No, no 64 bit here. Care to look at the output of strace?
/opt$ strace $(find /opt/atmel/as4e-ide -name "avr32gdbproxy") --simulate uc3a3256
execve("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/bin/avr32gdbproxy", ["/opt/atmel/as4e-ide/plugins/com."..., "--simulate", "uc3a3256"], [/* 39 vars */]) = 0
uname({sys="Linux", node="linux-devel1", ...}) = 0
brk(0) = 0x8f0b000
brk(0x8f0bcd0) = 0x8f0bcd0
set_thread_area({entry_number:-1 -> 6, base_addr:0x8f0b850, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
set_tid_address(0x8f0b898) = 3585
set_robust_list(0x8f0b8a0, 0xc) = 0
futex(0xbfbd9828, FUTEX_WAKE_PRIVATE, 1) = 0
rt_sigaction(SIGRTMIN, {0x83b7930, [], SA_SIGINFO}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x83b7870, [], SA_RESTART|SA_SIGINFO}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
brk(0x8f2ccd0) = 0x8f2ccd0
brk(0x8f2d000) = 0x8f2d000
futex(0x85d7f7c, FUTEX_WAKE_PRIVATE, 2147483647) = 0
rt_sigaction(SIGINT, {0x80486b0, [INT], SA_RESTART}, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGSEGV, {0x80486b0, [SEGV], SA_RESTART}, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGTERM, {0x80486b0, [TERM], SA_RESTART}, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGQUIT, {0x80486b0, [QUIT], SA_RESTART}, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGHUP, {0x80486b0, [HUP], SA_RESTART}, {SIG_DFL, [], 0}, 8) = 0
write(2, "Warning: running simulator but n"..., 61Warning: running simulator but no executable file specified.
) = 61
time(NULL) = 1295532616
open("/tmp/tmpfile_1295532616", O_RDWR|O_CREAT|O_TRUNC, 0666) = 3
readlink("/proc/3585/exe", "/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/bin/avr32gdbproxy"..., 200) = 111
stat64("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
mmap2(NULL, 2101248, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x110000
mmap2(NULL, 2101248, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x311000
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY|O_CLOEXEC) = 4
fstat64(4, {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
fcntl64(4, F_GETFD) = 0x1 (flags FD_CLOEXEC)
getdents(4, /* 53 entries */, 4096) = 1360
getdents(4, /* 0 entries */, 4096) = 0
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3l064revb.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3l064revb.xml", O_RDONLY) = 4
mmap2(NULL, 167936, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x704000
fstat64(4, {st_mode=S_IFREG|0664, st_size=1683, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x512000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1683
read(4, "", 45056) = 0
read(4, "", 49152) = 0
close(4) = 0
munmap(0x512000, 4096) = 0
munmap(0x704000, 167936) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3l064.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3l064.xml", O_RDONLY) = 4
brk(0x8f6d000) = 0x8f6d000
fstat64(4, {st_mode=S_IFREG|0664, st_size=1681, ...}) = 0
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1681
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3l032.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3l032.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=1677, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x83e000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1677
close(4) = 0
munmap(0x83e000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3l016.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3l016.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=1673, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xc30000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1673
close(4) = 0
munmap(0xc30000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c264c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c264c.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=1997, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x873000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1997
close(4) = 0
munmap(0x873000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c2512crevc.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c2512crevc.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=2122, ...}) = 0
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 2122
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c2512c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c2512c.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=2028, ...}) = 0
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 2028
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c2256c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c2256c.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=1998, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x584000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1998
close(4) = 0
munmap(0x584000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c2128c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c2128c.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xba1000
close(4) = 0
munmap(0xba1000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c164c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c164c.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xa6d000
close(4) = 0
munmap(0xa6d000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c1512crevc.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c1512crevc.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xe6e000
close(4) = 0
munmap(0xe6e000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c1512c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c1512c.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x860000
close(4) = 0
munmap(0x860000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c1256c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c1256c.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x919000
close(4) = 0
munmap(0x919000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c1128c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c1128c.xml", O_RDONLY) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c064c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c064c.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=2421, ...}) = 0
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 2421
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c0512crevc.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c0512crevc.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=2546, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6c9000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 2546
close(4) = 0
munmap(0x6c9000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c0512c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c0512c.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=2452, ...}) = 0
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 2452
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c0256c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c0256c.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=2422, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb40000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 2422
close(4) = 0
munmap(0xb40000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c0128c.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3c0128c.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7da000
close(4) = 0
