sinine
PostPosted: Apr 23, 2010 - 08:05 AM
i am having a problem whit Atmega128 and ds1820 sensors.i am using AVR studio for programming. I have searched lots of materials for ds1820 sensors, but not founded right C code to modify.
I am using http://home.roboticlab.eu/en/hardware/homelab/controller Atmega128 board. I made a connection between RS232 (com port) and DS1820 sensors.
So i want to connect it to Atmega128 board and get the sensors reading the temperature and get it on LCD.
Anyone has some good ideas or sample codes please notice! Rolling Eyes
PostPosted: Apr 23, 2010 - 08:37 AM
A DS18B20 is different to a DS18S20 chip. The DS1820 is obsolete (I think).
You can use any pin of your mega128 for the one-wire bus. You choose your physical pin and wire the chip according to the data sheet.
You tell the compiler / configure the library so that it knows this pin.
There are many programs. Google 'danni one wire AVR' or 'AVR DS18B20'
sinine
PostPosted: Apr 23, 2010 - 08:40 AM
I know it is different, im not using "B"
sherazi
PostPosted: Apr 25, 2010 - 01:59 PM
u can get help from the tuxgraphics.com article..
although it is for webserver but u can extract ur code...
http://tuxgraphics.org/electronics/200906/home-climate-control.shtm is the artcicle
and the code files arelhttp://tuxgraphics.org/common/src2/article09061/
in the code files u can use the ds18x20.c leave the first block... thats for webserver... use the required code.... the article would also help[/quote]
sherazi
PostPosted: Apr 25, 2010 - 02:04 PM
u can get much help at the other similar post...
http://www.avrfreaks.net/index.php?name ... p;p=347550
hope it might have helped...
sherazi
PostPosted: Apr 25, 2010 - 02:12 PM
http://www.kmitl.ac.th/~kswichit%20/avrthermo/thermo.c
u can also get the avr lib for it...
http://www.sicklinger.com/en/microcontr ... -in-c.html
sinine
PostPosted: May 04, 2010 - 07:17 AM
Thank you for the help! I tryed to do like this: http://www.sicklinger.com/en/microcontroller-avr/58-atmel-avr-atmega-ds18x20-library-in-c.html
I used only one sensor per ATMEGA Pin. So i connected first sensor to my Atmega128 PD3 (PORTD) and second one to PD5.
here is the datasheet of ds18s20: http://datasheets.maxim-ic.com/en/ds/DS18S20.pdf
Here is the code, can someone check it out, some tips my be useful! I can get on my LCD only " 0,0 C " so something is wrong it wont measure temp Idea Question
#include "lcd.h"
#include "pin.h"
#include "stdint.h"
#include "stdio.h"
#include <string.h>
#include "ds18x20lib.h"
// S T A R T  M A I N  P R O G R A M
int main (void)
// Init display
   lcd_init(LCD_DISP_ON);
   // Clear screen
   lcd_clrscr();
// Allocate memory
   unsigned char temp_po_str[8],temp_pm_str[8];//,temp_pu_str[8],temp_ke_str[8],temp_bo_str[8];
   float temp_po,temp_pm;//temp_pu,temp_ke,temp_bo;
// Init Stuff
   ds1820_init(DS1820_pin_po);              //Initialize DS1820
   ds1820_init(DS1820_pin_pm);              //Initialize DS1820
// Do only once
   for(;;){
// Read temperature
       temp_po = ds1820_read_temp(DS1820_pin_po);//Get temperature from DS1820 puffer oben
      temp_pm = ds1820_read_temp(DS1820_pin_pm);//Get temperature from DS1820 puffer mitte
      sprintf(temp_po_str,"%.1f C",temp_po); //Convert temp. puffer oben to string
      lcd_gotoxy(1,0);
      lcd_puts(temp_po_str);
      sprintf(temp_pm_str,"%.1f C",temp_pm); //Convert temp. puffer mitte to string
         lcd_gotoxy(1,1);
      lcd_puts(temp_pm_str);
// E N D  M A I N  P R O G R A M
// Reset DS18S20
uint8_t ds1820_reset(uint8_t used_pin)
  uint8_t err=100;
  DS1820_DDR |= 1<<used_pin;                  // define as ouput
  DS1820_PORT &= ~(1<<used_pin);               //Pull low
  _delay_us(480);            ;               // 480 us
  DS1820_DDR &= ~(1<<used_pin);                  // define as input
  DS1820_PORT |= 1<<used_pin;                  //Pullup on
  _delay_us(66);                              // 66 us
  err = (DS1820_PIN & (1<<used_pin)) >> used_pin;   // no presence detect --> err=1 otherwise err=0
  _delay_us(240);                           // 240 us
  if( (DS1820_PIN & (1<<used_pin)) == 0 ){         // short circuit --> err=2
    err = 2;
  return err;
// Write one bit to DS18S20
