SPI on ATXMEGA32A4 PORT D
7 posts / 0 new
I am interfacing with PIC MCU via SPI. I am sending 32 bits of data to the PIC. I have configured SPID on PORTD as a slave and the SPI port on the PIC is the master. The XMEGA is reading and processing data from an ADC and conveys it to the PIC. When a packet of data is ready, the PIC expects the MISO pin (PD6) to go low. It then initiates the data transfer.
The problem is with PD6. I set it as an output:
PORTD.DIRSET = SPI_MISO_bm;
And then toggle it high
PORTD.OUTSET = SPI_MISO_bm;
to let the PIC know that data is not ready. I later toggle it low
PORTD.OUT &= ~SPI_MISO_bm;
when the data is ready.
When I probe PD6 with my DMM, it is always low (0.001V or so). If I don't configure the SPID, PD6 goes high and low as expected. But if SPID is on, the functionality seems to be lost. I am using an AvrDrago and can toggle the pins directly: same thing, if SPID is on, PD6 doesn't budge from 0V.
When the SPID is on, PD6 is in tri-state. So maybe my DMM is pulling it low. But this doesn't seem to be right since the DMM has a pretty high input impedance.
I am not sure why PD6 is acting this way.
Thank you,
Dmitry
If you want the Xmega to initiate a data transfer make it the SPI master and the PIC the slave.
By enabling SPI module in slave mode, MISO function overrides normal pin function and this pin cannot be used as a general IO.
Ozhan KD
Knowledge is POWER
ArnoldB,
Thank you for your reply.
That would be great! But I didn't write the PIC firmware and can't alter it. It is looking for a slave. Essentially, the Xmega is a bridge for at LTC2492 ADC chip (http://www.linear.com/product/LT...). I am adding some other capabilities in the Xmega but as far as the PIC is concerned, it is talking to the ADC chip. So I have to mimic the ADC's behavior with the Xmega. That's why I have to mess with the MISO pin.
Dmitry
Ozhan,
Thanks for the reply. I feared that this might be the case.
Can you think of a way to work around this?
Dmitry
dmitry1001 wrote:
Ozhan,
Since you didn't thank me, I assume you don't want to have a suggestion from me. Fine with me.
ArnoldB,
Sorry for my bad manners. I am very thankful for your input and modified my original post to express my thanks.
Dmitry
