PostPosted: Sep 06, 2009 - 01:46 AM
Would there be anything wrong with someone posting AVR32 tutorials in this forum?
This forum is for 8 bit AVRs. The 32 bit AVRs have their own set of forums. It would be more appropriate if the admins would add a tutorial forum to that group.
Ductapemaster
PostPosted: Sep 09, 2009 - 06:25 PM
I think a tutorial on external interrupts would be useful. All the tutorials I have found all suggest different things and none of them explain how things work and just give you code to copy.
DavidDee
PostPosted: Oct 07, 2009 - 09:53 PM
I'm 18 since Feb 14th - I'm one of the young ones here (along with Daqq and a few others). Uni takes up a huge chunk of my days, and most of my home time is taken up by social commitments, Uni assignments, Uni homework and not a whole lot else. What time I do get to myself I usually spend posting and reading here. No time for anything else!
Ha sorry to comment on a post that was 2 years old. But I wonder who is the youngest on here that is active. I just turned 15. Never know there could be some 6 year old genius trolling around here.
frakk2136
PostPosted: Nov 16, 2009 - 10:36 AM
I would add a vote to software USB using the V-USB library or similar.
John3
PostPosted: May 26, 2010 - 04:03 PM
I don't seem to be able to find something that explains the conventions used by Atmel for altering register contents in all their assembly programming examples. I can make the code work by using the example, but it would be nice to have explanations all in one place.
What I mean by the above is stuff like shifting in a one or zero bit so many places as in:
ldi r16,(1<<CS02)|(1<<CS01)|(1<<CS00)
I would benefit by having a reference in the use of operators in parenthesis above. Not the bit names or the include file, just the operators.
John
PostPosted: May 26, 2010 - 04:52 PM
It's in the assembler user manual:
Studio help file wrote:
Shift left
Symbol:        <<
Description:   Binary operator which returns the left expression shifted left the number given by the right expression
Precedence:    11
Associativity: Left
Example:       ldi r17,1<<bitmask  ;Load r17 with 1 shifted left bitmask times
PostPosted: May 26, 2010 - 09:34 PM
And "|" and "&" are bitwise OR and bitwise AND. These are the same techniques used in C (and their use can be seen it the "Progamming 101" tutorial.
LDEVRIES
PostPosted: May 27, 2010 - 12:13 AM
A Tutorial on Fault finding technique & Basic test equipment would not go astray. Unfortunately with a lot of newbies if they can't fix it with a keyboard it can't be fixed.
Charles Darwin, Lord Kelvin & Murphy are always lurking about!
Lee -.-
John3
PostPosted: May 27, 2010 - 12:17 PM
Thanks Clawson and Koshchi. That is what I was looking for. I wish Atmel would add that to the HTML help in AVR Studio (so it would be there under HELP). And also, reference it in the application notes.
John
PostPosted: May 27, 2010 - 12:31 PM
That is EXACTLY where I copied that text from. In fact I just put a copy of the AVRASM help file online on my website. Suggest you look at:
http://www.wrightflyer.co.uk/asm/AVRASM ... sions.html
Either click the "<<" link in the table or simply scroll down the page to where it's documented. As I say I just took the .chm, that is accessible from the "Help" menu, from my copy of AVR Studio and converted it into a website. You can read how I did that here:
http://www.avrfreaks.net/index.php?name ... mp;t=77893
ArnoldB
PostPosted: May 27, 2010 - 07:08 PM
I have occasionally written a tutorial. Over time I have deleted all of them. Those in need of the information either don't read it "reading is for old people", or don't understand it. In the end the tutorials just earned me PMs from crackpots.
LDEVRIES
PostPosted: May 28, 2010 - 07:22 AM
Thanks for the advice Arnold. Plenty of crackpots around all right!
Lee -.-
John3
PostPosted: Jun 01, 2010 - 05:48 PM
name=PNphpBB2&file=viewtopic&t=77893
After reading the recommended thread I now see it is in the help HTML *after* an assembly project has been opened. If you don't open an assembly file, there is still plenty of help HTML in AVR Studio, but none that I found that way cover the operators that were confusing me. But once an assembly project is loaded, its all there!
John
PostPosted: Jun 01, 2010 - 06:34 PM
No ALL the .chm's are available without a project. Just start Studio, no project and the top entry on the Help menu is "AVR Tools User Guide". That leads to a composite list of all the installed .chm files including "AVR Assembler" and "AVR Assembler 2". The help about << is under "AVR Assembler - User's Guide - Expressions"
John3
PostPosted: Jun 02, 2010 - 12:13 PM
It is indeed! I thought I had checked everything there.
When a project is open there is a topic "asembler help" that appears and that one also has the expressions.
mbruck
PostPosted: Jan 27, 2011 - 08:07 PM
Morons guide using POINTERS!
PostPosted: Jan 28, 2011 - 12:10 PM
But surely there's nothing AVR specific about that and there's got to more than a thousand C/C++ tutorial sites on the internet where you can learn about that? If you are learning about using pointers in C it's far better to do it in a PC environment than on embedded hardware anyway as there are far more advanced and easy to use development tools and debuggers to "play" with experiments (the free editions of Microsoft Visual Studio Express spring to mind).
mbruck
PostPosted: Feb 09, 2011 - 12:39 AM
Agree!
IMHO having some tutorial about pointers in AVR GCC would be helpfull here.
LDEVRIES
PostPosted: Feb 09, 2011 - 08:12 AM
There is no doubt that when I used to teach C everything used to go pretty well until the day when pointers were introduced. The odd student who had done assembly language programing fared a little better as I could tell them that we pointers adressing was indexing and an index register was a pointer variable. But students tried to avoid pointers like the plague. Pointers of course allow extremely complex things to be done relatively simple...linked lists etc.
I believe that there are plenty of tutorials on pointers , but sometimes the connection is name made between pointers on PC and pointers in micros.
However, I am prepared to put together a short tutorial on pointers, with some specific AVR examples, without getting into complex algorithms(that can always be done later if required).
Lee -.-
PostPosted: Feb 09, 2011 - 11:39 AM
Lee,
Nice offer but you really have to question some of these folks ability to use Google. I just typed "introduction to pointers in C" into Google and it hit 4,660,000 sites. Everything on the first page of results looks really useful.
While you could write a tutorial from scratch to reinvent the wheel for the 4,660,001th time I'd suggest just cherry picking the best bits from some of those other articles (though I guess there may be an issue of copyright?)
