Posted: Jul 04, 2010 - 12:40 AM |
Hi, I'm trying to build a 16-bit word made up from three integer variables; address, control (both in range 0x00-0x03), and data (0x00-0xFF).
The most significant four bits of the word are irrelevant, the next two hold the address, the next two the control information, and the final 8 hold the data.
Will something like this allow me to contruct the word from these variables?
word = (address<<10) | (control<<8) | data
Posted: Jul 04, 2010 - 01:15 AM |
Have you tried it out? (For this kind of stuff the simulator in AVR Studio is excellent.)
But yes, that looks reasonable. |
Posted: Jul 04, 2010 - 04:57 AM |
Or you could do this:
typefef struct
unsigned int data :8;
unsigned int control :2;
unsigned int address :2;
} whateverYouWantToCallIt;
or:
typefef struct
unsigned int :4; //4 bits of fiiler
depending on endianness.
whateverYouWantToCallIt word;
word.address = address;
word.control = control;
word.data = data;
Posted: Jul 21, 2010 - 04:47 AM |
This one doesnot make sense to me,
To set bit 0 in foo and then store the result back into foo:
foo = foo | 0x01;
bit OR"|" with 0x01, we will set bit 1 in foo,,
why is it to set bit 0?
I am a newbie, forgive me if i am wrong. please explain it to me. |
Posted: Jul 21, 2010 - 09:16 AM |
| [Removed as I totally mis-understood the post above. Snigelen nailed the correct interpretation and answer below.] |
Posted: Jul 21, 2010 - 09:55 AM |
foo = foo | 0x01;
This is because bits in a byte are usually numbered from 0 to 7. So the first bit is number 0. |
Posted: Jul 21, 2010 - 10:53 AM |
Just to add a little more to that:
bit shift mask
0 (1<<0) = 0x01
1 (1<<1) = 0x02
2 (1<<2) = 0x04
3 (1<<3) = 0x08
4 (1<<4) = 0x10
5 (1<<5) = 0x20
6 (1<<6) = 0x40
7 (1<<7) = 0x80
Posted: Jul 24, 2010 - 10:22 AM |
| That was useful , Thanks . |
Posted: Jan 09, 2011 - 02:01 AM |
| Thanks!, i was looking for this information. |
Posted: Mar 02, 2011 - 01:27 PM |
how should i access the registers R0-R32? using c programming.
Just give me an example..
Thank you |
Posted: Mar 02, 2011 - 01:32 PM |
You don't - the point of C is that you don't need to directly access the CPU temporary registers. They are handled by the compiler in order to implement your code.
The I/O and peripheral registers (like the timer control registers) are manipulated by you, but not the CPU scratch registers.
Posted: Mar 02, 2011 - 02:12 PM |
To illustrate what Dean has said consider this program:
uint8_t mask = 0x55;
DDRB = 0xFF;
PORTB ^= mask;
if (PIND & 1<<PD0) {
mask ^= 0xFF;
when built by the compiler it generates:
00000080 <main>:
DDRB = 0xFF;
80: 8f ef ldi r24, 0xFF ; 255
82: 84 b9 out 0x04, r24 ; 4
84: 85 e5 ldi r24, 0x55 ; 85
DDRB = 0xFF;
PORTB ^= mask;
86: 95 b1 in r25, 0x05 ; 5
88: 98 27 eor r25, r24
8a: 95 b9 out 0x05, r25 ; 5
8c: 48 9b sbis 0x09, 0 ; 9
8e: fb cf rjmp .-10 ; 0x86 <main+0x6>
mask ^= 0xFF;
90: 80 95 com r24
92: f9 cf rjmp .-14 ; 0x86 <main+0x6>
In this code the compiler initially uses R24 to output 0xFF to DDRB. It then reuses R24 as 'mask' and initialises it to be 0x55. It reads PORTB into R25 then exclusive-or's this with 'mask' (R24). It then checks bit 0 of PIND and if that is set it complements the contents of 'mask' (so 0x55 switches to 0xAA).
