Timer1 in Atmega16
6 posts / 0 new
I want to generate PWM using Timer1
Crystal oscillator= 8MHz
Timer1 Prescale=8
so one timer tick is of 1us.
for 2ms high pulse, 2ms/1us= 2000
so S1=65535-2000=63535
for 18ms low pulse, 18ms/1us=18000
so prescale= 65535-18000=47535
By using S1, and prescale value, i wrote the code. When i check the simulation on ISIS protesus, i m getting 8 times high and low pulse.
Can anybody help?
the code is
$regfile = "m16def.dat"
$crystal = 8000000
Config Timer1 = Timer , Prescale = 8
On Timer1 Servoirq
Config Portd.0 = Output
Portd.0 = 0
Dim Preload As Word
Dim S1 As Word
Dim I As Byte
  Preload = 63285
   S1 = 47535
Enable Timer1                                               'required in any case
Enable Interrupts                                           'required in any case
Do
Loop
End
Servoirq:
If Portd.0 = 0 Then
  Timer1 = S1
  Portd.0 = 1
Else
  Portd.0 = 0
  Timer1 = Preload
End If
Return
A mega16 by default clocks at 1MHz. Presumably there's a setting in Proteus where you tell it that the chip is actually running at 8MHz? Have you changed this option?
hmmm. I was thinking that statement $crystal = 8000000 will do this job, but i was wrong.
In proteus, when i set CKSEL Fuses to Int. RC[8MHz]. i get right 2ms and 18ms pulses.
Then why not use PWM mode?
Steve A.
It is common that you need to have one setting telling your tool chain (compiler, assemblerm whatever..) the CPU speed so that it can generate correct code (e.g. calculating correct UBBRnx values for USART baud rates), AND one setting to tell the actual system what clock it should use. For the latter there is e.g. a setting in AVR Simulator, on real chips it is determined in part by fuses etc...
Warning: In another thread OP has already admitted to using a stolen copy of Bascom so it seems likely the Proteus is also stolen. As such I'll leave it for you to decide if you still want to provide support in this thread.
Moderator.
