Posted: May 30, 2010 - 06:23 PM |
Hi Alex
Just found your posting here - for some reason the avrfreaks search engine doesn't find this even when searching for the title.
Again thankyou thankyou for releasing Xboot.
To summarize out emails so far, I'm trying it on the X32A4 and it is programming it somewhere and then failing on the verify step.
It seems to me it might be something to do with the avrdude 5.10 released avrdude.conf
A couple of issues that show up
1) The X32A4 doesn't support JTAG
2) The A4 doc8069 rev N Table7-2 Pg14 has some thing wrong in Page Size for the 32A4 or the 64A4. Both specify Page Size 128Words and number of pages 128. Seems likely the spec for the 64A4 is wrong.
When I compare it against the M2560 that I've also used, there is a lot more customizations in the avrdude.conf - which I haven't researched to find out what they mean
So ANY pointers on what might be wrong greatly appreaciated. I'm going to dig into the where it might be placing the code and what avrdude docs says about the .conf settings.
Neil
# ATXMEGA32A4
part
id = "x32a4";
desc = "ATXMEGA32A4";
signature = 0x1e 0x95 0x41;
has_jtag = yes;
has_pdi = yes;
nvm_base = 0x01c0;
memory "eeprom"
size = 0x0400;
offset = 0x08c0000;
page_size = 0x20;
readsize = 0x100;
memory "application"
size = 0x00008000;
offset = 0x0800000;
page_size = 0x100;
readsize = 0x100;
memory "apptable"
size = 0x00001000;
offset = 0x00807000;
page_size = 0x100;
readsize = 0x100;
memory "boot"
size = 0x00001000;
offset = 0x00808000;
page_size = 0x100;
readsize = 0x100;
memory "flash"
size = 0x00009000;
offset = 0x0800000;
page_size = 0x100;
readsize = 0x100;
memory "prodsig"
size = 0x200;
offset = 0x8e0200;
page_size = 0x100;
readsize = 0x100;
memory "usersig"
size = 0x200;
offset = 0x8e0400;
page_size = 0x100;
readsize = 0x100;
memory "signature"
size = 3;
offset = 0x1000090;
memory "fuse0"
size = 1;
offset = 0x8f0020;
memory "fuse1"
size = 1;
offset = 0x8f0021;
memory "fuse2"
size = 1;
offset = 0x8f0022;
memory "fuse4"
size = 1;
offset = 0x8f0024;
memory "fuse5"
size = 1;
offset = 0x8f0025;
memory "lock"
size = 1;
offset = 0x8f0027;
and I use
avrdude -v -v -c avr109 -p x32a4 -b 19200 -P com15 -U flash:w:B014BrdTestA.hex
with the output
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf"
Using Port : com15
Using Programmer : avr109
avr910_devcode (avrdude.conf) : none
Overriding Baud Rate : 19200
AVR Part : ATXMEGA32A4
Chip Erase delay : 0 us
PAGEL : P00
BS2 : P00
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 0
StabDelay : 0
CmdexeDelay : 0
SyncLoops : 0
ByteDelay : 0
PollIndex : 0
PollValue : 0x00
Memory Detail :
Block Poll Page Polle
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBac
eeprom 0 0 0 0 no 1024 32 0 0 0 0x00 0x0
application 0 0 0 0 no 32768 256 0 0 0 0x00 0x0
apptable 0 0 0 0 no 4096 256 0 0 0 0x00 0x0
boot 0 0 0 0 no 4096 256 0 0 0 0x00 0x0
flash 0 0 0 0 no 36864 256 0 0 0 0x00 0x0
prodsig 0 0 0 0 no 512 256 0 0 0 0x00 0x0
usersig 0 0 0 0 no 512 256 0 0 0 0x00 0x0
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x0
fuse0 0 0 0 0 no 1 0 0 0 0 0x00 0x0
fuse1 0 0 0 0 no 1 0 0 0 0 0x00 0x0
fuse2 0 0 0 0 no 1 0 0 0 0 0x00 0x0
fuse4 0 0 0 0 no 1 0 0 0 0 0x00 0x0
fuse5 0 0 0 0 no 1 0 0 0 0 0x00 0x0
lock 0 0 0 0 no 1 0 0 0 0 0x00 0x0
Programmer Type : avr910
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "XBoot++"; type = S
Software Version = 1.6; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=256 bytes.
