4-channels pwm generation
14 posts / 0 new
Hi
I use ATXMEGA128A1 and the following code for 4-channels pwm generation:
void pwmSet(u08 channel, u16 value)
// Setup timer
TCC0_CTRLA = 0x01; // divide clock by 1
TCC0_PER = 0x0FFF; // set resolution to 12 bits
switch(channel){
case 0:
TCC0_CCA = value; // duty cycle A
break;
case 1:
TCC0_CCB = val;   // B
break;
case 2:
TCC0_CCC = val;   // C
break;
case 3:
TCC0_CCD = val;   // D
TCC0_CTRLB = 0xF3; /* enable frequency generation for all 4 Channels */
there is a problem. it is only channel D (PE3) does not work!
all for pins has set as outputs.
PE4 & PE5 are used as inputs and PE6 & PE7 as Rx1/Tx1 uart.
have I to replace ATXMEGA128A1 ? or it is a software issue ?
regards
TCC0 outputs are on PORTC and PE3 is a pwm output for TCE0.
Ozhan KD
Knowledge is POWER
sorry
I use both 4-pwm-channels of TCC0 and TCE0
TCC0 is good and the problem is only in channel D of TCE0
I cannot see any reason for your problem. Did you see the PE3 output by a scope?
Ozhan KD
Knowledge is POWER
no,
did you successfully drive all 16 pwm channels?
my issue is not a bug in xmega128a1 ?
ATXMEGA128A1 has 24 pwm outputs. What do you mean about "all 16 pwm channels"?
Ozhan KD
Knowledge is POWER
I see 28 OCxx/ns pins on ATXMEGA128A1 part but I mean those four quad ones (4x4=16).
Has anybody successfully driven all four pwm channels of PE0-PE3 ?
Only in your last post do you make clear you want PE0-PE3 as PWM !
You don't set ANY channels on PortE in the code you gave ! Do the same thing you did for PORTC.
2) WinAvr 20100110
A) Avr Dragon ver. 1
B) Avr MKII ISP, 2009 model
C) MKII JTAGICE ver. 1
yes
TCC0_xxx has replaced with TCE0_xxx
AVR Studio 5.0
MKII ISP model 2009
I don't understand your last post, but is it working now ?
2) WinAvr 20100110
no
Here,
I did it and it works fine.
#include"avr_compiler.h"
#include"TC_driver.h"
void main()
 PORTE_DIRSET=PIN3_bm|PIN2_bm|PIN1_bm|PIN0_bm;
 TC_SetPeriod(&TCE0,256);
 TC0_ConfigWGM(&TCE0,TC_WGMODE_SS_gc);
 TC_SetCompareA(&TCE0,128);
 TC_SetCompareB(&TCE0,64);
 TC_SetCompareC(&TCE0,32);
 TC_SetCompareD(&TCE0,16);
 TC0_EnableCCChannels(&TCE0,TC0_CCAEN_bm|TC0_CCBEN_bm|TC0_CCCEN_bm|TC0_CCDEN_bm);
 TC0_ConfigClockSource(&TCE0,TC_CLKSEL_DIV1_gc);
 while(1);
Ozhan KD
Knowledge is POWER
navidnavid, 'designer's code is one way, but you can also do for PORTE what you did for PORTC, as I've stated in a post. WHY haven't you tried that ( that's my impression from how you post ) ?! I've written code for TEN PWM channels on an XMEGA, code looks JUST like your PORTC code and it all works right. Show YOUR code for PORTE .
2) WinAvr 20100110
tanx
It seems that I have to replace chip
