GCLD Font Creator
12 posts / 0 new
This tool seems to come from http://www.mikroe.com/glcd-font-... these days.
A useful tool for creating fonts for your LCD and other graphic displays.
274,207,281-1 The largest known Mersenne Prime
It produces a structure that looks something like this.
const unsigned short Tahoma10x11[] = {
        0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,  // Code for char
Gives you one line per character. You'll want to edit it to be an array of bytes instead of shorts as none are bigger than 0xff. I also added PROGMEM.
The first byte of each line is the pixel width of the character. All the characters take the same memory so you can easily calculate where in the array to look for 'Q'. You could likely save some space by removing extra blanks and making another array to look up the offset into this array for each letter.
The rest of the line consists of the pixel data, one bit per pixel, arranged in columns. If your font is 16px high, there will be 2 bytes per column. The bits seem in reverse order to me, but aren't hard to read. Start with the first byte of the column. Bit 0 is the topmost pixel of the column, bit 1 below that and so on. The next byte goes below that.
A font is really big. "12 pt Tahoma" yielded 2880 bytes and 36pt Tahoma was 40KB. (I didn't use 36pt. Too big for display and memory.) I wonder if a simple "run length" compression would make it smaller but still easy to decode.
"Font converter" has been discussed before.
Gabotronics mentions compression:
http://www.avrfreaks.net/index.p...
>>You<< mentioned compression here:
The MikroElektronika tool is mentioned in this thread, along with the tool I use and links to more discussions:
"Pavius" tool:
http://www.pavius.net/2009/07/th...
Fonts can use up quite a lot of flash memory even with a 128x64 KS0108 display.
A 240x320 TFT display certainly benefits from better fonts. If you have a SDCard, memory is no problem. Otherwise just use subsets of fonts. e.g. if you are only displaying ascii text, you only need 0x20-0x7E.
Rendering detailed fonts on high resolution displays can use all sorts of tricks. Ask your Laser printer. I doubt that it is worth bothering when you only have 240x320.
Incidentally, the library simply uses a 7x5 font and multiplies each pixel. So it looks horrible in big sizes.
Hmmm--is there the equivalent of "TrueType" for zooming fonts suitable for an AVR8? Perhaps it is just easier to burn the storage for the needed fonts, than to spend time rendering and buffering the results in scarce SRAM.
I posted all this info here so it would show up if somebody searched. It's kindof an "update to the threads" posting.
I made 2 fonts from "Tahoma" and they are nicely readable on my tft. Tahoma is a font designed specifically to be read on screen. It does work well in print.
Yikes. A byte per pix. But I guess that makes sense if one has an 8 bit pixel. So each 10x11 char is 110 pix, 110 bytes, and you look up the 565rgb in a lookup table and draw the rgb pix?
And the storage requirements for a scalable vector-based font would be much greater than for a small-to-medium sized raster font. Add that to the code complexity, and I imagine the tipping-point where scalable beats raster is for very large fonts indeed.
JJ
"Read a lot.  Write a lot."
I've only done a couple of GCLD apps. Given the font storage size issue as is under discussion here, I stored only a partial font with the characters I needed and limited myself to a couple sizes.
I could certainly envision an app that wanted to display arbitrary strings and require a more-or-less full displayable character set. Upper+lower+numbers and space and period is 64. Add some other punctuation and symbols--say, 96? 80?
Now say you want it in several sizes. Keep it practical...say, x1/x2/x4. Three or four sizes?
So, where would the "breakeven" be to render a single font at several sizes and have it look good at x4?
Just noodling...
Just noodling...
A look at a simple non-serifed font like Arial shows it to be 266 KB (TTF format).
Looking at the font in FontForge we see the entry for the lower-case letter 'l' is described by 4 (x,y) points that are the endpoints of 4 joined lines.
The upper-case letter 'O' is described by 24 (x,y) points used to generate two concentric splines.
The special character '@' is described by 61 (x,y) points.
The average of the 3 characters is about 30 points. Let's assume this is excessive, and that a more realistic figure for a font designed for a small display is an average of 20 points per character.
Each point is represented by it's co-ordinates, a point type (linear, spline, etc), and some other attributes (angle, curvature, etc). For a simple implementation, let's assume we need only the co-ordinates.
With 20 points, each consisting of 2 co-ordinates, each stored as a 16-bit number, that's 80 bytes.
Add to that the expected code space required to do linear and even simple spline rendering, and we're looking at a fair amount of flash storage.
This is for one of the simpler fonts.
Compare that to a 5x8 1-bit raster font that takes only 5 bytes per character. A 10x16 font (twice the linear size) would take 20 bytes per character. A font family consisting of 5x8, 6x9, 7x11, 8x12, 9x14, and 10x16 would take about 5 + 9 + 11 + 12 + 18 + 20 = 75 bytes per character, but the code footprint would likely be much smaller than that of a scalable font engine.
Mind you, a scalable font implementation for a small display run by an 8-bit mcu wouldn't need all the features available in your average TTF font. You could possibly get away with 8-bit co-ordinates and still get decent results.
Noodles are tasty.
JJ
That would be scary. I use a bit per pix.
Hope this idea helps someone
