Posted: May 13, 2011 - 07:08 AM |
we encountered several problems running the demos under Windows 7. All those demos seems to rely on the Java runtime.
We had the first problems during installation of the WSN Monitor. The setup just stops and shows a blank screen. We fixed that issue by installing the application in an already existing directory.
But after that, the Connect button does not show a select com or other form - it just does nothing.
Is there a way to use the application with win7 64bit?
Thank you!
MrPec |
Posted: Mar 15, 2012 - 03:31 PM |
I have that problem too!
you got to solve?
thanks |
_________________ Marco Alves
Posted: Mar 15, 2012 - 06:37 PM |
| Same here WSNDemo and Bootloader Tool only runs fine in WinXP |
Posted: Mar 16, 2012 - 04:58 AM |
| I think you need to run it as administrator first time, but I'm not sure and I'm lucky enough not to have Win7 around. |
