AVR32 linux toolchain
23 posts / 0 new
Last post
Hi there,
I remember that long time ago it was possible to add a repository on the host linux machine and simply do an apt-get in order to get the avr32-linuxgcc compiler (plus the rest of the utils in the toolchain).
At this point of time, it seems that I have to make a full buildroot in order to get the toolchain.
Am I right? Is there a possible way to download the avr32-linux toolchain without making the buildroot?
Cheers
The only option is Buildroot, the binary release is removed and/or no longer maintained.
Don't use the binary release if you should stumble upon it, it has numerous bugs which have been fixed in the toolchain generated by Buildroot.
Hans-Christian
Hi hce, thanks for your reply.
I have already the toolchain up and running, the thing is that I want to give it to my group mate (school project) so he will not have to run buildroot. Can I simply copy my toolchain folder and paste it in his computer? will that work?
cheers
What I typically do if I want to deploy it, is to build to /opt/avr32-linux. You can do that in Buildroot by providing O=/opt/avr32-linux (or whatever you prefer). That will make it more consistent moving it around on various machines. Hopefully all your machines are either x86_64 or x86 (-; If not, you'll need to build two variants, 32-bit and 64-bit.
Hans-Christian
Very good! I will proceed as you explained, thanks for the suggestions.
I am wondering why nobody has generated toolchains and make them available for download, so people don't have to go through the nightmare of buildroot :D The same for the filesystem images...
Cheers
Nice suggestion.
My feelings are exactly the same as those of gallacticasd.
I am a PhD student and do not have much spare time for building buildroot-avr32-v3.0.0. Also I am not an expert in Ubuntu . I have spent more than two weeks on building buildroot-avr32-v3.0.0 for NGW100. But with no success yet.
Actually I am working on JBIG image compression. Its C++ library is available at
http://tpgit.github.com/UnOfficialLeptDocs/.
I want to compile JBIG2 library for NGW100. Till now I am unable to do it due to of lack of Linux expertise, because mostly I am working with FPGAs.
I am very much frustrated.........
So, hce please build buildroot-avr32-v3.0.0 for NGW100 as you suggested above ( I have quoted your suggestion below)
And make it available to everyone (if you have time), who just want to use it.
That's interesting, what sort of work are you doing with these?
I have buildroot up and running, which problems are you facing exactly? May be I can help you.
Cheers
Thank you both gallacticasd and rsx11m for such a quick response.
I have explained my problems at the following post at avrfreks but then no one is responding to those problems there and rsx11m previously suggested me avoid opening new posts.
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=107722
The main problem I am facing now is with mirror site.
I followed the suggestions of rsx11m from one of his post for changing mirror site but then I got the following problem.
Resolving www.at91.com... 217.16.6.11
Connecting to www.at91.com|217.16.6.11|:21... connected.
Logging in as anonymous ...
It stucked at this point and then automatically continued after long time. But when finished then my C++ project is not working with it.
My C++ project is showing the following error (Please note that my C++ project is compiling with g++ but not compiling with avr32-linux-g++)
root@khursheed-desktop:~/Build/EXE_Ubuntu/jbig2encoder# make
avr32-linux-g++ -o jbig2 jbig2.cc -L. -ljbig2enc /usr/local/lib//liblept.a -I/usr/local/lib//src -Wall -I/usr/include -I/usr/local/include/leptonica -I./ -L/usr/lib -O3 -lpng -ljpeg -ltiff -lm -lz
In file included from /home/khukhu/Build/buildroot-avr32-v3.0.0/output/staging/usr/bin-ccache/../lib/gcc/avr32-unknown-linux-uclibc/4.2.4/../../../../avr32-unknown-linux-uclibc/include/c++/4.2.4/iosfwd:45,
from /home/khukhu/Build/buildroot-avr32-v3.0.0/output/staging/usr/bin-ccache/../lib/gcc/avr32-unknown-linux-uclibc/4.2.4/../../../../avr32-unknown-linux-uclibc/include/c++/4.2.4/bits/stl_algobase.h:70,
from /home/khukhu/Build/buildroot-avr32-v3.0.0/output/staging/usr/bin-ccache/../lib/gcc/avr32-unknown-linux-uclibc/4.2.4/../../../../avr32-unknown-linux-uclibc/include/c++/4.2.4/vector:66,
from jbig2.cc:18:
/home/khukhu/Build/buildroot-avr32-v3.0.0/output/staging/usr/bin-ccache/../lib/gcc/avr32-unknown-linux-uclibc/4.2.4/../../../../avr32-unknown-linux-uclibc/include/c++/4.2.4/avr32-unknown-linux-uclibc/bits/c++locale.h: In function 'int std::__convert_from_v(int* const&, char*, int, const char*, ...)':
/home/khukhu/Build/buildroot-avr32-v3.0.0/output/staging/usr/bin-ccache/../lib/gcc/avr32-unknown-linux-uclibc/4.2.4/../../../../avr32-unknown-linux-uclibc/include/c++/4.2.4/avr32-unknown-linux-uclibc/bits/c++locale.h:111: error: 'vsnprintf' is not a member of 'std'
Please help me in this problem
Ok, lets try to get the mirror thing fixed first.
Whenever a software package is not downloading you will get an error and buildroot will stop (if it is not stopping and it keeps retrying pres Ctrl+C and stop the build manually).
Solution:
Check the name of the software package that cannot be downloaded and go to http://www.atmel.no/buildroot/source/mirror/ download exactly the same version that is required by buildroot. If the sources are not available there look for the same version in sourceforge or google code. Download them to your linux box.
Move the sources you have just downloaded to the folder dl in the buildroot directory.
Resume the compilation by typing make sources.
This always fixes the problem of failing downloads. If you do this, Buildroot will see the required sources in the dl folder, therefore it will avoid downloading them again.
Buildroot is continuing because it is skipping the package you are trying to download. I assume that this package has some libraries you need for your project and the whole thing is crashing when you are compiling it.
Cheers
Thank you gallacticasd.
I will try this method now. hce also suggested this kind of method but it was not clear to me for where to place the download file. Now you cleared to to place it in dl folder.
thank you once again. please be with me till the end of build process.
Pages
