[TUT][SOFT][CODE]FreeRTOS for ATmega2560/1
25 posts / 0 new
I have had requests from several folks for my version of FreeRTOS for the ATmega2560. I had always intended to take the latest) version of FreeRTOS, apply my changes, and submit it to the FreeRTOS group as another supported AVR processor, but I simply haven't gotten around to it.
Instead, I'm posting the code here, free for anyone's use. Please note that *all* the licenses from FreeRTOS apply to this version. Also, you get the same support, which is you can ask me for help and I may or may not help, depending on the request and my work load.
This code is based on FreeRTOS 4.8.0, although the grand majority of the changes are fairly simple and would be easy to merge with the latest version of FreeRTOS.
I have not included the co-routine stuff, since I do not use it.
There is a new switch, USE_RTC_TIMER which switches the RTOS timer from a dedicated timer (timer 0) to the RTC-crystal driven timer (timer 2). Your tick is a little longer than 2 mS, but you now have a single OS/RTC timer instead of two timers used for the same task of keeping track of time.
I've included the second level heap manager, heap_2.c, since I've added a routine to report memory usage for each task and for the total managed help.
Note that the task list function has had sprintf patched out in favor of itoa() and ltoa(). I did this because I don't like the added overhead of sprintf.
One of the problems with the ATmega2560/1 series is that GCC uses a 16-bit word to keep track of location. Most of the time this is corrected in the loader, but jump tables and function pointers have trouble with the upper half of the flash memory. (Keep in mind that the AVR addresses instructions by a word pointer so you have direct access to 128 Kbytes of flash. That's exactly half of the total 256 KBytes in the ATmega2560/1).
Since I want to be sure that the task stack initialization is simple, I require that all user-defined task routines reside in lower flash memory. I do that by modifying the portTASK_FUNCTION_PROTO macro to put the task function into the .task linker section. The custom script linker_script.x contains the special section .task located before the main code section.
For the same reason, my command handler defines the following macro:
#define COMMAND_HANDLER   __attribute__ ((section (".fptr_target")))
The .fptr_target section, like .task, is set up before the main code section. I use it in the prototypes of my command routines, like:
CmdError
CmdUnimplementedCommand( CmdPacket* pCmdPkt ) COMMAND_HANDLER;
Usage:
	result = CmdUnimplementedCommand( pCmdPkt );
Description:
	Default command procedure for unimplemented commands
Arguments:
	pCmdPkt - pointer to the command packet for this command
Results:
	CMD_ERROR_FUNCTION_NOT_IMPLEMENTED - always returns this!
The final bit of weirdness in linker_script.x is that I have another of these "pre-main code" sections, .isr, for ISRs. I am unconvinced that this is necessary since the JMP command can easily handle jumps to the top of memory, but I put it in a pique of anger once when an ISR wasn't working and I have never taken it out.
Nonetheless, inside of the projdefs.h file you will find:
/* The following defines the section for ISRs used throughout the code.
 * This is added to the current ISR() macro as another called argument.
#define ISR_SECTION __attribute__ ((section (".isr")))
This can be appended to the list of arguments in the ISR macro like this:
ISR( SIG_2WIRE_SERIAL, ISR_BLOCK ISR_SECTION )
(Yes, there is not a comma between ISR_BLOCK and ISR_SECTION. That's a weirdity of the way the ISR macro is defined.)
That's pretty much it. I currenlty have more than 70,000 lines of code and 9 tasks running on this. I regularly use queues, semaphores and task suspension without problems.
The problems that crop up regularly are:
1 - Insufficient stack space allocated to a task. Look for this if the machine "reboots" when you don't expect it. Use the task list function to get reports on how much stack your tasks are using. Keep in mind that ISRs can fire in any task, so if you have and ISR that uses lots of RAM (bad idea), make sure your minimumSTACK_SIZE is increased to handle it.
2 - Using a non-ISR function in an ISR. This will almost always lock up the machine.
At any rate, I hope this helps folks along. Enjoy!
Stu
can you post a complete project with makefile.(making two dummy tasks)
and thanks in advance for posting this
I love Digital
and you who involved in it!
