Posted: Mar 15, 2011 - 08:45 AM |
I want to program in Tiny25 with HVSP. I'm certain the jumpers are correct on the Dragon. However there is no HVSP option in the "AVR Programming Dialog". All I get to choose from in the Interface drop down is ISP.
How do I enable HVSP?
Why do I need to, because my Dragon met with an accident when I was using the ISP. So I've removed the voltage comparitor and hardwired volts from the USB connector, as detailed in a number of posts. The Dragon powers up fine. Not sure if this is why HVSP is unavailable.
BTW I like Studio 5. |
Posted: Mar 15, 2011 - 10:14 PM |
| I realise I should have titled this. "Does HSVP work with AVR Studio 5 and Dragon?" |
Posted: Mar 15, 2011 - 10:39 PM |
Good that you think about it. But the title is clear. No worries.
If you want you can edit your own post and change the title. I can do it for you, but it's good to learn these things.
As for your question: AVRStudio5 is still beta. So I suggest you keep using AVRStudio4 for what MUST be done. And AVRStudio5 for testing.
Plons
moderator |
Posted: Mar 15, 2011 - 11:40 PM |
Thanks for the comment Plons.
I hadn't considered reverting to AVRStudio4 because Studio5 seems so close. I also considered it as most likely some configuration issue with Studio5 that I didn't understand.
I'll try AVRStudio4 later. |
Posted: Mar 16, 2011 - 07:23 AM |
Hi.
I am sorry, but HVSP on the AVR Dragon is not yet supported.
The issue number for this problem is 13830.
Torleif Sandnes,
Atmel Norway |
Posted: Mar 16, 2011 - 09:29 AM |
| Is the bugzilla (or whatever system it is you use) available online? |
Posted: Mar 16, 2011 - 09:33 AM |
No, this is an internal issue tracking database only.
Torleif |
Posted: Mar 16, 2011 - 09:50 AM |
| I can confirm HVSP works fine with AVRStudio4. A real shame, I was enjoying using 5. |