munmap(0x7da000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b164.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b164.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=1582, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xd0a000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1582
close(4) = 0
munmap(0xd0a000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b1512revc.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b1512revc.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=1625, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xac5000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1625
close(4) = 0
munmap(0xac5000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b1512.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b1512.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=1614, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x83f000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1614
close(4) = 0
munmap(0x83f000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b1256es.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b1256es.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=1593, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xd82000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1593
close(4) = 0
munmap(0xd82000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b1256.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b1256.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=1613, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xbe0000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1613
close(4) = 0
munmap(0xbe0000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b1128.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b1128.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=1583, ...}) = 0
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1583
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b064.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b064.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x849000
close(4) = 0
munmap(0x849000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b0512revc.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b0512revc.xml", O_RDONLY) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b0512.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b0512.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xe0b000
close(4) = 0
munmap(0xe0b000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b0256es.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b0256es.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xe3a000
close(4) = 0
munmap(0xe3a000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b0256.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b0256.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x9d5000
close(4) = 0
munmap(0x9d5000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b0128.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3b0128.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xfbb000
close(4) = 0
munmap(0xfbb000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3a364s.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3a364s.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=2263, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xd68000
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 2263
close(4) = 0
munmap(0xd68000, 4096) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3a364.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3a364.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=2262, ...}) = 0
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 2262
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3a3256s.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3a3256s.xml", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0664, st_size=2264, ...}) = 0
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 2264
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3a3256.xml", O_RDONLY|O_LARGEFILE) = 4
close(4) = 0
open("/opt/atmel/as4e-ide/plugins/com.atmel.avr.utilities.linux.x86_3.0.0.201009140848/os/linux/x86/share/avr32/uc3a3256.xml", O_RDONLY) = 4
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6a3000
close(4) = 0
munmap(0x6a3000, 4096) = 0
mmap2(NULL, 266240, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xba0000
socket(PF_INET, SOCK_STREAM, IPPROTO_IP) = 4
fcntl64(4, F_GETFL) = 0x2 (flags O_RDWR)
fcntl64(4, F_SETFL, O_RDWR|O_NONBLOCK) = 0
setsockopt(4, SOL_SOCKET, SO_REUSEADDR, [-1078094068], 4) = 0
setsockopt(4, SOL_SOCKET, SO_KEEPALIVE, [-1078094068], 4) = 0
bind(4, {sa_family=AF_INET, sin_port=htons(4711), sin_addr=inet_addr("0.0.0.0")}, 16) = 0
open("/etc/nsswitch.conf", O_RDONLY) = 5
fstat64(5, {st_mode=S_IFREG|0644, st_size=475, ...}) = 0
read(5, "# /etc/nsswitch.conf\n#\n# Example"..., 4096) = 475
read(5, "", 4096) = 0
close(5) = 0
open("/etc/ld.so.cache", O_RDONLY) = 5
fstat64(5, {st_mode=S_IFREG|0644, st_size=123341, ...}) = 0
mmap2(NULL, 123341, PROT_READ, MAP_PRIVATE, 5, 0) = 0x652000
close(5) = 0
open("/lib/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib", {st_mode=S_IFDIR|0755, st_size=20480, ...}) = 0
open("/usr/lib/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib", {st_mode=S_IFDIR|0755, st_size=139264, ...}) = 0
munmap(0x652000, 123341) = 0
mmap2(NULL, 123341, PROT_READ, MAP_PRIVATE, 5, 0) = 0x8a0000
close(5) = 0
open("/lib/libnss_files.so.2", O_RDONLY) = 5
read(5, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0 \32\0\0004\0\0\0"..., 512) = 512
fstat64(5, {st_mode=S_IFREG|0644, st_size=42572, ...}) = 0
mmap2(NULL, 45772, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0xe7d000
mmap2(0xe87000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0x9) = 0xe87000
close(5) = 0
open("/lib/libc.so.6", O_RDONLY) = 5
read(5, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0@n\1\0004\0\0\0"..., 512) = 512
fstat64(5, {st_mode=S_IFREG|0755, st_size=1421892, ...}) = 0
mmap2(NULL, 1427880, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0x512000
mmap2(0x669000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0x157) = 0x669000
mmap2(0x66c000, 10664, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x66c000
close(5) = 0
open("/lib/ld-linux.so.2", O_RDONLY) = 5
read(5, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0P\10\0\0004\0\0\0"..., 512) = 512
fstat64(5, {st_mode=S_IFREG|0755, st_size=118084, ...}) = 0
mmap2(NULL, 121112, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0x818000
mmap2(0x834000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0x1b) = 0x834000
close(5) = 0
mprotect(0x834000, 4096, PROT_READ) = 0
mprotect(0x669000, 8192, PROT_READ) = 0
mprotect(0xe87000, 4096, PROT_READ) = 0
munmap(0x8a0000, 123341) = 0
mmap2(NULL, 1048576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x66f000
open("/etc/protocols", O_RDONLY|O_CLOEXEC) = 5
fcntl64(5, F_GETFD) = 0x1 (flags FD_CLOEXEC)
fstat64(5, {st_mode=S_IFREG|0644, st_size=2626, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xcd7000
read(5, "# Internet (IP) protocols\n#\n# Up"..., 4096) = 2626
writev(2, [{"avr32gdbproxy", 13}, {": ", 2}, {"relocation error", 16}, {": ", 2}, {"/lib/libnss_files.so.2", 22}, {": ", 2}, {"symbol strcmp, version GLIBC_2.0"..., 87}, {"", 0}, {"", 0}, {"\n", 1}], 10avr32gdbproxy: relocation error: /lib/libnss_files.so.2: symbol strcmp, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
) = 145
exit_group(127) = ?