Sorry for being silly. Found the sources (was not logged in...)
I want to use freeRTOS in a Atmega1280 (The chip that is used by Arduino Mega)
What version o the code should i use? The code to 2560 or the Atmega323?
Many thanks
Atmega 2560 gotchas:
You might be aware also that there was a problem when a C++ constructor
had to be called for a global static object in the region of upper flash (past 128KB).
The result was something strange, and the bug was corrected around late 2009 in gcc.
I am wondering what more problems we can find related to this 16-bit addressing. it hurts that 2560 is the only in line aith more than 128KB so that few users will have chance to witness the bugs before the application gets really big and complicated.
Hi..
I had decided to work with FreeRTOS. I have found that new version is 6.11.
So I'm little confused: should I start with your now quite old version, or download fresh version from official site.
I have buyed I book "Using the FreeRTOS Real Time Kernel - A Practical Guide wp" to support author.
Could you please review this latest version and give us short description how to start using it, at least with mega2560 as you already do with 4.8.0.
Regards!
You don't post AVR studio 5 project files. So how do compile using linker script you provided? :roll:
I've taken Stu_San's guidance and made modifications for freeRTOS 7.1.0 through to 8.2.3. The application is Arduino Mega 2560 (specifically a Freetronics EtherMega).
Code here:
https://github.com/feilipu/avrfreertos
http://sourceforge.net/projects/avrfreertos/
Write up here:
http://feilipu.me/2012/01/15/ethermega-arduino-mega-2560-and-freertos/
And here:
http://feilipu.me/2011/09/22/freertos-and-libraries-for-avr-atmega/
Note the 2560 portion is still incomplete, and probably faulty. But the scheduler is running so, by definition I guess it is working.
Thanks stu_san for your contribution. I have posted a link to this thread in the FreeRTOS Interactive! site:
http://interactive.freertos.org/entries/20870227-link-to-discussion-and-source-for-atmega2560-port
There are other contributed AVR ports there too:
http://interactive.freertos.org/forums/103473-atmel
Including this one, which seems to cover quite a lot of parts:
http://interactive.freertos.org/entries/20782373-freertos-winavr-port-for-atmega128-atmega1284p-at90can128-atmega169-atmega16
Please note, this is all contributed, rather than official code:
http://www.freertos.org/differences-between-officially-supported-and-contributed-FreeRTOS-code.html
+ http://www.FreeRTOS.org
The de facto standard, downloaded every 4.2 minutes during 2015.
+ http://www.FreeRTOS.org/plus
IoT, Trace, Certification, TCP/IP, FAT FS, Training, and more...
I tried to compile the port from feilipu's side [url] http://feilipu.posterous.com/eth...
but i always get the error : lib_fatf / cc932.c "This file is not needed in current configuration" line 23
I tried it 4 or 5 times, always the same error ! I followed all the steps on feilipu's tutorial. Can someone tell me where the problem is ?
Regards, Waldemar.
Is the error message not telling you EXACTLY what the problem is? cc932.c contains code to support Japanese Long File Names. (Chan is Japanese after all!). When you configure FatFs you edit ffconf.h and change the line:
/ Locale and Namespace Configurations
#define _CODE_PAGE	1
/* The _CODE_PAGE specifies the OEM code page to be used on the target system.
/  Incorrect setting of the code page can cause a file open failure.
/   932  - Japanese Shift-JIS (DBCS, OEM, Windows)
/   936  - Simplified Chinese GBK (DBCS, OEM, Windows)
/   949  - Korean (DBCS, OEM, Windows)
/   950  - Traditional Chinese Big5 (DBCS, OEM, Windows)
/   1250 - Central Europe (Windows)
/   1251 - Cyrillic (Windows)
/   1252 - Latin 1 (Windows)
/   1253 - Greek (Windows)
/   1254 - Turkish (Windows)
/   1255 - Hebrew (Windows)
/   1256 - Arabic (Windows)
/   1257 - Baltic (Windows)
/   1258 - Vietnam (OEM, Windows)
/   437  - U.S. (OEM)
/   720  - Arabic (OEM)
/   737  - Greek (OEM)
/   775  - Baltic (OEM)
/   850  - Multilingual Latin 1 (OEM)
/   858  - Multilingual Latin 1 + Euro (OEM)
/   852  - Latin 2 (OEM)
/   855  - Cyrillic (OEM)
/   866  - Russian (OEM)
/   857  - Turkish (OEM)
/   862  - Hebrew (OEM)
/   874  - Thai (OEM, Windows)
/	1    - ASCII only (Valid for non LFN cfg.)
