that's my way:
 ATmega16 @ 8 Mhz
 PORTA as ADC
 PORTB leds
#include <inttypes.h>
volatile uint8_t adc_result[8];
volatile uint8_t input = 0; // both var. volatite because shared by main and ISR ...clawson FAQ #1
void ADC_init(void);
   DDRB = 0xFF; // PORTB as Out
   ADC_init();  //init ADC
   sei(); // enable all interrupts
   ADCSRA |= (1 << ADSC); // first ADC conversion
   while (1) {
      if (adc_result[0] > 150) {
         PORTB = 0x01;
      } else if (adc_result[0] < 150) {
         PORTB = 0x00;
      if (adc_result[1] > 150) {
         PORTB = 0x02;
      } else if (adc_result[1] < 150) {
         PORTB = 0x00;
ISR( ADC_vect ) {
   adc_result[input] = ADCH; // input 0, first result, 8 bits
   if (input < 8)
   input++;
   input = 0;
   ADMUX |= input; // next input
   ADCSRA |= ( 1 << ADSC ); // next conversion
void ADC_init() {
    ADMUX |= (1 << ADLAR) | (1 << REFS0); // left adj. and AVcc as reference
   ADCSRA = (1 << ADEN) | (1 << ADIE) | (1 << ADPS2); // Enable ADC, interrupt, prescaler 16
...but I can't see any led on. Sad
PostPosted: Jun 27, 2011 - 10:41 AM
You never clear the previous channel setting. Suggest you use:
ADMUX = (1 << ADLAR) | (1 << REFS0) | channel;
indianajones11
PostPosted: Jun 27, 2011 - 11:11 AM
Also, one time code should be done... once . Put
in your adc_init() ( which you already did, so no need to repeat the same stuff ). It's just a waste of time / memory to do it the way you did .
Your code with the switch is not right, time to open your C book and look at that.
loutek
PostPosted: Jun 27, 2011 - 07:35 PM
Hello, when I start debuging the changed code
   while (1) {
      if (adc_result[0] > 120) {
         PORTB = 0x01;
      } else if (adc_result[0] < 120) {
         PORTB = 0x00;
      if (adc_result[1] > 120) {
         PORTB = 0x02;
      } else if (adc_result[1] < 120) {
         PORTB = 0x00;
ISR( ADC_vect ) {
   if (input < 8)
   input++;
   input = 0;
   ADMUX |= (input & 0x07); // next input and mask the bits
I can see in the I/O view no ADSC setted by
instruction
I think code is correct but I can't check where is my error or what I can't understand.
Thank you
PostPosted: Jun 27, 2011 - 07:41 PM
I start debuging
Simulator or real hardware debugging?
loutek
PostPosted: Jun 27, 2011 - 07:46 PM
...real hardware debugging. I test hardware too and things work... i think it's a programming issue..
Thank you very much for reply.
PostPosted: Jun 27, 2011 - 07:59 PM
This is not right - you are NOT clearing the previous channel selection - presumably you did not understand my previous answer?
indianajones11
PostPosted: Jun 27, 2011 - 10:43 PM
I doubt that you put a breakpoint and then single-stepped into the ADSC being set, because you didn't see it , but you didn't say the ISR DIDN'T fire , OR that you didn't get adc_values . If you run the debugger at full speed, there's plenty you'll miss, if that's what you're doing .
Anyway, you're bouncing all around with these code versions and it's not a good move to go from non-working code to a more complex non-working version ( ISR ).
How are ALL your MCU adc pins connected and which debugger do you use ? Put adc_result in the watch window and breakpoint after it should get a value in the ISR .