Programmer supports the following devices:
Device code: 0x7b
avrdude: devcode selected: 0x7b
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9541
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "B014BrdTestA.hex"
avrdude: input file B014BrdTestA.hex auto detected as Intel Hex
avrdude: writing flash (1798 bytes):
Writing | ################################################## | 100% 1.05s
avrdude: 1798 bytes of flash written
avrdude: verifying flash memory against B014BrdTestA.hex:
avrdude: load data flash data from input file B014BrdTestA.hex:
avrdude: input file B014BrdTestA.hex contains 1798 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1.14s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0002
0xf4 != 0xbc
avrdude: verification error; content mismatch
avrdude done. Thank you.
Posted: May 30, 2010 - 08:19 PM |
Hm. I have it working perfectly on a 32a4 with no extra customizations, so that's a little fishy. And it looks like we're using the same avrdude.conf file. How did you program the bootloader to the chip? With make program?
Btw, this is the output I get when I program a 32a4 with XBoot:
avrdude -p atxmega32a4 -P /dev/ttyUSB2 -c avr109 -b 115200 -U flash:w:main.hex -v -v
avrdude: Version 5.10svn, compiled on May 2 2010 at 17:02:16
System wide configuration file is "/usr/local/etc/avrdude.conf"
User configuration file is "/home/alex/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB2
Overriding Baud Rate : 115200
PAGEL : P00
BS2 : P00
RETRY pulse : SCK
Timeout : 0
StabDelay : 0
CmdexeDelay : 0
SyncLoops : 0
ByteDelay : 0
PollIndex : 0
PollValue : 0x00
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 0 0 0 0 no 1024 32 0 0 0 0x00 0x00
application 0 0 0 0 no 32768 256 0 0 0 0x00 0x00
apptable 0 0 0 0 no 4096 256 0 0 0 0x00 0x00
boot 0 0 0 0 no 4096 256 0 0 0 0x00 0x00
flash 0 0 0 0 no 36864 256 0 0 0 0x00 0x00
prodsig 0 0 0 0 no 512 256 0 0 0 0x00 0x00
usersig 0 0 0 0 no 512 256 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
fuse0 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse1 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse2 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse4 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse5 0 0 0 0 no 1 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Device code: 0x7b
Reading | ################################################## | 100% 0.01s
avrdude: reading input file "main.hex"
avrdude: input file main.hex auto detected as Intel Hex
avrdude: writing flash (6842 bytes):
Writing | ################################################## | 100% 1.09s
avrdude: 6842 bytes of flash written
avrdude: verifying flash memory against main.hex:
avrdude: load data flash data from input file main.hex:
avrdude: input file main.hex contains 6842 bytes
Reading | ################################################## | 100% 1.10s
avrdude: 6842 bytes of flash verified
Posted: May 30, 2010 - 08:29 PM |
I can't remember the exact output, but I've had problems with AVRDude 5.10 on my laptop. I also have AVRDude 5.10 on my desktop, but they came from different repositories - the laptop one came from Debian "stretch" and the working desktop version came from Ubuntu 10.04. Both are reportedly version 5.10, but maybe one of them has extra patches included in the package that fix some of these issues. Still trying to get to the bottom of that, not sure if it's related...
