3 phase SPWM (IAR - CodeVision)
10 posts / 0 new
The project was originally written in CodeVision, but I also added IAR version of project.
Ozhan KD
Knowledge is POWER
Sorry but which project in the Academy does this post relate to?
Hi Cliff,
This is the project:
http://www.avrfreaks.net/index.php?module=Freaks%20Academy&func=viewItem&item_type=project&item_id=2896
Ozhan KD
Knowledge is POWER
I will add V/f curve to the project for AC motor control applications.
Ozhan KD
Knowledge is POWER
Acceleration-deceleration and V/f curve was added to project for AC motor control applications.
Ozhan KD
Knowledge is POWER
Great project. Have you tried to generate AC voltage for motor control? Just curious what was used - triac, SCR etc? I would like to produce 0 -230 VAC 3 Phase power for testing?
Jerry
This project is written for ac motor control applications. A 3 phase bridge with 6 igbts with a driver like IR2130 can be used for this purpose. The 3 phase output are applied to 3 Not gates and the 6 output signals can be applied to IR2130.Also an isolation stage is better for safe operation.
Ozhan KD
Knowledge is POWER
Hi,Ozhan K. Thanks to your work. This project is very useful for me.but if the Carrier frequency need to be changed(i.e. 5kHz-20kHz),how to modify the project.
wgz
Hi wugenzhong
Carrier frequency depends on timer clock and pwm resolution. According to timer prescaler divisions(1,8,64,256,1024) and with constant pwm resolution, I think 5-20khz carrier frequency can be achieved by clocking the timer from an external clock with proper frequency range.
Ozhan KD
Knowledge is POWER
if I use timer from internal clock(there is no external clock),how to do it? Thanks!
wugenzhong