Like me I bet you have that set to 1 saying you don't need/want foreign symbol support? When you then look in the cc932.c file you find:
#if !_USE_LFN || _CODE_PAGE != 932
#error This file is not needed in current configuration.
#endif
So it deliberately forces a compile time error if either you have not configured for LFNs or (if you have) if the code page is not set to 932. Well it isn't (see ffconf.h) so what this #error is telling you is "modify the list of files being passed to the compiler/linker to be built because cc932.c is no longer needed". (you'll be pleased to hear that this instantly reduces the size of FatFs by many KB!).
sorry for beeing stupid, but the only tools i worked with is avr studio 4 and the arduino IDE, so i dont know how to say the linker that the file cc932.c is not needed
i dont even know what a linker is... :(
In Studio there are a list of .c files in the project tree at the left. Just right click the cc932.c one and say "remove from project" (do NOT use the "delete" link - it really will delete the file from the disk!)
1. thanks for your help
2. i tried to get it running with eclipse, but it doesnt work, eclipse gives me always some errors, can someone explain how to get this running with avr studio 4? I'm new to the whole thing, i have written some projects in C but never worked with external files and so on.
As Ghost09 I still ahve problems compiling it. I get problems in lib_serial
expected ‘;’, ‘,’ or ‘)’ before ‘uxTxQueueLength’ lib_serial.h /FreeRTOS730/freeRTOS730/include line 172 C/C++ Problem
expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘xSerialGetChar’ lib_serial.h /FreeRTOS730/freeRTOS730/include line 183 C/C++ Problem
expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘xSerialPutChar’ lib_serial.h /FreeRTOS730/freeRTOS730/include line 184 C/C++ Problem
are this problem related to mega2560 or not?
9 times out of 10 that error is because you are using a type that the compiler does not know yet. Have a look at the lines mentioned and see if there's a non-standard C type being used. If so find where it is typedef'd and make sure an inclusion of the .h file where it is defined precedes the line where it is used.
I try to keep the Sourceforge AVRfreeRTOS code up to date, and improving.
Just updated the ChaN FatF code to 0.9b today, for example.
If I don't respond to a question here quickly, and no one else smarter gets to it either, try to get me here http://feilipu.me/
By the way, I've commissioned some hardware for a Goldilocks Arduino Uno clone. Description here.
http://feilipu.me/2013/03/08/goldilocks-1284p-arduino-uno-clone/
Be warned that there's a bug in it. mmc.c has added a sector erase ioctl but it uses defines not in the header.
I have been moving #defines around to manage quickly swapping between compiling on the Mega with XRAM and the Uno. To support a prototype for ArduSat XRAMFS.
http://feilipu.me/2013/02/17/ardusat-xramfs-prototyping/
So something might be in broken the example applications. But avrfreeRTOS and the libraries are not broken. In any case, I've just uploaded a new iteration. So let me know.
To the point from clawson, there is no mmc.c file in the code base, so I don't understand specific issue. Details, please?
And, please get a Goldilocks prototype Uno clone with 1284p with 16kByte RAM here:
http://pozible.com/project/18609
And help to grow our avr options for using Arduino Shields.
I guess you are using ff9b.zip rather than ffsample.zip then? The latter has implementation example files for ata, usb and mmc with mmc.h/mmc.c providing the SD/MMC code. That set of files has a bug. The readme in the former simply says:
Low level disk I/O module is not included in this archive because the FatFs
module is only a generic file system layer and not depend on any specific
storage device. You have to provide a low level disk I/O module that written
to control your storage device.
