programming an xmega with avrdude using PDI interface
3 posts / 0 new
I am trying to program an xmega with avrisp mkII using PDI interface by avrdude. I am getting an error.
avrdude -p x128a1 -P usb -B5 -c avrisp2 -U flash:w:AES_example_interrupt.hex:i
avrdude: stk500v2_command(): error in CMD_XPROG_SETMODE: Unknown
avrdude: stk600_xprog_program_enable(): CMD_XPROG_SETMODE(XPRG_MODE_PDI) failed
this check.
avrdude: stk500v2_command(): error in CMD_XPROG: Unknown
avrdude: stk600_xprog_program_disable(): XPRG_CMD_LEAVE_PROGMODE failed
avrdude done. Thank you.
make: *** [flash] Error 1
Can anyone help me please to solve this issue? I am a beginner in this field.
Thanks.
Please check your connections. What board are you using? Are you using an Atmel AVRISPmkII or a clone?
https://www.mattairtech.com/
ARM Cortex M and XMEGA development boards / Gentoo Linux
Also check that your AVRISPmkII is fully up to date, as PDI was only added to later firmware versions. Unfortunately the only way to upgrade the firmware I know of is to use AVRStudio.