You, the programmer, need never be aware which registers the compiler has chosen to put values or variables into. |
Posted: Mar 30, 2011 - 06:51 PM |
What this program does not work help me
// Project: Analog Comparator example
// Author: winavr.scienceprog.com
// Module description: Analog comparator example with positive comparator
// input connected to Vref 1.23V. When compared voltage exceed 1.23V LED lighst on.
// When voltage drops bellow - LED turns OFF. Comparator inputis connected to ADC3 pin.
#include <avr\io.h>
#include <avr\interrupt.h>
#define AINpin PA3
#define LED PD0
void Init(){
DDRA&=~(1<<AINpin);//as input
PORTA&=~(1<<AINpin);//no Pull-up
DDRD|=(1<<LED); //Led pin as output
PORTD|=(1<<LED);//Initally LED is OFF
SFIOR|=(1<<ACME);//enable multiplexer
ADCSRA&=~(1<<ADEN);//make sure ADC is OFF
ADMUX|=(0<<MUX2)|(1<<MUX1)|(1<<MUX0); //select ADC3 as negative AIN
ACSR|=
(0<<ACD)| //Comparator ON
(1<<ACBG)| //Connect 1.23V reference to AIN0
(1<<ACIE)| //Comparator Interrupt enable
(0<<ACIC)| //input capture disabled
(0<<ACIS1)| //set interrupt on output toggle
(0<<ACIS0);
sei();//enable global interrupts
// Interrupt handler for ANA_COMP_vect
ISR(ANA_COMP_vect) {
if bit_is_clear(ACSR, ACO)
PORTD&=~(1<<LED);//LED is ON
else PORTD|=(1<<LED);//LED is OFF
// Main program
Init();
while(1) { // Infinite loop; interrupts do the rest
Posted: Mar 30, 2011 - 07:54 PM |
ghost800,
How does your post extend the discussion of the article in the first post of this thread?
Moderator. |
Posted: Mar 30, 2011 - 09:10 PM |
Cliff!
When those post totally unrelated to the thread occur I think we should tossin an explanation of the difference between the "new topic" and the "new reply" buttons. I have a feeling that the distinction is not clear for many newcomers, or thet they even do not see the buttons and think that the only way to post on the forum is the "Quick Reply" area.
ghost800!
If you want to start a discussion on a new topic, use the "new topic" button at the top or bottom thread pages and forum listings here at AVRfreaks. Each discussion should commence in a separate "thread" (topic) or things become very confused and out of order. When creating a new thread please take the time to think out a really smart title (subject) so that it reflects the content of your post (extremely bad subjects are things like "Help!", "Why does my code not work" etc).
Hope this helps! |
Posted: Apr 01, 2011 - 07:27 AM |
can the macros be used with ports?
for eg
int totalcomplete()
int retval;
if ((bit_get(PORTC, BIT(1))) && (bit_get(PORTC, BIT(0)))==0)
retval = 1;
else retval = 0;
return retval;
Posted: Apr 01, 2011 - 10:33 AM |
I'm curious. What would make you want to type:
when you could have typed:
if ((PORTC & 3) == 0)
Do the tortuous macros really help?
(BTW do you mean to read PORTC or PINC?) |
Posted: Apr 01, 2011 - 08:15 PM |
| thanks! ya my mistake it should have been PINC .sorry but am new to programming an ya thanks i guess i could use
but what i meant was does this macro
#define bit_get(p,m) ((p) & (m))
work when a pin is specified in place of variable p. Or do we have to use macro such as
#define READ(port,pin) ((PIN ## port & (1<<pin))
Posted: Apr 01, 2011 - 08:44 PM |
| Yes and my question is why obfuscate code with layers of macros when the plain C to achieve the same would actually be simpler. There seems to be a recent trend to try and wrap code in N levels of macro at the drop of a hat. As someone who has to read/maintain other programmers code I find that it very rarely aids the mainatainability/readability of the code but instead just makes it more difficult to follow. Perhaps you can explain what how your bit_get() macro makes the code easier to follow. ALL programmers know what an AND operation is! |
Posted: Apr 01, 2011 - 09:02 PM |
| thanks, and well as u said it will be simpler to use plain c but the reason is that, i am working on a project and the panel where i have to present it to has a few members who have well little or no knowledge of programming so i am hoping the macros will help in making them understand more easily. |