You don't see any LEDs on, but only superman could since it would be too fast for you to see . You have no delays for when it's on / off .
loutek
PostPosted: Jun 29, 2011 - 02:27 PM
to clear the previus channel:
ISR( ADC_vect ) {
   for (input=0; input <8; input++) {
        input = ADMUX;
        input &= 0x07;
        ADMUX++;
      ADCSRA |= (1 << ADSC); // next ADC conversion
    ADMUX &= 0xF0;
Now if a simulator debug i can see ADSC setted, in real debug with avr dragon no ADSC is setted Confused Confused
PostPosted: Jun 29, 2011 - 02:29 PM
Your code makes no sense whatsoever?!?
loutek
PostPosted: Jun 29, 2011 - 02:37 PM
...Ok I give it up...
Kartman
PostPosted: Jun 29, 2011 - 03:14 PM
Go back to your original code and fix the problems. Have you read the datasheet onthe part you're using? It is all pretty simple, but you're making some fundamental mistakes.
PostPosted: Jun 29, 2011 - 04:05 PM
In your latest code, what is the point with doing
        ADMUX++;
Youre at the end of the loop, just about to iterate and increment input which will then be assigned to ADMUX.
PostPosted: Jun 29, 2011 - 04:36 PM
Johan,
That's just one of many things. He's clearly using interrupts yet switches to a polling method in the ISR. That polling method, rather sadly does not actually poll the thing it's supposed to. And, as you say, the ADMUX++ thing is just plain odd given that he already has an iterator. As I said previously:
indianajones11
PostPosted: Jun 30, 2011 - 05:27 AM
You keep saying you don't see ADSC set or LEDs come on, but you didn't do ANY of the things I suggested either, huh ( I'm banking that you don't REALLY know how to use the debugger / IDE in a totally correct way and it's part of your confusion with the i/o view. Another time for THAT though. ) ? STOP changing ( supposedly ) non-working code into different versions ( It makes no sense for you to do the for{} in the ISR, considering all it needs is an inc. of the index. You went from ( bad ? ) to definitely worse with that 1. ) .
DON'T enable any ISRs, do the init() and in your while(1) JUST have an led turn ON at a threshold value ( verify what the # should be with a DVM ), disable the adc and NOTHING ELSE ( for now ) in the while loop . That means take the for loop OUT. Whether this works ( should ) or not, don't change it until it's working ( post ALL the code and let's work with that. Don't make any functions yet, keep it out in the open for now. ). Make sure you're connected to CHANNEL 0. Modify your OP code version and tell us what happens with THAT . After starting the conversion, do these before the while(1):
while( ADCSRA & ( 1<< ADSC ) ); // wait under conversion done
adc_result[0] = ADCH;  // Then test if this is > 120
Is your adc hooked up right based on the REF bits, and do you have the cap. on the Aref pin ( you never answered my question about all that Rolling Eyes ) ?
loutek
PostPosted: Jun 30, 2011 - 08:59 AM
@ indianajones11
Thank you very much for the reply (and patience!!)
as soon as possible I will do what you suggest me.
L.
loutek
PostPosted: Jun 30, 2011 - 09:38 PM
   DDRB = 0xFF;
   ADMUX |= (1 << REFS0) | (1 << ADLAR); //AVCC as ref. and left adj.
   ADCSRA |= (1 << ADEN) | (1 << ADPS2) | (1 << ADPS1); //enable ADC, prescale to 64: 125 kHz @ 8 Mhz
    ADCSRA |= (1 << ADSC); // start conversion
   while (1) {
      if (ADCH < 120) {
         PORTB |= 0x01;
         } else if (ADCH > 120) {
            PORTB = 0x00;
      ADCSRA &=~ (1<<ADEN);  //disable ADC
       int result = 0;
   DDRB = 0xFF;
    result = ADCH
   while (1) {
      if (result < 120) {
         PORTB |= 0x01;
         } else if (result > 120) {
            PORTB = 0x00;
I always see a led turn ON... I think I should
in the while (1) loop and then
ADCSRA |= (1 << ADIF);
as the datasheet says to clear ADIF by writing a logical one to the flag.