If you just use the generic files then presumably to satisfy diskio.c you have provided your own implementations of MMC_disk_initalize(), MMC_disk_write() and so on? So I guess you won't suffer from the problem of using ChaN's own version of these. (having said that I'm not sure why anyone would not simply use Chan's own files from ffsample.zip?)
EDIT: OK I see it now. In your FreeRTOS730/lib_fatf/diskio.c you have replaced the generic code with your own implementation of read/write functions. The code there actually looks a lot like an old version of mmc.c in fact (but with different function names). Do you not worry that you will miss out on bug fixes (or, as in this case, introduced bugs!) in later issues of ChaN's mmc.c?
I keep an eye on updated versions and diff each file before I replace it. Also I usually get a lot of alternative sources for functions before I actually build something. That way I can learn how other people with better skills have than me have done it before.
It is interesting to follow freertos line by line as it develops, I think.
Regards.
[edit: Please support: http://pozible.com/goldilocks Thanks]
With the new avrbinutils (dependency for avrlibc 1.8.0), there is a attribute tag added to avr6.x for .lowtext.
I've changed the port in AVRfreeRTOS from v8.0.0 to use this attribute defined in portmacro.h, rather than the .task attribute.
This means that there is no further reason to modify the avr6.x file, and linking just works automatically. Winning.
Hi ,
I am using WinAVR-20100110 compiler and using 2560 port.
I have few queries on the port.
  1. In the above conversion append ISR
ISR( SIG_2WIRE_SERIAL, ISR_BLOCK ISR_SECTION ) is mentioned
I am not sure where this is to appended and why.
2. In task.h and task.c if  inline void vTaskIncrementTick( void ); I get undefined reference error. Once I remove inline from .h and .c there is no error.
IS there any issue to remove inline. Is there any other work around by not removing inline.
3>I am getting the following linking error
Linking: main.elf
avr-gcc -mmcu=atmega2560 -I. -gdwarf-2 -DF_CPU=16000000UL -Os -funsigned-char -f
unsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ad
hlns=main.o  -std=gnu99 -MMD -MP -MF .dep/main.elf.d main.o heap_2.o port.o list
.o queue.o tasks.o serial.o --output main.elf -Wl,-Map=main.map,--cref     -lm
c:/winavr-20100110/bin/../lib/gcc/avr/4.3.3/../../../../avr/bin/ld.exe: section
.isr [00003026 -> 0000302b] overlaps section .data [00003026 -> 0000303b]
make: *** [main.elf] Error 1
What is this section .isr overlap section .data how do i resolve  this.
Any help would be appreciated.
Thanks in advance
Mansiha
I was going to say that someone else had this overlap error in another thread just the other day but then I realised it was YOU. I already told you that you need to find out what this ".isr" section is and why it's there.
EDIT: OK so I have a (possibly old!) copy of FreeROS on my machine so I just tried this:
/windows/FreeRTOSV8.1.0$ grep -I -R "\.isr" *
FreeRTOS/Demo/lwIP_AVR32_UC3/BOARDS/EVK1100/led.c:      AVR32_PWM.isr;
FreeRTOS/Demo/lwIP_AVR32_UC3/BOARDS/EVK1100/led.c:      while (!(AVR32_PWM.isr & (1 << led_descriptor->PWM.CHANNEL)));
FreeRTOS/Demo/lwIP_AVR32_UC3/BOARDS/EVK1101/led.c:      AVR32_PWM.isr;
FreeRTOS/Demo/lwIP_AVR32_UC3/BOARDS/EVK1101/led.c:      while (!(AVR32_PWM.isr & (1 << led_descriptor->PWM.CHANNEL)));
FreeRTOS/Demo/lwIP_AVR32_UC3/DRIVERS/MACB/macb.c:  ulIntStatus = AVR32_MACB.isr;
FreeRTOS/Demo/AVR32_UC3/BOARDS/EVK1100/led.c:      AVR32_PWM.isr;
FreeRTOS/Demo/AVR32_UC3/BOARDS/EVK1100/led.c:      while (!(AVR32_PWM.isr & (1 << led_descriptor->PWM.CHANNEL)));
FreeRTOS/Demo/AVR32_UC3/BOARDS/EVK1101/led.c:      AVR32_PWM.isr;
FreeRTOS/Demo/AVR32_UC3/BOARDS/EVK1101/led.c:      while (!(AVR32_PWM.isr & (1 << led_descriptor->PWM.CHANNEL)));
FreeRTOS-Plus/Demo/FreeRTOS_Plus_UDP_and_CLI_LPC1830_GCC/cr_startup_lpc18xx.c:__attribute__ ((section(".isr_vector")))
As you can see the only occurrence of ".isr" in any of that are in files to do with either the AVR32-UC3 chip or an NXP LPC1830 chip. I don't hit anything using ".isr" to do with ATmega so are you sure you are tying to use the correct files for ATmega2560 ?
