rider_wakya
PostPosted: May 13, 2011 - 01:40 AM
i want to convert time based analog signal to frequency based signal (spectrum signal) by using microcontroller and display it on graphical LCD...,
i think method that i can used is FFT....but i haven't knew yet how to applied FFT method on microcontroller...
can you tell me the algorithm for FFT on microcontroller?
thanks before...
PostPosted: May 13, 2011 - 02:25 AM
Lots of FFT source code on the web. You have any requirements? You want to analyze your stereo speakers? You need 20Hz to 20KHz. 20Hz has a period of 50ms. 20KHz freq resp means you need to take samples at 40KHz (every 25 usec) for 50ms. Thats about 1250 samples. FFT programs like to use a power of 2, so I'll suggest 1024 samples. You can take 8 bit samples or 10 bit samples with the AVR a/d converter. That will give you 36 dB or 54 dB range. (Looking for distortion needs a deep range. Just adjusting your room eq will do with the smaller range). Here's the problem: you need 1024 4 byte reals and 1024 4 byte imaginaries (that's 8K byte of ram needed). For this you need the new mega1284 with 16K of ram.
RickB
PostPosted: May 13, 2011 - 04:11 AM
Go to youtube and search for avr and fft. Lots of examples, some with links to the project. Many use the fft module from ChaN.
http://elm-chan.org/docs/avrlib/avrfft.zip
rider_wakya
PostPosted: May 13, 2011 - 05:41 AM
i want to analyze range frequency signal until 160MHz...
I use mixer and DDS AD9951 to down converter this signal close to zero, then i do filtering using Max297 (LPF), then sampling using ADC 12 bits....
you say that i need real sample and imaginary samples,
can you tell me why we need real and imaginary sample on FFT method?
i still need more information about that...
rider_wakya
PostPosted: May 13, 2011 - 05:44 AM
is it possibe if i use ATmega32 as the controller of this?
mckeemj
PostPosted: May 13, 2011 - 08:34 AM
You state the base frequency of your signal ( 160MHz ) and that you are down converting it, but you do not state what the necessary bandwidth of your sampling is - that is the important bit. Bob gave an excellent example of designing a FFT for a specific pass band ( in his case audio ); you will need to do something similar. If the bandwidth requirements and harmonic discrimination requirements ( FFT sample width ) are light enough, yes, it could be implemented with an AtMega32; but we do not have enough information to be able to say one way or the other.
As for the imaginary/real samples... perhaps you should read a bit about Fourier transforms - they are complex functions. You can store all real samples, and/or ignore any complex frequency components, but the function itself does work with them. There are optimizations for real-valued, symmetric, functions but, as I said, you really need to read about them for yourself.
Martin Jay McKee
As with most things in engineering, the answer is an unabashed, "It depends."
mikrosen
PostPosted: May 19, 2011 - 09:43 AM
Martin Jay McKee
hi..
want to convert time based analog signal to frequency based signal (spectrum signal) by using multitasking computer tinytiger2 and display it on graphical LCD...,
i think method have to use is FFT....but i am not having any idea about FFT
can you tell me the algorithm for FFT In the form of flowchart or procedure it will help for me to understand.
PostPosted: May 19, 2011 - 10:19 AM
Did you follow Rick's link. Did you see the page it comes from:
http://elm-chan.org/works/akilcd/report_e.html
mikrosen
PostPosted: May 19, 2011 - 10:31 AM
i got some idea thanks for your reply. but i need the flow chart for the FFT algoritmh...
RickB
PostPosted: May 19, 2011 - 04:17 PM
Before you try to understand fft, learn how to use google.
http://www.dspguide.com/ch12/2.htm
http://www.syscompdesign.com/AppNotes/fourier-transform.pdf