Also, did you use the included makefile to program the bootloader? I swear I was doing everything right, but for some reason the makefile programmed it correctly whereas my own AVRDude attempts failed. |
_________________ _________________
Brad Nelson
http://bradsprojects.wordpress.com
Posted: May 30, 2010 - 08:35 PM |
| You're using Windows, right Neil? Most of the testing I have done has been in Linux. It shouldn't make too much difference, but it is definitely a consideration. I will try firing up a Windows VM later and seeing if I can program a chip successfully with the latest avrdude for windows. |
_________________ Alex Forencich
XBoot eXtensible Bootloader for AVR ATMEGA and XMEGA
Posted: May 30, 2010 - 09:12 PM |
Alex, yes I'm using using windows with AvrStudio 4.18Sp2
By referencing back to my last boot build, I've found I need to include in AvrStudio Project.Configuration Options.Project Options.[Linker Options] the following
-Wl,--section-start=.text=4000
Also, when programming it - the F2 B6=0
Fuses.BOOTRST="Boot Loader Reset"
This gets the Bootloader loaded into the right memory. Your makefile is sure nice for that. For some reason I haven't got the right make to run it so I'm doing it through AvrStudio.
Then I can use avrdude with -t to be able to go into terminal mode and read if the application file is being programmed in. Which it is not.
If I program it from the JTAG it works.
So there must be something I am missing.  |
Posted: May 31, 2010 - 04:10 AM |
Posted: May 31, 2010 - 04:31 AM |
4000 (0x4000) places it in the right place in memory.
The manual Fig 7-1 references the word address as
2000 for the X16A4
4000 for the X32A4
8000 for the X64A4
I'm getting the xboot loaded in the right location - and its processing commands, but doesn't appear to be programming it. I've put it on the back burner till I can look at the avr109 code to see if there is a way of monitoring the command stream into/out of avrdude.  |
Posted: May 31, 2010 - 05:33 AM |
| Yeah. But I believe the linker requires an address in bytes, not words. Please try it with 8000 and tell me what happens, since that's the value that works for me on the same part. |
Posted: May 31, 2010 - 07:02 AM |
That seems to have done it!. At least from the quick late night test.
I thought I had tried it, and checked its placement in memory, but I think I got confused with the byte/word issue.
So the boot program was running before, and then continually restarting - so it was handling the commands but not from the boot section, so it couldn't program. Whew.
So thanks for looking over my shoulder and making suggestions as to the obvious.
Will check it more tomorrow. |
Posted: May 31, 2010 - 07:28 AM |
| Heh. No problem. Thanks for verifying that it is actually possible to get XBoot to run properly in AVR Studio in windows! I have not had a chance to get a debug environment set up for that yet. Would you be interested in writing a little blurb about how to set up AVR studio for the XBoot readme? |
Posted: May 31, 2010 - 03:06 PM |
How does this look - its two parts - 1)the AvrStudio setup 2) the programming with a JTAG MkII from AvrStudio
TO use AvrStudio for Xmega Xboot ensure you have
AvrStudio 4.18 Sp2 (build700) and WinAvr-20100110
Create a project within Avr - say Xboot.
The somewhat tricky bit is that the project has to be set for the specific member of the Xmega family used.
The Flash is linear and the Boot code is at the end of the flash. Refer to the makefiles "BOOT_SECTION_START" or the specific parts manual. For the AtXmega32A4 with 4K of boot, it is located at byte address 8000.
In AvrStudio on the Project menu, open the configuration options.
On the "general" tab, select the device atxmega32a4
Set the Frequency to 2000000Hz
Ensure Create Hex File is checked
Step on to the Custom Options tab, and in the "Custom Compilation Options" window select the [Linker Options]
Copy the following into the Add window, and then press Add
-Wl,--section-start=.text=8000
Press OK
and build your project.
The 2nd part - blowing into the boot
Now program the boot file into the part and set the FUSEBYTE2 Bit6 = 0 (Boot Loader Reset).
The method is dependent on the Xmega member used and your tools.
A number of members of the Xmega family require the PDI interface(eg the Xmega32A4) - so I have the Jtag MKII that supports PDI (B revision - see Avr Tools Guide in Avr Studio.)
From AvrStudio connect to the MkII Jtag.
ON the Main tab set the "Device", (eg ATxmega32A4) and press read Signature to ensure its connected.
