Search |
Posted: Mar 04, 2011 - 11:42 PM |
I am trying to understand this protocol that my DSC 1555 alarm uses between the base and the keypad, but issue is its propriatary of some sorts. There was another thread about it on this forums but it ended prematurely with the guy just checking one bit for stay or away mode.
From what I know about this protcol so far the clock line runs at 1kHz with 50% duty and oddly enough only does so for 41.6ms then it stays high for 5.4ms and starts all over again. The data line seems to transistion on either the falling or rising edge of the clock (or in the middle), which led Kortuk of chiphacker.com to belive that it is NRZ encoding which I'm not sure of yet but here are some OLS dumps of the data and clock lines hopefully with teamwork we can figure this out.
I'm pretty sure the data is the same as whats listed in the PC5401 pdf below just sent via some weird protocol, all I really need help with is figuring out whats a 1 and whats a 0. From there I'm confident I can figure out the rest. Thanks for your time
0 is the Data line, 1 is the Clock
DSC OLS Dump
ECP Patent
PC5401 Dev-PDF
Previous AVRFreaks Thread |
Posted: Mar 05, 2011 - 12:36 AM |
I have a DSC system, but I've never bothered to investigate it. I assumed, since it's a 4 wire connection to all the keypads in parallel, that it used some kind of RS485 multi-drop protocol, or possibly I2C.
I'm not quite sure what I'm looking at in your .ols files - I assume bit 0 is one line and bit 1 is the other, but I can't make sense of the data. |
Posted: Mar 05, 2011 - 12:53 AM |
Forgot to mention 0 is Data and 1 is Clock
From what more I've read in patent 6868493 it appears that the actual MCU on the DSC alarm speaks RS485 then I'm guessing somewhere else it is changed into the propriatary ADEMCO ECP (Expanded Console Protocol)
The OLS files are for the OpenLogic Sniffer client |
Posted: Mar 05, 2011 - 01:19 AM |
The DSC keypads are so cheap, and so simple, that I find it hard to believe they could afford any external circuitry to change to a protocol not supported by the main chip. Of course we don't know what that is, since the chip is masked and proprietary. Maybe plotting out the clock and data on paper will make sense of it.
You have to go a long way down the "idle_test.ols" to find a state where both clock and data are low at the same time, and then it's only present for a couple of samples. |
Posted: Mar 05, 2011 - 01:44 AM |
| That is true, I never thought about the keypad itself having to TX back to the base. |
Posted: Mar 31, 2011 - 10:19 PM |
I was in a similar situation with a DSC 1580 base central. I have no oscilloscope so I don't know the exact timings but I have figured out the protocol.
Signalling is made with a CLK line (yellow) and DATA line (green). The frequency is 1kHz. Base central acts as a master unit and all panels as slaves.
Before any command is sent by the master, a synchronization occurs where CLK is high for approx. 5-10 ms. After this, CLK is a square wave with 1ms cycle until all data bits has been sent followed by next synchronization.
The tricky part was to realize that data is sent bidirectionally between master and slaves at the same time. On falling CLK flanks, master sends a bit on DATA line and on rising CLK flanks, slave sends a bit.
I don't know the exact timing, but if I read DATA line 400us after CLK flank, it works for me.
I strongly suspect that a slave (panel) just has an open-drain on the DATA line, if nothing is sent it will read back as a logical 1.
Data sent by the master is mostly of the form:
Command (8 bits)
Zero padding (1 bit)
Data (x * 8 bits)
Checksum (8 bits)
Some commands don't have a checksum. It may be to support old panels as it seems that these are mostly followed by another command containing the same data and a checksum.
The checksum is a simple sum of the other bytes.
Slaves respond from the 9:th bit and onward.
For example, to detect which panels are available, master sends 0x11 as command. Each panel respond by sending two zeros at position 9 + ((slot-1) * 2) where slot is the programmed slot for that panel [1-8].
I hope this will be of help, I had no luck in finding any information about this protocol anywhere so I had to do it the hard way. |
Posted: Apr 03, 2012 - 11:55 PM |
Here are some protocol details found by inspecting data and guessing:
Commands sent from master (first byte):
0x05 - Status update (no checksum, no zone info)
0x27 - Status update (extended version of the above, with checksum)
Second byte:
100EBMAR (LEDs: E=Error, B=Bypass, M=Memory, A=Armed, R=Ready)
Third byte:
text message code (0x01=Enter code, 0x03=Close all sections, 0x11=System armed ...)
