Posted: Mar 26, 2009 - 05:19 PM |
i follow what you ask me to do and i can build it.
but the prob is the program shows warning there
rm -rf fyp.o fyp.elf dep/* fyp.hex fyp.eep
Build succeeded with 0 Warnings...
avr-gcc.exe -mmcu=atmega169 -Wall -gdwarf-2 -DF_CPU=1000000UL -O0 -fsigned-char -std=gnu99 -MD -MP -MT fyp.o -MF dep/fyp.o.d -c ../fyp.c
In file included from ../fyp.c:2:
../LCD_Driver.h:48:8: warning: no newline at end of file
avr-gcc.exe -mmcu=atmega169 -Wall -gdwarf-2 -DF_CPU=1000000UL -O0 -fsigned-char -std=gnu99 -MD -MP -MT LCD_Driver.o -MF dep/LCD_Driver.o.d -c ../LCD_Driver.c
In file included from ../LCD_Driver.c:21:
../LCD_Driver.c:255:3: warning: no newline at end of file
avr-gcc.exe -mmcu=atmega169 fyp.o LCD_Driver.o -lm -o fyp.elf
avr-objcopy -O ihex -R .eeprom fyp.elf fyp.hex
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 --no-change-warnings -O ihex fyp.elf fyp.eep || exit 0
c:\WinAVR\bin\avr-objcopy.exe: there are no sections to be copied!
AVR Memory Usage
Device: atmega169
Program: 1718 bytes (10.5% Full)
(.text + .data + .bootloader)
Data: 33 bytes (3.2% Full)
(.data + .bss + .noinit)
Build succeeded with 3 Warnings...
what the problem with that warning |
Posted: Mar 26, 2009 - 05:25 PM |
Well what do you THINK that warning means? |
Posted: Mar 26, 2009 - 05:26 PM |
The problem is exactly what the warning says. There is no newline at the end of the file. How can that be unclear?
IIRC this can be a problem for the some compilers (not seeing the last token in the file). The simple remedy is to edit those files. Go to the last line. Place the caret after that last character on the line. Hit enter. Save the file and exit. Repeat for all files that generate the warning. |
Posted: Mar 26, 2009 - 05:29 PM |
AVR Memory Usage
Device: atmega169
Posted: Mar 26, 2009 - 05:31 PM |
| I'm out. |
Posted: Mar 26, 2009 - 08:13 PM |
sorry about the double post..
internet connection at my place so slow so it cause error like that
anyway thanks for the advice
my program now work properly without warning
you are really nice people |
Posted: Mar 30, 2009 - 07:34 PM |
Hye,
I have compile both keypad and lcd butterfly code C in a AVR Studio without warning and error.
But after i downloaded to AVR there was a buzzing sound appear.
Why is it happened?? Is it my coding mistake or AVR problem?
I attach the code for reference. Hope someone can help..  |
Posted: Mar 30, 2009 - 08:28 PM |
Look at the Butterfly schematic to see which pin is attached to the piezo element (buzzer) then note which part of you code is toggling that pin at an audio frequency.
Smiley |
Posted: Apr 02, 2009 - 04:52 PM |
i already change my keypad from PORTB to PORTD and i don't hear any "buzzing" sound.
but my problem now is the LCD doesn't show anything when i download the program to AVR
i'm using LCD driver which i get on the 1st thread of this forum
could anybody help me |
Posted: Apr 02, 2009 - 05:00 PM |
Posted: Apr 04, 2009 - 03:42 PM |
i already look the butterfly schematic but i still got the problem..
my keypad cannot sent data to buttefly lcd
this is my keypad code
int main()
//high nibble for output(columns) low for input(rows);
DDRB=0xF0;
//enable internal pullups for PB0-PB3
PORTB=0x0F;
//Port D for indication only
DDRD=0xFF;
while (1) //loop key check forever
//first column
PORTB =0b01111111;
//check for rows and send key number to portD
//instead sending key number to PORTD you can use
// any function that serves pressed button
if (bit_is_set(PINB, 3)) PORTD=1;
if (bit_is_set(PINB, 2)) PORTD=2;
if (bit_is_set(PINB, 1)) PORTD=3;
if (bit_is_set(PINB, 0)) PORTD=4;
//second column
PORTB =0b10111111;
if (bit_is_set(PINB, 3)) PORTD=5;
if (bit_is_set(PINB, 2)) PORTD=6;
if (bit_is_set(PINB, 1)) PORTD=7;
if (bit_is_set(PINB, 0)) PORTD=8;
//third column
PORTB =0b11011111;
if (bit_is_set(PINB, 3)) PORTD=9;
if (bit_is_set(PINB, 2)) PORTD=10;
if (bit_is_set(PINB, 1)) PORTD=11;
if (bit_is_set(PINB, 0)) PORTD=12;
//fourth column
PORTB =0b11101111;
if (bit_is_set(PINB, 3)) PORTD=13;
if (bit_is_set(PINB, 2)) PORTD=14;
if (bit_is_set(PINB, 1)) PORTD=15;
if (bit_is_set(PINB, 0)) PORTD=16;
what's the problem of this code because i can compile it on avr studio
is there any additional connection to interface this keypad and this butterfly lcd??
i really appreciate your kindest to help me find this problem |
Posted: Apr 04, 2009 - 05:22 PM |
I must be misunderstanding your question since both the Butterfly schematics and the 'Butterfly Alternate Pin Uses' document that I provided a link to for you both show that PORTD is connected to the PORTD pad AND to 8 of the LCD pins - so as one should see on the schematic or read in the document, you cannot use PORTD for both the LCD and as an input port at the same time.