On the Fuses tab
select BOOTRST: "Boot Loader Reset" or FUSEBYTE2 bit6=0
Now go to the Program tab, In the Flash section, select the hex file and press program.
Posted: Sep 07, 2010 - 03:39 AM |
I've just got my xboot bootloader going on a Xmega256A3 using AVR Studio, big thanks to Alex and Neil - it would've taken me a lot longer if you guys hadn't been willing to share your hard work.
Note to others intending on using AVR Studio, the linker start address is in bytes but spec'd in the data sheet in words. This is mentioned in an earlier post but I still missed it...tsts |
Posted: Sep 13, 2010 - 02:50 AM |
Can you provide a link for the latest patched avrdude executables? You mention on your webpage that version 5.10 does not support XMEGA unless it is patched (which I am not familiar doing).
[edit] I just found that sinaprog has it included in it.
(I am still trying to get the bootloader to work...) |
_________________ www.gabotronics.com
Posted: Sep 13, 2010 - 03:29 AM |
As far as I have been able to determine, the patches are only necessary for a JTAGICE mkII programmer. I have had no trouble using the included makefile (modified for my selected AVR and to use an AVRISP mkII) with the standard AVRDude 5.10.
Brad |
Brad Nelson
Posted: Sep 13, 2010 - 03:43 AM |
Thanks. I am one step further with the bootloader. I am able to run avrdude and the xmega responds. It starts programming but fails in the verification. I get this message:
avrdude: verification error, first mismatch at byte 0x0000
0x0c != 0xff
I compared the content of the ATXMEGA324A4's flash before and after and it is the same. Any clues? |
Posted: Sep 13, 2010 - 03:52 AM |
Is this output from avrdude loading XBoot onto the micro via PDI or avrdude loading a program onto the micro via XBoot?
I recall seeing this error I got when the bootloader was not correctly loaded into the boot section.
Hmmm ... come to think of it, I also got this error recently on a new development setup and the only way I could get it to install was to restart the computer. It would only correctly load the bootloader on the first avrdude attempt per boot. I hate to give such crude advice, but try unplugging the programmer and rebooting, then give it another try.
A little more info might help: Are you using the included makefile? What OS? Which programmer? The terminal command you are using with avrdude and the full output would help also.
Brad |
Brad Nelson
Posted: Sep 13, 2010 - 04:04 AM |
Thanks. Attached is the source, the hex file, the makefile and the output. All the remaining source files that I didn't include are the same as the original source.
I am using windows 7 64-bit, avrdude 5.10, AVR Studio 4.18, with the "Use external makefile" checked.
I was wondering if the problem was specifying the address like in the posts above, but since I am using the makefile, I think the linker options cannot be changed. |
Posted: Sep 13, 2010 - 04:12 AM |
You're using a JTAGICE mkII programmer according to the Makefile - is that right? Also, have you verified the JTAGICE mkII hardware revision you have can program XMegas? (Search the forum for more info if not) Does it have recent firmware loaded into it?
I'm not a Windows user, so I'll help as much as I can but it will be mostly in generalities. |
Brad Nelson
Posted: Sep 13, 2010 - 04:16 AM |
I am using the serial port, not the JTAGICE. I just changed that setting on the makefile, so now it is:
AVRDUDE_PROGRAMMER = avr109
But it didn't make any difference. |
Posted: Sep 13, 2010 - 04:23 AM |
Hope this doesn't come across as condescending, just need to make sure we're on the same page:
1) XBoot must first be correctly loaded into the boot section of flash on the XMega. This must happen using a PDI capable programmer, such as the JTAGICE mkII or the AVRISP mkII. The patch mentioned is for this step, not for general XBoot (AVR109) programming.
2) After XBoot has been correctly loaded, only then can one use avrdude configured to use the AVR109.
It sounds to me like step 1 has not been correctly accomplished yet. Which PDI capable programmer are you using for this step? |
Brad Nelson