void ds1820_wr_bit(uint8_t wrbit,uint8_t used_pin)
   if (wrbit ==0)   {
      _delay_us(60);
      _delay_us(4);
   if (wrbit ==1)   {
      _delay_us(10);
      _delay_us(54);
// Read one bit from DS18S20
uint8_t ds1820_re_bit(uint8_t used_pin)
   uint8_t rebit;
   _delay_us(1);
   _delay_us(10);
   rebit = (DS1820_PIN & (1<<used_pin)) >> used_pin;    //Read bit
   _delay_us(50);
   return rebit;
// Read 1 byte from DS18S20
uint8_t ds1820_re_byte(uint8_t used_pin)
   uint8_t rebit;
   uint8_t rebyte =0x00;
   uint8_t i;
   for (i=0;i<8;i++)
      rebit=ds1820_re_bit(used_pin);
      //_delay_us(2);                           //be on the save side
      if (rebit==1){
         rebyte|=(1<<i);
   return(rebit);
// Write 1 byte to DS18S20
void ds1820_wr_byte(uint8_t wrbyte,uint8_t used_pin)
   uint8_t i;
   for (i=0; i<8; i++) // writes byte, one bit at a time
      ds1820_wr_bit((wrbyte & 0b00000001),used_pin);
      wrbyte = wrbyte >> 1;
   _delay_us(5);
// Read temperature
float  ds1820_read_temp(uint8_t used_pin)
   uint8_t error,i;
   uint16_t j=0;
    uint8_t scratchpad[9];
   float temp=0;
   scratchpad[0]=0;
   scratchpad[1]=0;
   scratchpad[2]=0;
   scratchpad[3]=0;
   scratchpad[4]=0;
   scratchpad[5]=0;
   scratchpad[6]=0;
   scratchpad[7]=0;
   scratchpad[8]=0;
   error=ds1820_reset(used_pin);                           //1. Reset
   if (error==0){
       ds1820_wr_byte(0xCC,used_pin);                       //2. skip ROM
       ds1820_wr_byte(0x44,used_pin);                       //3. ask for temperature conversion
       while (ds1820_re_byte(used_pin)==0xFF && j<1000){         //4. wait until conversion is finished
         _delay_us(1);
         j++;
       error=ds1820_reset(used_pin);                        //5. Reset
       ds1820_wr_byte(0xCC,used_pin);                       //6. skip ROM
       ds1820_wr_byte(0xBE,used_pin);                       //7. Read entire scratchpad 9 bytes
       for (i=0; i<9; i++)                                //8. Get scratchpad byte by byte
          scratchpad[i]=ds1820_re_byte(used_pin);                //9. read one DS18S20 byte
   if(scratchpad[1]==0x00 && scratchpad[7]!=0){               //Value pos.
      scratchpad[0]=scratchpad[0] >> 1;
      temp=(scratchpad[0]-0.25f+(((float)scratchpad[7]-(float)scratchpad[6])/(float)scratchpad[7]));
      temp = (floor(temp*10.0+0.5)/10);                     //Round value .x
   if(scratchpad[1]!=0x00){                              //Value negative
      uint8_t tmp;
      tmp =scratchpad[0];                                 //Save Kommabit
      tmp= ~ tmp;
      tmp= tmp >> 1;
      temp = (-1)*(tmp+1);
      if ((scratchpad[0]&0b00000001)==1){
         temp=temp+0.5;
   return temp;
// Initialize DS18S20
void  ds1820_init(uint8_t used_pin)
   uint8_t error;
   uint16_t i =0;
   if (error==0){
       while (ds1820_re_byte(used_pin)==0xFF && i<1000){         //4. wait until conversion is finished
         _delay_us(1);
         i++;
sinine
PostPosted: May 17, 2010 - 06:31 PM
Code updated, help still needed!
PostPosted: May 17, 2010 - 06:55 PM
Why not put some LCD output routines (followed by a delay to allow you to see the result) within the ds1820_read_temp() starting by outputting the raw bytes read from the chip. I'm kind of guessing they might all be 0x00 suggesting that the ds1820_re and ds1820_wr primitives themselves are not working.
Don't expect to be able to debug something this complex by writing the entire thing then wondering why the display shows "0.0 C". You need to start at the lowest level primitives, prove those and only move on to debugging the code that relies on them when they are proven 100%
Bingo600
PostPosted: May 17, 2010 - 07:34 PM
I still recommend this library
Web
http://www.siwawi.arubi.uni-kl.de/avr_p ... index.html
Code
http://www.siwawi.arubi.uni-kl.de/avr_p ... 091001.zip
/Bingo
sherazi
PostPosted: Jul 12, 2010 - 10:15 AM
the ds18x20 are one wire sensors, that means you can connect multiple sensors on a single pin...
titan5451
PostPosted: Mar 22, 2012 - 06:41 PM
hey I have written code for interfacing ds18s20 with avr128.can anyone tell me what is the error and how can i rectify it.I want to display output on port B.I am using winavr.Please help at earliest.
