series or parallel cut crystals
3 posts / 0 new
In regards to the crystal oscillator circuitry, can the AVR devices use a series cut crystal,
or parallel cut only? If series cut can be used, are there any application notes or other data sheets showing frequency accuracy?
Thanks in advance for your help!
Rob Deatherage
admin's test signature
Check out these url's for information on crystals for microcontrollers
http://www.edtn.com/embapps/emba...
and this one has more detail, it is intel's AP-155 note.
http://developer.intel.com/desig...
Cheers
Carl
Hi all,
Normally, the crystal vendor knows very well what to supply to MCUs, and he definitely knows the most about crystal accuracy.
Generally, it can be said that the AVR needs Parallel resonance, AT cut crystals decoupled with caps typically in the range of 22-27pF.
For ceramic resonators, i think this page is of great help.
Best regards,
Morten, AVR tech. support, Atmel FAE
