AVR Studio 4.18 error
9 posts / 0 new
Hello there I am trying to burn the hex file using ATMEL JTAGICE mkII ,but I get this message-"FAILED TO IDENTIFY TARGET,WOULD YOU LIKE TO RETRY WITH EXTERNAL RESET ENABLED ?",Please look at the screen shot attached to this post.I have tried to disconnect the Jtag ice device and then tried to connect and burn the .hex but the same problem persists.
I had no issues as such when I was working with these softwares but off late this has become really annoying
Following are the list of the softwares with versions installed on my system running Windows 7(64 bit)
1)AVR JUNGO USB - 10.2
2)AVR TOOLCHAIN - 3.3.0.110
3)AVR STUDIO - 4.18.716
4)AVT TOOLS - 1.00.0000
5)WinAVR - 20090313
Can someone help me to troubleshoot this issue,I have tried uninstalling the softwares and reinstalling them again.
Thanks and regards
Silly question but it is a JTAG rather than an ISP link you have made to the 2560? The picture says "JTAG"
Every day, in every way, this signature gets better and better ;-)
Nothing silly I guess ...its detecting ...please check the screenshot for confirmation
What more proof I can give that I am trying to use a JTAGICE mkII and I have used it several times before encountering this issue??thanks
Then the fact the Studio can clearly talk to the ICE and that this exact same setup (with JTAG rather than ISP selected) worked before surely says "wiring problem".
Note that the JTAGICEmkII ribbon cables have been known to break and I think Atmel have spares on their site:
EDIT: yes: http://store.atmel.com/PartDetai...
OK 10k+Superfreak will check this and get back ...but I am quite sure about the cables nothing seems to be wrong..but will check thoroughly ..thanks
That USUALLY happens if the code disables JTAG when running. I hope your JTAG header has the reset pin wired up to it.
Edit you also seem to have a strange mix of software including a very old version of winAvr.
Hello John thanks for giving some more troubleshooting hints ...well I forgot about another message thats been displayed before the AVR studio throws the error "FAILED TO IDENTIFY TARGET,WOULD YOU LIKE TO RETRY WITH EXTERNAL RESET ENABLED ?"
Attached to this post is the error message regarding the minimum voltage required for detection.I tried connecting several times and I got the target detected just once out of several tries ..
The following list is the softwares I have installed
1)AVR JUNGO USB - 10.1
2)AVR TOOLS - 1.00.0000
4)WinAVR - 20090313
Yes the softwares are old but I can't help it.Its only because of these softwares I am able to build a zero-error/warning hex file and finally burn it on the hardware.
Any other troubleshooting steps so that the target can be easily identified.
And what is your VCC? If it drops with the JTAG plugged in then you have probably a short circuit in the I/O protection chip which sits behind the cable header inside the JTAG.