EDIT2: I just read some of this thread. I see StuSan mentioned section(".isr") being in projdefs.h but when I look at that file in my 8.1.0 set of files it only contains:
windows/FreeRTOSV8.1.0/FreeRTOS/Source/include$ cat projdefs.h
[licence removed by Cliff]
     *    Having a problem?  Start by reading the FAQ "My application does   *
     *    not run, what could be wrong?"                                     *
     *    http://www.FreeRTOS.org/FAQHelp.html                               *
    http://www.FreeRTOS.org - Documentation, books, training, latest versions,
    license and Real Time Engineers Ltd. contact details.
    http://www.FreeRTOS.org/plus - A selection of FreeRTOS ecosystem products,
    including FreeRTOS+Trace - an indispensable productivity tool, a DOS
    compatible FAT file system, and our tiny thread aware UDP/IP stack.
    http://www.OpenRTOS.com - Real Time Engineers ltd license FreeRTOS to High
    Integrity Systems to sell under the OpenRTOS brand.  Low cost OpenRTOS
    licenses offer ticketed support, indemnification and middleware.
    http://www.SafeRTOS.com - High Integrity Systems also provide a safety
    engineered and independently SIL3 certified version for use in safety and
    mission critical applications that require provable dependability.
    1 tab == 4 spaces!
#ifndef PROJDEFS_H
#define PROJDEFS_H
 * Defines the prototype to which task functions must conform.  Defined in this
 * file to ensure the type is known before portable.h is included.
typedef void (*TaskFunction_t)( void * );
/* Converts a time in milliseconds to a time in ticks. */
#define pdMS_TO_TICKS( xTimeInMs ) ( ( ( TickType_t ) xTimeInMs * configTICK_RATE_HZ ) / ( TickType_t ) 1000 )
#define pdFALSE			( ( BaseType_t ) 0 )
#define pdTRUE			( ( BaseType_t ) 1 )
#define pdPASS			( pdTRUE )
#define pdFAIL			( pdFALSE )
#define errQUEUE_EMPTY	( ( BaseType_t ) 0 )
#define errQUEUE_FULL	( ( BaseType_t ) 0 )
/* Error definitions. */
#define errCOULD_NOT_ALLOCATE_REQUIRED_MEMORY	( -1 )
#define errQUEUE_BLOCKED						( -4 )
#define errQUEUE_YIELD							( -5 )
#endif /* PROJDEFS_H */
I just went to The FreeRTOS site and V8.2.0 is the latest so mine is not so very out of date. Yet Stu made his post in 2008 (7 years ago!). So I think you are probably using an old, out of date version of FreeRTOS?
Oh I see - is it the case you are trying to use the one in this thread? I would suggest that is unwise. Unless maintaining old code I'd always get the latest (and that would include upgrading from WinAVR2010 too!) and I'd just take whatever suggestions Stu made here for the 7 year old version and see if it needs to be applied to the latest.
Oh and as I typed this I downloaded 8.2.0. It's no surprise that the projdefs.h it contains doe not mention a section(".isr"). I think this is something the FreeRTOS authors have realised was wrong in the last 7 years and in that time it's been removed.
Will restart take the fresh files,
Merge the changes and try to make a build.
Thanks  for your guideline.
Appreciate your support.
