Difference between ATmega328, 328P and 328PU
17 posts / 0 new
I got some chips in from Digi-Key, which were giving me the wrong signature byte. Here's what avrdude said about them:
avrdude: Device signature = 0x1e9514
    avrdude: Expected signature for ATMEGA328P is 1E 95 0F
    Double check chip, or use -F to override this check.
I sent a query about this to Digi-key. Their response is confusing me a bit, hoping someone could clarify.
The order was for 4 ATMega328p processors - Digi-key part #ATMEGA328-PU-ND.
The response from Digi-key was
"The ATMEGA328-PU-ND is NOT a ATMEGA328P it's a ATMEGA328 so the signature should NOT
match"
Aside from the fact that what I ordered was a 328p and they seem to be telling me they sent a 328, I can't find a definitive statement of what the difference between -P and -PU is. Clarification would be welcome.
Not -P but just P. ATMega328 and ATMEGA328P are almost same chips but manufactured with different tecnological processes. The suffix (-P, -PU etc.) shows just a package related information which is clearly described in RTFM.
328P is not the same as 328-PU. The P in the first case indicates picopower. The P in the second case indicates the package (PDIP). If you wanted the picopower chip in a PDIP package, you should have gotten ATMEGA328P-PU.
Steve A.
I think you'll find the differences are just in the silicon and affect the power consumption. In terms for functionality and pin compatibility (and programming) there is no difference.
--greg
Still learning, don't shout at me, educate me.
Starting the fire is easy; the hardest part is learning how to keep the flame!
So the signature bytes will be different then?
Not quite true. There are a couple of differences that could be important when using the picopower functionality. For one, the BOD disable is not available on the non-P part.
Yes, they are different chips.
Steve A.
Granted.
Very, very similar, though not identical, then ;)
--greg
I got caught out by this at first, confusing the PU with picopower. IIRC the part of TFM (or datasheet) you need to refer to is Ordering Information. :wink:
Bummer, doesn't look like avrdude supports 328. Guess I'll have to do some reading to add it to my config file.
It's trivial. Just copy the existing 328x entry, and paste it after that section, then replace the sig bytes. Done.
--greg
Great, easy is good, avrdude sees them now.
Greg,
  Sorry could you give me more information as to how I would go about doing this?
uptime,
  Were you able to get avrdude to work with the 328-pu?  I am fine with power consumption of these chips I just want to be able to program with avrdude.  If you got this to work can you get me detailed information as to how I would go about doing this?
@avrhick, you do realize that you have asked for information in a thread that is 3 years old.wink
The latest versions of Avrdude support the 328-pu.  What version of Avrdude are you using and on what OS?
"When you arise in the morning think of what a privilege it is to be alive: to breathe, to think, to enjoy, to love." - Marcus Aurelius
@Laryvc,  I did not notice that the thread was that old.  My bad. Perfect first impression right lol.
I am using the avrdude version 5.1 on windows 8.1... I might have to look at updating my avrdude, but until then.
I actually found my own answer.  For anyone looking at this post in the future ->
1) Find your avrdud.conf file
2) Make an original copy of .conf file
3) edit original file in Notepad or Notepad++
-> Find Atmega328P configuration and copy it below... change your id to m328x and change your signature to 0x1e 0x95 0x14.
Hope this might help someone out in the future if this comes up again.
OK. Just for clarification:
The ATMega328 is a microcontroller chip, the theoretical reference design.
ATMega328-PU is the microcontroller in a DIP package.
ATMega328 SMD is the other, surface mount version of the 328, with 2 extra analogs.
ATMega328P is the ATMega reference design with the picoPower low voltage running capability, available in PU and SMD versions
ATMega328P-PU is the most common ATMega found on Arduino UNOs and other boards. This is possibly the easiest to work with when making your own duino.
ATMega328P SMD is the chip found on Lilypad and Nano boards and boasts two extra analogs.
I hope this helps!!
--AVR Helper
2 years late but it may help someone else. And by the way you forgot the Mega328PB.