Fourth byte:
always 0x01
Fifth byte:
always 0x81
Sixth byte:
Open zones 1-8
0xA5 - Time
(Offset is in bits starting with 0 including 1 bit zero-padding after 8 bit command)
Offset Length Data
9 4 Year digit 3
13 4 Year digit 4
19 4 Month
23 5 Day
28 5 Hour
33 6 Minute
0x11 - Query available keypads (no checksum)
Each keypad in slot 1-8 will respond with two zeros if present.
i.e. the response bits are:
aabbccddd ...
a = Keypad in slot 1 present
b = Keypad in slot 2 present
For example:
11110011 ... (Keypad in slot 3 present)
0x0A - Status in menu mode
0xC3 - no idea
0x16 - no idea
0x1C - emergency button acknowledge?
0x5D - alarm memory?
0xB1 - zone configuration?
0x64 - beep command
second byte:
0x06 - 3 short beeps
0x0a - 4 short beeps
0x0c - long beep
Response commands sent by keypads:
0xBB - Fire emergency button pressed
0xDD - Assistant emergency button pressed
0xEE - Police emergency button pressed
Second byte of the response is the pressed key:
xxxxxxcc (x = key, c = checksum)
Code for verifying checksum of the key:
unsigned int l_Key = p_Packet.m_Bytes[1] >> 2;
unsigned int l_ChkSum = p_Packet.m_Bytes[1] & 0x03;
bool l_bChkSumOk = ((((l_Key >> 4) & 0x03) + ((l_Key >> 2) & 0x03) + (l_Key & 0x03)) & 0x03) == l_ChkSum; |
Posted: Oct 31, 2012 - 11:31 PM |
MrBoard, what you posted until now has been true for me, and I want to share. I got and arduino sketch working to try to decipher the code. It works, but not for all possibilities. Code 0x5 works, and is being sent every second or so. Reading the info goes as follows:
Wait for a long HIGH clk signal. Then read data on every clk rise until message is finished.
I get data that seems really good, but I'm missing details. If somebody has more detail on how to interpret the data, I'll be really happy to know
Code is here:
#define CLK 11
#define DTA 12
String st;
String msg;
long ledActivity;
void setup()
pinMode(CLK,INPUT);
pinMode(DTA,INPUT);
pinMode(13,OUTPUT);
Serial.begin(9600);
Serial.println("Start");
void loop()
// Display led if no activity. Detect activity on bus
if (millis() - ledActivity > 1000) digitalWrite(13,0); else digitalWrite(13,1);
if (waitCLKchange(1) > 200)
// Message start detected
st = "";
msg = "";
while (1)
// CLK is low. Let's wait until it goes up, max 500 usec.
if (waitCLKchange(0) > 50) break;
// CLK is high. Read a bit
delayMicroseconds(100);
if (digitalRead(DTA)) st += "1"; else st += "0";
// Wait for CLK to drop again
if (waitCLKchange(1) > 50) break;
// Get command number
int cmd = getBinaryData(st,0,8);
// Command 5 is status from panel. If we got a status, we got activity. Reset counter for inactvity for the LED
if (cmd == 5 || cmd == 0x27) ledActivity = millis();
if (cmd == 5)
int zones = getBinaryData(st,9+8+8+8,8);
msg += "Zones " + String(zones);
// Interpret the TIME broadcast
if (cmd == 165)
int year3 = getBinaryData(st,9,4);
int year4 = getBinaryData(st,13,4);
int month = getBinaryData(st,19,4);
int day = getBinaryData(st,23,5);
int hour = getBinaryData(st,28,5);
int minute = getBinaryData(st,33,6);
msg += "Date: 20" + String(year3) + String(year4) + " " + String(month) + " " + String(day) + " " + String(hour) + ":" + String(minute);
// Send findings to USB port
if (cmd != 0 && st != "00000101010000001000000010000000011000111000000001100011100000000110001111")
Serial.print(st);
Serial.print(" ");
Serial.print(cmd);
Serial.print(" ");
Serial.print(msg);
Serial.println("");
int waitCLKchange(int currentState)
int c = 0;
while (digitalRead(CLK) == currentState)
delayMicroseconds(10);
c++;
if (c > 1000) break;
return c;
int getBinaryData(String st, int offset, int length)
int buf = 0;
for(int j=0;j<length;j++)
buf <<= 1;
if (st[offset+j] == '1') buf |= 1;
return buf;
Posted: Nov 01, 2012 - 02:30 AM |
I can also confirm that my PC1616 DSC panel sends data on the CLK line going UP (HIGH), and that the keypads respond on the CLK line going down.
