AVR-GCC-4.7.0 Toolchain for Windows
34 posts / 0 new
I compiled a Toolchain including 4.7.0 (as of 2012-17-02) for Windows, including some fixes to known bugs of this version, like the LTO-Bug, the Relax Bug, The Multilib-tiny-stack Bug. There are probably other minor bugs but it works fine for me.
It is a standalone Toolchain, but only the core Components are included. All other Tools can be taken by WinAVR or Atmels Toolchain.
It includes:
- Binutils-2.22 (as of 2012-19-02)
- Avr-Libc-1.8.0
- AVR-Dude 5.11.1
- Languages: C, C++
- Support for ATMega and ATXMega Devices!!
As stated, you can use it as standalone version, but if you are missing some tools, install WinAVR first and then replace its files with those from my Package.
This is the Download Link, size is around 11 MB.
I hope you can profit from this! For my project, which is about 16kb, it improves the size 4,1% with -Os (Optimize for size) and 1,4% with -O2 compared to Atmels most recent Toolchain which is based on gcc 4.5.1
I would like to hear your results and please report any bugs, when found, here or directly to GCC Bugzilla.
Many greetings,
Stefan
Update 02/22: Added the missing .dll file to each directory.
Thanks for the hard work, Stefan ! I'll let you know . I would've liked it to have USB_Xmega ( crt.o files ) support though, I know it wasn't under your control . :)
2) WinAvr 20100110
A) Avr Dragon ver. 1
B) Avr MKII ISP, 2009 model
C) MKII JTAGICE ver. 1
You can take a look at the appended file to see which devices are supported. Alot (or even all) ATXMegaxxxxU devices are supported and crt.o files are there. For exampe for the atxmega128a1u the file is crtx128a1u.o.
Or maybe i understand you wrong?
Edit: every device, that is mentioned in the appended file, is supported.
Please keep in mind that the xmega support is new and has not been tested by anyone besides me until now :)
Our tanks for this nice work belongs to the hard-working people from the avr-gcc department of GNU Compiler. Atmel itself has not released its sources from their xmega-supporting avr-gcc
I meant for the new xmegas with builtin USB, example Xmega32A4U .
2) WinAvr 20100110
Yep this particular device isnt supported atm.
Let me talk to the developers and see what they can do!
Maybe you could take a look and provide a list of missing devices.
That's a list I don't have .
2) WinAvr 20100110
Prior to reporting, please read http://gcc.gnu.org/bugs
There is an up-to date list of most PRs, mainly focused at avr-gcc. You can skim the lists and maybe your problem is already known, worked on or even fixed.
• www.mikrocontroller.net: avr-gcc Bugs
• gcc.gnu.org/bugzilla: avr
• AVR Libc: bugs
wow thanks you, I will test it!
LTO is working?
I tried the toolchain by overwriting it over the AS5.1 default toolchain folders (C:\Program Files (x86)\Atmel\AVR Studio 5.1\extensions\Atmel\AVRGCC\3.3.1.27\AVRToolchain) but it giving me this error when avr-gcc.exe starts and it can't compile.
Seems working in cygwin under Win7/64. I renamed the folder to C:/avr-gcc47 and added it to the beginning of the PATH, as you said winavr picks up the rest:
$ PATH=/cygdrive/c/avr-gcc47/bin:$PATH
Thanks!
$ avr-gcc --version
avr-gcc.exe (WinAVR 20100110) 4.3.3
$ avr-size -C --mcu=atmega1284p webserver6.avr-raven
AVR Memory Usage
Device: atmega1284p
Program:   73838 bytes (56.3% Full)
(.text + .data + .bootloader)
Data:      13044 bytes (79.6% Full)
(.data + .bss + .noinit)
$ avr-gcc --version
avr-gcc.exe (GCC) 4.7.0 20120217 - by SRMeister
]$ avr-size -C --mcu=atmega1284p webserver6.avr-raven
AVR Memory Usage
Device: atmega1284p
Program:   68896 bytes (52.6% Full)
Data:      13060 bytes (79.7% Full)
In INSTALL-DIR/avr/bin there should be a libiconv-2.dll.
BTW: I'd propose you could use path name with umlauts, ligatures and some chinese and khmer characters ;-)
I still have a
lto1.exe: internal compiler error: Segmentation fault
if I enable LTO (Windows 32 bits host)
Im sorry for this, its a mistake on my side.
I forgot to copy the file "libiconv-2.dll" in every directory where .exe files are. (For example where cc1.exe is)
The file is there though, you would just copy it from \AVR-Toolchain\bin to AVR-Toolchain\libexec\gcc\avr\4.7.0\
I will fix this of course, in the next release!
I compiled it under MinGW32 so didnt even know that it would work in cygwin. Nice, you got over 7% decrease in size!
Magister wrote:
I still have a
lto1.exe: internal compiler error: Segmentation fault.
Thats probably caused by the above mentioned missing libiconv-2.dll. Please tell me if this fixes your problem. Iam sorry for this! Was a little bit late when i packed the file together :)
Probably another method would be to add the \AVR-Toolchain\bin folder to your PATH variable, like dak664 did.
Edit: i updated the package in the first post to fix this issue.
Hope this helps!!
Stefan
Why would you need to make copies - you just ensure the directory where it is located is on the PATH don't you?
Every day, in every way, this signature gets better and better ;-)
This would force you to use the by setting PATH. It's great to be able to use the tools without changing *anything* in the environment.
WinAVr has always added \winavr\bin and \winavr\utils\bin to the PATH during installation - I don't think it's ever been considered a "problem".
(though it's true that if you have more than one make.exe or more than one cygwin1.dll it has caused some upset).