#include <stdio.h>
#include <delay.h>
#define SKIP_ROM   0xCC
#define CONVERT_T   0x44      // DS18S20 commands
#define READ      0xBE
#define WRITE      0x4E
#define EE_WRITE   0x48
#define READ_PS      0xB4
unsigned short w1_init(unsigned short);
unsigned short w1_read(unsigned short);
void w1_write( unsigned short, unsigned short);
void w1_writebyte(unsigned short, unsigned short);
unsigned short w1_readbyte(unsigned short);
void _delay_ms (double __ms);
void _delay_us (double __us);
   unsigned short w1_init(unsigned short pin)
     unsigned short detect;
     DDRE  |= (1<<pin);     // pull bus low  (output logical 0)
     PORTE &= ~(1<<pin);
     _delay_us(480);
     DDRE  &= ~(1<<pin);    // Release bus (input, pull-up)
     PORTE |= (1<<pin);
     _delay_us(70);
     detect = !(w1_read(pin));       // if a 0 is detected, sensor is detected
     _delay_us(410);
     return detect;
   unsigned short w1_read(unsigned short pin) {
  unsigned short result;
  DDRE  |= (1<<pin);
  PORTE &= ~(1<<pin);      // initiate communication
  _delay_us(6);
  DDRE  &= ~(1<<pin);
  PORTE |= (1<<pin);      // release the bus (pull-up)
  _delay_us(9);
  result = PINE & (1<<pin); //leftshift once
  _delay_us(55);
  return result;
   void w1_write( unsigned short pin, unsigned short thebit) {
  if(thebit == 1) {
    DDRE    |= (1<<pin);
    _delay_us(6);
    DDRE    &= ~(1<<pin);
    _delay_us(64);
  else {
    DDRE    |= (1<<pin);
    _delay_us(60);             // maintain pull down during 60us
    DDRE    &= ~(1<<pin);
    _delay_us(10);
void w1_writebyte(unsigned short pin, unsigned short command) {
  unsigned short temp,i;
  for(i=0;i<8;i++) {
    temp = (command & 0x01); // temp is equal to the value of the first bit of command LSB
    if(temp)             //if true
       w1_write(pin,1);    //write bit1
      w1_write(pin,0);       //write bit0
    command = command >> 1; //right shift by 1 so next bit comes in LSB
unsigned short w1_readbyte(unsigned short pin) {
  unsigned short temp;
  int i;
  temp = 0x00;
  for(i=0;i<8;i++)
    temp |= ((w1_read(pin)) << i); //read bit by bit and keep shifting left to reach MSB so
                           //when i=7 MSB will have bit 7
  return temp;
{                        //referred from page 19 of DS18S20 data sheet
   unsigned short x;
   DDRE = 0x00;              // 1wire defined as input by default
   PORTE = 0x01;
   DDRB = 0xFF;             //make output port
   w1_init(0);
   w1_writebyte(0,SKIP_ROM);
   w1_writebyte(0,CONVERT_T);
   _delay_ms (10);
   w1_init(0);
   x=w1_readbyte(READ);
   PORTB=x;
   w1_writebyte(0,WRITE);
   w1_writebyte(0,EE_WRITE);      //copy to SPD
   PORTE=0x01;            //enable internal pull up for input
   _delay_ms (10);
$ Fixed code tags - JS $
Confused Confused Confused Confused
PostPosted: Mar 22, 2012 - 07:36 PM
what is the error
What error? What is happening and what do you expect? What happens after the last _delay_ms (10); statement?
titan5451
PostPosted: Mar 23, 2012 - 07:19 AM
js wrote:
what is the error
I have written according to the datasheet of ds18s20.My main objective is"to get the temperature from the sensor,convert it to integer value and store it in the micro controller and then display it on lcd" so what changes do I have to make in the code?