Here is a sample of data coming from the panel.
00000101 0 10000000 00000011 00000000 11000111 00000000 11000111 00000000 11000111 1 zone 3
00000101 0 10000001 00000010 00000000 11000111 00000000 11000111 00000000 11000111 1 zone 2
00000101 0 10000000 00000011 00000000 11000111 00000000 11000111 00000000 11000111 1 zone 4
00000101 0 10000001 00000010 00000000 11000111 00000000 11000111 00000000 11000111 1 zone 1
00000101 0 10000001 00000001 00000000 11000111 00000000 11000111 00000000 11000111 1 no zone
00000101 0 10000011 00001000 00000000 11000111 00000000 11000111 00000000 11000111 1 arm delay
00000101 0 10000011 00001000 00000000 11000111 00000000 11000111 00000000 11000111 1 arm delay short beeps
00000101 0 10000010 00000101 00000000 11000111 00000000 11000111 00000000 11000111 1 armed
For the life of me, the "normal no zone trespassed" string I've verified many times, but I can't understand why I don't see zeros for the third group of bits.
If someone smarter than me figures it out, I'll be happy to know where I'm wrong. |
Posted: Nov 01, 2012 - 02:22 PM |
| Amazing freaks have about everything figured out! |
_________________ Discursive design,
Torby
Posted: Nov 16, 2012 - 02:41 PM |
Here is the circuit I built to connect the arduino to the DSC Keybus:
Then, here is the Arduino code. Completely rewritten to use interrupt on pin 2 (interrupt 0), because otherwise it seems too slow to be able to receive all messages
#define CLK 2
#define DTA 4
String st, old;
unsigned long lastData;
void setup()
pinMode(CLK,INPUT);
pinMode(DTA,INPUT);
pinMode(13,OUTPUT);
Serial.begin(57600);
// Interrupt 0 = PIN 2 externe
attachInterrupt(0,clkCalled,RISING);
void loop()
if (millis() - lastData > 500)
digitalWrite(13,0);
digitalWrite(13,1);
if (waitCLKchange(1) < 2000) return;
String stc = st;
st = "";
int cmd = getBinaryData(stc,0,8);
if (cmd == 0x05) lastData = millis(); // Reset led counter
if (stc == old) return;
if (cmd == 0) return;
old = stc;
String msg;
// Interpreter les donnees
if (cmd == 0x05)
if (getBinaryData(stc,12,1)) msg += "Error";
if (getBinaryData(stc,13,1)) msg += "Bypass";
if (getBinaryData(stc,14,1)) msg += "Memory";
if (getBinaryData(stc,15,1)) msg += "Armed";
if (getBinaryData(stc,16,1)) msg += "Ready";
if (cmd == 0xa5)
int year3 = getBinaryData(stc,9,4);
int year4 = getBinaryData(stc,13,4);
int month = getBinaryData(stc,19,4);
int day = getBinaryData(stc,23,5);
int hour = getBinaryData(stc,28,5);
int minute = getBinaryData(stc,33,6);
msg += "Date: 20" + String(year3) + String(year4) + "-" + String(month) + "-" + String(day) + " " + String(hour) + ":" + String(minute);
if (cmd == 0x27)
msg += "Zones: ";
int zones = getBinaryData(stc,8+1+8+8+8+8,8);
if (zones & 1) msg += "1";
if (zones & 2) msg += "2";
if (zones & 4) msg += "3";
if (zones & 8) msg += "4";
if (zones & 16) msg += "5";
if (zones & 32) msg += "6";
if (zones & 64) msg += "7";
if (zones & 128) msg += "8";
Serial.print(formatDisplay(stc));
Serial.print("-> ");
Serial.print(cmd,HEX);
Serial.print(":");
Serial.println(msg);
void clkCalled()
if (st.length() > 200) return; // Do not overflow the arduino's little ram
unsigned long waitCLKchange(int currentState)
unsigned long c = 0;
c += 10;
if (c > 10000) break;
return c;
String formatDisplay(String st)
String res;
res = st.substring(0,8) + " " + st.substring(8,9) + " ";
int grps = (st.length() - 9) / 8;
for(int i=0;i<grps;i++)
res += st.substring(9+(i*8),9+((i+1)*8)) + " ";
res += st.substring((grps*8)+9,st.length());
return res;
unsigned int getBinaryData(String st, int offset, int length)
int buf = 0;
buf <<= 1;
return buf;
This way, I get codes 0x05, 0x27 0xa5 and others. Seems to work well. The code is not complete though, because I still need to make events happen (for example, disconnect the battery) and find out how to identify these events from the data the DSC spits out.