Yeah WinAVR did that, but my Toolchain does not have a installer, so one would have to do it by hand.
OR
as i stated in first post, first install WinAVR and overwrite its files by those in my package.
But anyways, its fixed now. No need to edit PATH
Some people complained about WinAVR changig PATH, because it can interfere with other programs.
*confused* AFAIR WinAVR installer asks if it should change PATH or not...
For anyone worried that changing PATH will break the existing tools, note PATH=foo:$PATH:bar affects only the current command window. So testing is harmless, and once you get it working you can add an alias to your .profile or .bash like alias usegcc47='PATH=foo:$PATH'. In Windows command windows it's set PATH=foo;% PATH% without the space after %
I only read about it, for example look at first 3 posts at the bottom of this page.
I always change the PATH when I test toolchain, so I know it can find the libiconv-2.dll. LTO not working may be a bug in binutils.
EDIT: binutils version is 2.22.52, not 2.23?
Well, cygwin does not like your rm.exe during a make clean, e.g. if *.map does not exist it gives an error. I renamed it to rmbad.exe to get the winavr version. The first rm below deletes the file, the second gives an error since the file is gone:
$ rm --version
rm (GNU coreutils) 5.3.0
$ rm *.map
$ rm *.map
C:\avr-gcc47\bin\rm.exe: cannot remove `*.map': Invalid argument
Just use rm -f
Well it was the makefile that showed the error and that did use -f. But it still gives an error:
$ echo 1>test.map
$ rm -f *.map
$ rm -f *.map
well, i dont understand why you're using cygwin.
These linux commandline tools are probably made with MinGW (ripped them off of AVR Studio 5), so maybe there is some incompatibility when trying to run a mingw program using cygwin.
maybe what you really need is a linux compiled version of gcc-4.7 so you wouldnt need to use cygwin to emulate the environment... idk.
people reported its working when combined with AVR Studio, when combined with WinAVR, and even standalone combined with some other IDE.
It is not intented to run in every imaginary way possible, otherwise i would have to write an installer and put a huge load of other work and research into it.
If you got THIS problem with rm.exe, just replace it with another rm.exe that works for you(or stop using cygwin). The same advice applies to any file that does not seem to be working.
Maybe it was a bad idea of me to make it "standalone" in that sense to include all these GNU command line tools.
Hello Magister,
please can you specify what command line options you used. Also, what is your OS?
please copy and paste your console output.
binutils is the most recent version of its trunk.
I have XP 32 bits, I launch the make under a command prompt. I just added the -flto flag to CFLAGS
Please submit a full bug report,
with preprocessed source if appropriate.
See for instructions.
lto-wrapper: avr-gcc returned 1 exit status
c:/avr/tools/4.7/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/ld.exe: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
Without the -flto, everything works fine.
And console output with these?
-flto -v -Wl,-v -save-temps
Not a lot of useful info, lto1.exe does a sigsegv
COLLECT_GCC_OPTIONS='-c' '-mmcu=atmega168' '-mmcu=atmega168' '-fno-move-loop-inv
ariants' '-fno-tree-loop-optimize' '-funsigned-char' '-fpack-struct' '-ffunction
-sections' '-fdata-sections' '-fno-inline-small-functions' '-mcall-prologues' '-
mstrict-X' '-v' '-save-temps' '-gstabs' '-D' 'F_CPU=16000000' '-D' 'GRAPHIC' '-O
s' '-L.' '-Lcanlib/src' '-dumpdir' './' '-dumpbase' 'obduino3.elf.wpa' '-fltrans
-output-list=obduino3.elf.ltrans.out' '-fwpa' '-fresolution=-lcan.res'
c:/avr/tools/4.7/lib/gcc/../../libexec/gcc/avr/4.7.0/lto1.exe -quiet -dumpdir .
/ -dumpbase obduino3.elf.wpa -mmcu=atmega168 -mmcu=atmega168 -mcall-prologues -m
strict-X -auxbase obduino3 -gstabs -Os -version -fno-move-loop-invariants -fno-t
ree-loop-optimize -funsigned-char -fpack-struct -ffunction-sections -fdata-secti
ons -fno-inline-small-functions -fltrans-output-list=obduino3.elf.ltrans.out -fw
pa -fresolution=-lcan.res @C:\DOCUME~1\Frederic\LOCALS~1\Temp\ccce08yy
GNU GIMPLE (GCC) version 4.7.0 20120217 (experimental) (avr)
compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0,
MPC version 0.9
GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096
MPC version 0.9
[Leaving LTRANS obduino3.elf.ltrans.out]
[Leaving LTRANS C:\DOCUME~1\Frederic\LOCALS~1\Temp\cc6oPJ8t.args]
r failed
either, it is caused by wrong PATH setting, or there is a real bug.
Maybe it is loading some libs from a wrong dir. Could you try setting your PATH in such a way, that the Toolchain dir is first dir, eg. PATH=/toolchain-4.7/bin:$PATH (or its windows equivalent).
If we do deal here with a real bug, im no expert at that, but im sure SprinterSB will try:)
There are several other toolchains I use which are easy installations under cygwin, which also tries very hard to use installed windows applications. I have not been able to get Perl serialport.pm working in any other shell, possibly this is a 64 bit .dll problem.
But the rm error is trivial and I am happy to have the 4.7.0 build option.
The only way (for me) to track it down is to reproduce this on linux host. IF it works there I have no idea.
Is there still segmentation fault without -fdata-sections?
@srmeister,
Thankyou very much. You have compiled avrdude-5.11.1 for Windows.
And it works nicely with usbasp and TPI devices !!
Yes, I even removed "-ffunction-sections -fdata-sections -Wl,--relax,--gc-sections" and it still sigsegv
