DYNDNS: alternative to using a computer
Last post
9 posts / 0 new
hi,
I have a machine running at a customer site. Great. (it happens to use an ATMEGA128 which is why i'm posting this at avrfreaks)
It has an HMI interface that can be accessed from the internet. HOWEVER, the site has a dynamic IP. So I have a computer down there running the DYNDNS client software, and I use a domain from dyndns to be able to accessed the machine. The HMI does not provide any tools to update a dynamic IP.
However, if that computer running the client software goes down (or goes to sleep), then when the IP address changes, the domain doesnt get updated.
OK, that sucks, but what is worse is that in the future I dont want to put a computer down with every machine.
I am using the XNUT-100 from proconyx. It has an ethernet port. Does anyone know how I can update the new IP address straight from the controller so I dont require a computer?
Alternatively, is there a din rail mounted device that can acts as a host for the DYNDNS client software?
Unless otherwise stated:
uC: ATMega128 or 644P
Compiler: Imagecraft ICCAVR V7.2
Debugger: AVRstudio 4.16
Programmer: Atmel, JTAG MKII
Experience: 20 years of C
Dismal ASM skills
Why not add a DynDNS updater to the firmware. The protocol is most likely open and documented.
/Jesper
http://www.yampp.com
The quick black AVR jumped over the lazy PIC.
What boots up, must come down.
Seems like dyndns update is a "http request". This one
http://forum.dyndnscommunity.com/forum/viewtopic.php?p=4865&sid=87212020049baeeb564050c8f511ded8#p4865
Suggests this
http://user:pw@members.dyndns.org/nic/update?hostname=host.domain.com
More hints
http://www.readynas.com/forum/viewtopic.php?f=11&t=16176
And the XNUT-100 is using NUT/OS
http://www.proconx.com/xnut100/
Witch can do http requests.
I'd try the "updating" using a plain browser on a pc first , and when it works , i'd incorporate "the html request" in NUT/OS.
Note you wont need wget (as wget is just used as a "commandline" browser here).
/Bingo
The syntax is posted here...
http://www.dyndns.com/developers/specs/syntax.html
-Tim
hmm, my previous post never made it.
I said "thanks!"
however I am have some more spoecuifics that make even these suggestions challenging. First I am using the controller but not the nut/OS. I have a few time critical things that needs done and I wasnt ready to entrust the overhead of an operating system with that.
Too badm because it looks like a lot of headache could be removed if I just used the nut/Os tools for modbus and now http.
since I dont have the nut/os kits, does anyone know the basics of setting up the ethernet port and creating the proper format and parsing for IP so I can use it for this?
Or am I looking at a whole course in IP to get my head around this?
Dismal ASM skills
Have you heard of Adam Dunkel's uIP?
http://www.sics.se/~adam/uip/index.php/Main_Page
There are a number of ports to various AVRs and Ethernet controllers. The documentation is pretty good.
I beleive that there are already examples for HTTP. Certainly a server.
-Tim
As an alternative, how about a linksys WRT54GL running the Tomato firmware? It happily supports DDNS (I know this from happy experience). Cost is well under $100.
Huh?
Typically, a microprocessor with a LAN interface (like ethernet 802.3) interfaces to a LAN, not a WAN. The micro has a private LAN IP address. The router that faces the WAN would have a public IP address.
If the microprocessor sends mainly to one server, as is often the case with control apps, then the micro can send UDP or do a TCP connection to the server that it is configured to use. Then there's no need for dyndns.
As long as the micro know there is an IP change, it can send the proper request for a DynDNS change, even if it's on the LAN.
Anyway, the micro itself could be connnected directly WAN, usually it looks just like any other network segment with a DHCP server.
/Jesper