If somebody was to redo this, please share information about what you get out of it, I'd be really interested. |
Posted: Dec 06, 2012 - 05:13 AM |
Thanks for your code, riviera65, I'm using it to decode my own DSC unit, I think I have discovered some new information. I want to know which Access code arms and disarms, and I believe the information is encoded on the 0xA5 time/status line. Following the time are two zero bits, then bits 41-48 seem to indicate whether a system is being armed or disarmed, and by whom. Bits 41&42 are 0x02 for arming, and 0x03 for disarming. Subtracting 0x99 from the arming code and 0xC0 from the disarm code reveal the Access code (01..32, and master code 40 is represented as following duress code 34). Some examples, the first line is the entire string, the following are just the 8 bits pointed at:
10100101 1 0001 0010 01 1100 00010 00010 010101 00 10011001 11111111 01010101 1
0xA5:Date:2012-12-2 2:21 ^^^^^^^^
10011001 is arming, user code 01
11000000 is disarming, user code 01
10100000 is arming, user code 01
11000111 is disarming, user code 08
10111011 is arming, master code (i.e. "35")
11100010 is disarming, master code (i.e. "35")
8 bits of ones follow a user code, plus another 8 bits unless it's a master code. Both sequences are then followed by a single bit (usually 1). I haven't been able to decode the last full byte for a user code (preceding the 1 bit).
Can anyone duplicate these findings? |
Posted: Dec 09, 2012 - 09:08 PM |
Hi Arduino_rich,
I reproduced your idea on my system.
DDDDDDDD DDDDDDDDDDDDDDDDDDDDA
a5:00010010011011101101000111101110100110110000000001111111 ARM user 0
a5:00010010011011101101001000011010100110110000000010101100 ARM user 1
a5:00010010011011101101001000001110100110110000000010100000 ARM user 2
a5:00010010011011101101001000100010100110110000000010110100 ARM user 40
a5:00010010011011101101001000001100110000000000000011000011 DISARM user 1
a5:00010010011011101101001000000000110000010000000010111000 DISARM user 2
a5:00010010011011101101001000100000111000100000000011111001 DISARM user 40
In this data, these are the a5 packets I received for different events. The first line identifies with the D which bits are used for Date and time (this I'm sure), The A is probably the Armed status (not completely sure yet). But, for the remaining bits (the last eight), I can't say I'm sure I get the same thing you do, and I'm not able to get the user number from those. Maybe you can? I'm still trying to make sense out of it though. I'll post other details if I finally get the enlightenment...
Edit: Please disregard this example, I think I did not take the right A5 message, since when I arm the system, I get one first A5 message when the code is entered, and then another one when the exit delay has expired and the system is really armed. This is the second A5 that I displayed in the example above, and the first one seems better. Here is the first one:
a5:00010010011011101101000111101100101111110000000010100001 BEFORE ARM user 0
a5:00010010011011101101001000011000100110010000000010101000 BEFORE ARM user 1
a5:00010010011011101101001000001100100110100000000010011101 BEFORE ARM user 2
a5:00010010011011101101001000100000101110110000000011010010 BEFORE ARM user 40
Posted: Dec 09, 2012 - 09:52 PM |
More info found.
