Posted: Jun 22, 2007 - 10:38 AM |
How ca I remove these includes when I'am woking in a windows version? Tese includes seems to appear for no reson?!?
Help?
Edit:
Invalid project path: Include path not found (\usr\include).
Invalid project path: Include path not found (\usr\include\w32api).
Invalid project path: Include path not found (\usr\lib\gcc\i686-pc-cygwin\3.4.4\include).
Posted: Jul 24, 2007 - 06:10 PM |
Hi eaanon01,
I've the same problem running AVR32 1.0 with the latest updates, toolchain 1.2.5 and library 1.0.0 trying to understand the hello world example.
(I also used the library 1.1.0)
I cannot find where to change the path information
I can add a directory at properties c/c++ build include paths and add "..\..\..\..\Cygwin\usr\include" Then I have a new include path in the project.
But I don't know where to change the environment variables.
changing the environment at properties c/c++ build environment also doesn't help.
Any ideas?
cheers
Joern |
Posted: Jul 24, 2007 - 06:49 PM |
if I understand you correctly
I was able to add environment variable "BOARD"
by going to
project->properties->C/C++ build->Symbols->add
and adding
"BOARD=AVK1100"
hope I helped |
Posted: Jul 30, 2007 - 05:25 PM |
Dear natanel,
thanks for your poste. But after adding BOARD=AVK1100 I've got an "make.exe Application Error":
The instruction at "0x6100365f" referenced at "0x0062da90". The memery could not be "written".
check environment fails.
Any ideas what went wrong?
Regards
Joern |
Posted: Jul 30, 2007 - 10:49 PM |
Help?
These includes are generated by CDT which for some reason does not respect the toolchain compiler/linker command and retrieves the values from whatever gcc you have first in the path. The warning can be safeley ignored as they do no harm. We're looking into the matter. |
Posted: Jul 31, 2007 - 07:26 AM |
Posted: Jul 31, 2007 - 05:23 PM |
ok torkildr,
I will ignore the warning.
By the way, today the IDE was operative again, but a
gcc.exe.stackdump is new in may project.
Exception: STATUS_ACCESS_VIOLATION at eip=00000000
eax=00000001 ebx=18C7CDF0 ecx=61105500 edx=FFFFFFFF esi=61104F30 edi=18C7CE64
ebp=00000000 esp=18C7CDBC program=C:\Cygwin\bin\gcc.exe, pid 948, thread proc_waiter
cs=001B ds=0023 es=0023 fs=0038 gs=0000 ss=0023
Stack trace:
Frame Function Args
End of stack trace
1284936483 [unknown (0x548)] gcc 948 _cygtls::handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
1284972214 [unknown (0x548)] gcc 948 _cygtls::handle_exceptions: Error while dumping state (probably corrupted stack)
Best Regards
Joern |
Posted: Aug 06, 2007 - 02:40 PM |
there is a typo in the tread
please use
BOARD=EVK1100
instead of
BOARD=AVK1100 |
Posted: Feb 29, 2008 - 11:55 PM |
Guys,
I'm having a problem that might be related.
I am trying to run the blinky example (loading using batch isp). When I load the binary that I compiled, LEDs 0, 1 and 3 light up, and 2 is off (i.e. it doesn't work).
When I load the gpio example from AT32UC3B-1.1.1 drivers, it works fine.
This leads me to believe it is my compiler that is broken.
Please help!
-P |