Thank you.
indianajones11
PostPosted: Jun 30, 2011 - 10:24 PM
Good work ! I use ADSC since it auto-clears when a convert is done. ADIF takes an extra line, but works too. You can redo it for constant converts in the while, just code it right. Don't just try ANYTHING, THINK(!!) about stuff at each point and come up with code that makes sense ( BE the cpu ), if you have to do it line by line . Don't write alot of code and then test it... do it little by little. My point in asking you to code what you have NOW is start with something you KNOW works and go from there.
NOW you can think about using a for loop ( NO Switch or anything else yet ! )to read X number of values into your array and when the loop's done, use dragon to confirm that ALL channels, that you want, are there. Build it gradually and then you're ready to try it with an ISR ( ADC_ISR isn't the best way, like you state from 1 of your posts, it's used IF NEEDED that's all. ). You now know better from this thread what should/shouldn't go in the init() / read() AND the correct way to change channels. Put your init() and read() back in when you're ready.
If you want to see ADSC clr in i/o view, open disassembly window and breakpoint or run...cursor to the line just below that loop. Running full speed, it sets/clrs too fast and it just appears to always be set.
PostPosted: Jul 01, 2011 - 07:35 AM
If you are checking the ADSC flag, there is no need to clear the ADIF flag. You only need to do that if it is the ADIF flag that you are checking.
eventhorizon
PostPosted: Jul 08, 2011 - 06:04 PM
Hi! For multiple ADC's what I did was instead of iterating the ADMUX to switch the ADC input, I connected several sensors between a different ports to a single ADC port. And what I meant by that is PD0 to PC0, PD1 to PC0, PD2 to PC0.... Instead of connecting your sensor from Vcc to your ADC input, you get power from some other port and then switch those ports. I would happily code and make a schematic of it for you guys you you'd like
PostPosted: Jul 08, 2011 - 06:14 PM
So you are multiplexing externally when the AVR contains an multiplexer internally? Very odd?!?
eventhorizon
PostPosted: Jul 08, 2011 - 06:39 PM
Well yes, given that you have like 2 or more sensors to read, you'd eventually use several ADC pins too. With that for an atmega8 with only 5 ADC pins, could be increased to <5 * unused_ports> (now who would use that much sensors...)
eventhorizon
PostPosted: Jul 08, 2011 - 06:41 PM
BTW, I'm not sure if you could read two or more ADC pins at-the-same-time. By externally multiplexing the sensors, you could scan 2 or more sensors in parallel, or what ever combination you want.
Kartman
PostPosted: Jul 09, 2011 - 03:23 AM
Eventhorizon, there is only 1 adc but there is a number of analog inputs on the AVR. You can only convert one at a time.
eventhorizon
PostPosted: Jul 09, 2011 - 11:14 AM
Yes Kartman I'm aware of that. I just gave another method of reading multiple sensors through 1 ADC by multiplexing sensors externally. Say, an ATMega8 only has 5 ADC pins, but you need to scan 10 sensors, you could use 5 other ports for 1 ADC, then another 5 on another ADC. It's not the conventional way of doing it, but it works and I'm using using it on my sumobot.
PostPosted: Jul 09, 2011 - 02:37 PM
Most mega AVRs have 8 mux inputs so why add the additional hardware overhead of an external mux until you run out of 8. Though I agree you are forced to do this for 10 channels on a 5 channel MCU.
loti1990
PostPosted: Jun 09, 2012 - 09:43 AM
uint16_t Adc_Read(uint8_t adc_input){
   uint8_t low_bit=0;
   uint16_t avrage=0;
   ADMUX=(ADMUX & 0xf0)|adc_input;
   _delay_us(10);
for(int i=0;i<31;i++){
ADCSRA|=1<<ADSC);
while(!(ADCSRA & (1<<ADIF)));
low_bit=ADCL;
avrage+=(uint16_t)((ADCH<<8)|low_bit);
    ADCH=0;
    ADCL=0;
   return(uint16_t)(avrage/30);
That functions works excellent !!