DDDDDDDDPPDDDDDDDDDDDDDDDDDDDDA UUUUUU
DDDDDDDDPPDDDDDDDDDDDDDDDDDDDDA B
a5:00010010001011101101001010100000111001111111111100111101 Battery disconnect
a5:00010010001011101101001010101100111011111111111101010001 Battery reconnect
In this data, I think I identified by PP the partition number. When this number is partition 1, we get a user (U section) in this weird encoding that I still have to figure out (I know you did, but I'm still stumped)
If we get partition 0, then the information is not a user but an error status (see how the B byte could be battery error, I'll have to get more data)
The hunt continues...  |
Posted: Dec 10, 2012 - 11:17 AM |
From what I know about this protcol peimar led lights so far the clock line runs at 1kHz with 50% duty and oddly enough only does so for 41.6ms then it stays high for 5.4ms and starts all over again. The data line seems to transistion on either the falling or rising edge of the clock (or in the middle), which led Kortuk of chiphacker.com to belive that it is NRZ encoding which I'm not sure of yet but here are some OLS dumps of the data and clock lines hopefully with teamwork we can figure this out.
DSC OLS Dump
ECP Patent
PC5401 Dev-PDF
I have used system many a times but never tried to learn the protocol |
Posted: Dec 10, 2012 - 06:33 PM |
Here are some code changes to the Nov 16, 2012 - 03:41 PM post which should help with the user codes,
Add this to the end of the "if (cmd == 0xa5)" section:
int arm = getBinaryData(stc,41,2);
int master = getBinaryData(stc,43,1);
int user = getBinaryData(stc,43,6); // 0-36
if (arm == 0x02) {
msg += " armed";
user = user - 0x19;
if (arm == 0x03) {
msg += " disarmed";
if (arm > 0) {
if (master) msg += " master code"; else msg += " user";
user += 1; // shift to 1-32, 33, 34
if (user > 34) user += 5; // convert to system code 40, 41, 42
msg += " " + String(user);
The 0xa5 armed message is received after the exit delay when the system switches off ready to armed. The disarm message is received immediately upon disarming. On my system I receive a date message every four minutes regardless of arming/disarming, so disregard that one for this user information. I think your "A" bit should be two bits long and is two bits later than your code sample. Note that it is followed by 8 zeros and then another 8-bit message which I can't determine. Also make sure your user codes are unique, if you post the same 4 digit pin for two user codes I believe it only finds the first one.
add this to the "if (cmd == 0x05)" section for a possible power fail indicator:
if (getBinaryData(stc,28,1)) msg += "power fail? ";
Posted: Jan 14, 2013 - 05:09 PM |
Hi guys,
This is really great information. I've always wanted to interface with the Keybus protocol.
Some questions:
Do you know if the alarm is always the "master" and keypads are slaves?
When do slaves talk in the bus?
Jose |
Posted: Mar 16, 2013 - 06:45 AM |
| How can I write TO keybus? How to simulate a keypad sending keystrokes to the panel? |
Posted: Apr 28, 2013 - 02:07 PM |
Hi,my name is Federico. i have an Logic Analizer Tektronix TLA704 in order to help in the proyect.
me i captured some frames the CLK and DATA for sharing.
follow in the proyect?
Thanks and I am at your disposal. |
Posted: May 07, 2013 - 08:51 PM |
Posted: May 11, 2013 - 08:46 AM |
Nice info ..
But there is no source .... Only a hex
Would you by any "chance" be related to "This guy" .....
Your username is jpessini and http://www.juliano.com.br/ refers to a Juliano Zabero Pessini
If you are .. you might ask your "relative" to release the sourcecode
/Bingo |
Posted: May 22, 2013 - 09:56 PM |
| hello! I am also studying the bus DSC 5010, and I can not understand the purpose of the last bit in the package ..I want to use the keyboard in my project. So far only got to control LED ARM READY |
Posted: May 23, 2013 - 03:25 PM |
With the help of a synthesizer package I learned the purpose of each status bit
7- BACKLIGHT
6- FIRE
5- PROGRAM
4- TROUBLE
3- Bypass
2- Memory
1- Armed
0- Ready |
Posted: May 24, 2013 - 09:29 AM |
0x27 - Status update zone 1-8
0x2D - Status update zone 9-16
0x5D - alarm memory group1
0x63 - alarm memory group2
0xB1 - zone configuration, next byte allowed zone
0x64 - beep command group1
0x69 - beep command group2 |
Posted: Jun 14, 2013 - 10:08 AM |
| Most people would choose the LED lights for cars or also house decoration. So do I. After all, the LED car lights are getting more and more available and affordable in the cars and motors and would make your cars look greater. |
