Error AVR
9 posts / 0 new
Hello !
I have a weird problem with lot of my code.
Yesterday the code work very well, didn't change anything.
This code is a simple example and i have an error with this one too.
#include
#include
// Standard Input/Output functions
#include
void main(void)
int i;
delay_ms(3000);
///////////////////// Port D initialization \\\\\\\\\\\\\\\\\\\\\\\\
PORTA=0x00;
DDRA=0x00;
PORTB=0x00;
DDRB=0xFF;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0x00;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: On
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud Rate: 9600
UCSRA=0x00;
UCSRB=0x18;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x19;
////////////////////////// Pogramme \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
PORTB=~0xFF;
delay_ms(1000);
printf("U");
i=getchar();
if (i==0b00000110)
  PORTB=~0xF0;
  delay_ms(3000);
  PORTB=~0x01;
  delay_ms(3000);
And that it's my error !
Error: C:\Users\DOUKI\Desktop\Projet 2011\Developpement AVR\uDrive\Udrive1.c(72): function argument #1 of type 'flash unsigned char [2]' is incompatible with required parameter of type 'const unsigned char *'
And one again i didn't touch anything since yesterday.
Then why did you rebuild? :twisted:
Are you using the same compiler version?
Is this CodeVision? It compiles cleanly for me with 1.25.9 and 2.04.5.
Yesterday it worked perfectly, and now all my code have this error.
You know when you write "int" it like that int bold text, but now when i write "int" or "char" it's not bold text.
And i use he same version of Codevision AVR, i didn't change anything.
Ok thank you
Problem solved, i have a wrong stdio.h file
It seems that something >>did<< change...
It was not me, my brother use my computer and he restoring trash.
SO the stdio was in the trash.
You really should set up individual user accounts to prevent things like this from happening.
Hi everyone! I know that it is very old topic, but it is most common to my issue. May be, it could help someone later.
I made a new project and copied full old code to new *.c file, then changed it a little. I really did Not touch anything in functions or const definition.
And I did not use <stdio.h> at all (but I tried to include it also - no profit).
Building my new code comes full of such errors:
function argument #1 of type 'const unsigned char [17]' is incompatible with required parameter of type 'flash unsigned char []'
I tried to open CodeWizard and generate *.c file, then I delete everything in that *.c file and fully copied my new code from project with errors.
Tadaaam! It was compiled without errors, but I really did not understand WTF happened with compiler and what a crazy error "const != flash" it gave without CodeWizard.
After some brain-f**king I've found that there are a setting named "Store Global Constants in FLASH Memory" in the Project -> Configure.
Checking this setting let the compiler work without "const != flash" errors.
So, the summary is that you created a new >>project<<, copied the >>code<< from the old project, but made no attempt to compare the project settings for the old and new projects.
Indeed, just on the "main" project panel there are probably a dozen or more configuration options that can make a great difference.  Add onto that the settings where you enter a number.
In the end, hardly a surprise.  And while this appears to be CodeVision, the same situation could well happen with e.g. Studio and the married GCC.