titan5451
PostPosted: Mar 23, 2012 - 07:57 AM
#include "lcd.h"
#include "pin.h"
#include "stdint.h"
#include "stdio.h"
#include <string.h>
int main (void)
// Init display
   // Clear screen
   lcd_clrscr();
// Allocate memory
// Init Stuff
// Do only once
   for(;;){
// Read temperature
      lcd_gotoxy(1,0);
         lcd_gotoxy(1,1);
// Reset DS18S20
  uint8_t err=100;
    err = 2;
  return err;
   if (wrbit ==0)   {
      _delay_us(60);
      _delay_us(4);
   if (wrbit ==1)   {
      _delay_us(10);
      _delay_us(54);
   uint8_t rebit;
   _delay_us(1);
   _delay_us(10);
   _delay_us(50);
   return rebit;
   uint8_t rebit;
   uint8_t i;
   for (i=0;i<8;i++)
      if (rebit==1){
         rebyte|=(1<<i);
   return(rebit);
   uint8_t i;
   _delay_us(5);
// Read temperature
   uint8_t error,i;
   uint16_t j=0;
   float temp=0;
   scratchpad[0]=0;
   scratchpad[1]=0;
   scratchpad[2]=0;
   scratchpad[3]=0;
   scratchpad[4]=0;
   scratchpad[5]=0;
   scratchpad[6]=0;
   scratchpad[7]=0;
   scratchpad[8]=0;
   if (error==0){
         _delay_us(1);
         j++;
      uint8_t tmp;
      tmp= ~ tmp;
      tmp= tmp >> 1;
         temp=temp+0.5;
   return temp;
   uint8_t error;
   uint16_t i =0;
   if (error==0){
         _delay_us(1);
         i++;
Which complier are you using winavr or codevision?
titan5451
PostPosted: Mar 23, 2012 - 09:50 AM
#include "lcd.h"
#include "pin.h"
#include "stdint.h"
#include "stdio.h"
#include <string.h>
int main (void)
// Init display
   // Clear screen
   lcd_clrscr();
// Allocate memory
// Init Stuff
// Do only once
   for(;;){
// Read temperature
      lcd_gotoxy(1,0);
         lcd_gotoxy(1,1);
// Reset DS18S20
  uint8_t err=100;
    err = 2;
  return err;
   if (wrbit ==0)   {
      _delay_us(60);
      _delay_us(4);
   if (wrbit ==1)   {
      _delay_us(10);
      _delay_us(54);
   uint8_t rebit;
   _delay_us(1);
   _delay_us(10);
   _delay_us(50);
   return rebit;
   uint8_t rebit;
   uint8_t i;
   for (i=0;i<8;i++)
      if (rebit==1){
         rebyte|=(1<<i);
   return(rebit);
   uint8_t i;
   _delay_us(5);
// Read temperature
   uint8_t error,i;
   uint16_t j=0;
   float temp=0;
   scratchpad[0]=0;
   scratchpad[1]=0;
   scratchpad[2]=0;
   scratchpad[3]=0;
   scratchpad[4]=0;
   scratchpad[5]=0;
   scratchpad[6]=0;
   scratchpad[7]=0;
   scratchpad[8]=0;
   if (error==0){
         _delay_us(1);
         j++;
      uint8_t tmp;
      tmp= ~ tmp;
      tmp= tmp >> 1;
         temp=temp+0.5;
   return temp;
   uint8_t error;
   uint16_t i =0;
   if (error==0){
         _delay_us(1);
         i++;
what is floor..?what does this do?
and i am getting this warning
main.c:86: warning: implicit declaration of function 'floor'
main.c:86: warning: incompatible implicit declaration of built-in function 'floor'
main.c: In function 'main':
main.c:227: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
main.c:227: warning: format '%.1f' expects type 'double', but argument 3 has type 'float'
for
and
PostPosted: Mar 23, 2012 - 10:08 AM
floor:
http://www.nongnu.org/avr-libc/user-man ... d89bd4cb85
which means you need:
#include <math.h>
at the top of your code and to be sure you link with libm.a
and PLEASE don't quote entire posts just to add a few lines in future!
titan5451
PostPosted: Mar 26, 2012 - 05:20 PM
PostPosted: Mar 26, 2012 - 05:26 PM
The entire main() code of that program does:
int main (void)
// Allocate memory
   unsigned char temp_x_str[8];
   float temp_x;
// Initialization Stuff
   w1_init(DS1820_pin);              //Initialize DS1820 Buffer oben
// Do only once
   for(;;){
// Read temperature
       temp_x = ds1820_read_temp(DS1820_pin);//Get temperature from DS1820 puffer oben
      sprintf(temp_x_str,"%.1f C",temp_x); //Convert temp. puffer oben to string
Exactly which line in that do you think will write anything on the LCD?
titan5451
PostPosted: Mar 26, 2012 - 05:36 PM
[code]int main (void)
sorry...my mistake.but the temperature does not come.
vinzrule
PostPosted: Dec 28, 2012 - 06:09 AM
int main (void)
// Allocate memory
   float temp_x;
// Do only once
   for(;;){
// Read temperature
vinzrule
tried running main program. an error-- ds18x20lib.h coming tell me what to do