And I just looked at your code and now my question is: what function in your code is sending data to the LCD? Earlier you said you changed your keypad from PORTB to PORTD and the buzzing stopped, but your code doesn't show this. Were you trying to turn on individual LCD elements with the write to PORTD?
And looking further back, I see that Dean suggested you use his LCD driver, so now I'm even more confused about what you are asking.
Please answer:
1. Did you try to use Dean's driver?
2. If so, why doe's it not show up in you code listing?
3. If you read the Butterfly Schematics how could you not know that your code would cause the Piezo element to buzz?
4. You said that after you changed ports the buzzing stopped, but you show the same code unchanged?
4. And if you read the Schematics and the Alternate Pin Use document, how could you not know that moving the keypad to PORTD would interfere with the LCD?
Again, I must be missing something in your question.
Smiley |
Posted: Apr 05, 2009 - 08:33 AM |
oh sorry..
i didn't mention it to you before..
after read the schematic i know that the Piezo element is in PINB5.
It's true that in the early i try to connect my keypad to PORTD but after reading the schematic, i change it back to PORTB because i realize PORTD will interfere the LCD.
my answer for your question..
1. yes, i 'm using dean's driver.
2. i send you the full code of my program include Dean's driver.
3. i already ask my friends.they said maybe the connection from the keypad to butterfly makes the buzzing sound.
your question 4 and 5 i already explain at above
sorry again because sending you the not update program
here i send you my new program
hope i already answer your question..
thanks |
Posted: Apr 05, 2009 - 05:08 PM |
Your keypad.c code:
#include "LCD_Driver.h"
int main()
DDRD=0xF0;
PORTD=0x0F;
DDRB=0xFF;
//first column
PORTD =0b01111111;
if (bit_is_set(PIND, 3)) PORTB=1;
if (bit_is_set(PIND, 2)) PORTB=2;
if (bit_is_set(PIND, 1)) PORTB=3;
if (bit_is_set(PIND, 0)) PORTB=4;
//second column
PORTD =0b10111111;
if (bit_is_set(PIND, 3)) PORTB=5;
if (bit_is_set(PIND, 2)) PORTB=6;
if (bit_is_set(PIND, 1)) PORTB=7;
if (bit_is_set(PIND, 0)) PORTB=8;
//third column
PORTD =0b11011111;
if (bit_is_set(PIND, 3)) PORTB=9;
if (bit_is_set(PIND, 2)) PORTB=10;
if (bit_is_set(PIND, 1)) PORTB=11;
if (bit_is_set(PIND, 0)) PORTB=12;
//fourth column
PORTD =0b11101111;
if (bit_is_set(PIND, 3)) PORTB=13;
if (bit_is_set(PIND, 2)) PORTB=14;
if (bit_is_set(PIND, 1)) PORTB=15;
if (bit_is_set(PIND, 0)) PORTB=16;
Now I know I'm missing your question because this code has nothing in it that uses Dean's LCD code. I thought your question was about getting the output of a keypad to show on a the Butterfly LCD using Dean's code, but I don't see anywhere that you use Dean's code, so what am I missing?
Smiley |
Posted: Apr 06, 2009 - 09:08 AM |
sorry..
i really confuse now..
what do you mean by this keypad code has nothing in it that uses Dean's LCD code.
am i using a wrong coding for this keypad?
what the function of #include "LCD_Driver.h"
if my keypad program is wrong, can you help and guide me how to make my project works or can you give some suggestion what link should i go and guidelines to settle this problem
thanks  |
Posted: Apr 06, 2009 - 10:28 AM |
Just #include'ing a .h file does NOT make use of any of the facilities it provides. This only happens when you call one or more of the functions that it documents.
To USE the LCD library you should be calling LCD_Init() near the start of your program and then later (probably) LCD_puts() to put message strings on the display. Otherwise what were you expecting to see on the display?
Cliff |
Posted: Apr 06, 2009 - 06:09 PM |
amiraliff wrote:
sorry..
Please read:
http://www.avrfreaks.net/index.php?name ... mp;t=70673
Then get the Butterfly Quick Start Guide from my website along with the Butterfly FAQ and a few other free and helpful documents that you can use to get started. I would further suggest you look at some of the source code I provide and at the Smiley's Workshops to learn the fundamentals before attempting a keypad.
After reading all this then if you have additional questions please start a new thread on using a keypad with a Butterfly. This tread is not the appropriate place for this discussion.
Smiley |
Posted: Apr 24, 2009 - 05:41 PM |
hi again
im having a problem with dean's lcd driver
when i try to compile this driver, there is an error's appear
c:/winavr/bin/../lib/gcc/avr/4.1.1/../../../../avr/lib/avr5/crtm169p.o  .init9+0x0): undefined reference to `main'
make: *** [lcd.elf] Error 1
hope u guys out there can help me |
Posted: Apr 24, 2009 - 06:24 PM |
| Well that's telling you that no where in the files being compiled is there a function called main() - all C programs must have this. |
Posted: Apr 24, 2009 - 06:45 PM |
oh...
so where should i put the main() function
i try to write it but there still have an error
so can u tell me where the best place i should write this function |
