SPI
6 posts / 0 new
Hi!
How can I get two AVR8515 to talk to eashother. I´ve tried with SPI but I don´t now how to implement it. I´ve tried many diffrent way but nothing seems to work.
I´m using CodeVision compilier maybe there are some limits in this?
admin's test signature
Here's some code a friend of mine once wrote. There are two files. One for master 8515, and another for slave 8515.
Master 8515:
/* code example: SPI master
compiled using IAR Embedded Workbench 1.51C
#include "iom163.h"
#include "ina90.h"
#define MOSI DDB5
#define MISO DDB6
#define SS DDB4
#define SCK DDB7
unsigned char data = 0;
interrupt [SPI_STC_vect] void ISR_SPI(void)
SPDR = data++; //send the value of data and increment data
void main(void)
// Data direction of SPI lines
DDRB |= 1<<MOSI; //Output
DDRB |= 0<<MISO; //Input (Automaticly set as input in master mode)
DDRB |= 0<<SS; //Input (Should be output on multi-master bus)
DDRB |= 1<<SCK; //Output
//SPI mode
SPCR |= 1<<MSTR; //select SPI master mode
SPCR |= 1<<SPIE; //Enable SPI interrupt
SPCR |= (1<<SPR1)|(1<<SPR0); //setting SPI speed fck/128
SPCR |= 1<<SPE; //Enable SPI
_SEI(); //Enable global interrupts
SPDR = data; //Transmit the value of data trough SPI
//and increment data
while(1); //loop for a while
Slave 8515:
/* code example: SPI slave
#include "iom163.h"
#include "ina90.h"
#define MOSI DDB5
#define MISO DDB6
#define SS DDB4
#define SCK DDB7
PORTD = ~SPDR; //Place the received value on PORTD
void main(void)
//Data direction on PORTD
DDRD = 0xff; //All pins used for output
DDRB |= 0<<MOSI; //Input (Automaticly set as input in slave mode)
DDRB |= 1<<MISO; //Output
DDRB |= 0<<SS; //Input (Automaticly set as input in slave mode)
DDRB |= 0<<SCK; //Input (Automaticly set as input in slave mode)
//SPI mode
SPCR |= 0<<MSTR; //select SPI master mode
Does this do the trick? If you're using assembly, it's pretty straightforward conversion...
Corinthian
Hi!
Thanks!
We wonder were we can find the headerfiles that are included in the code.
Lars
Those are included in the IAR compiler he's using. Other compilers will use other header files. What compiler are you using? If it's made for AVR, there should be a corresponding file. I could mail them to you if I've got the right one, provided I get your e-mail address :)
The iom163 file contains definitions such as DDRB and SPE, e.g. links between these names and the appropriate memory addresses. The ina90 contains intrinsic commands such as SEI(); Look for files containing these definitions.
Corinthian
Hi!
We are using the CodeVision compiler but we also have the IAR compiler but we can´t find the iom163.h file. It would be nice if you could mail it to us. My emailadress is:peha1377@student.uu.se
Per Hammer
I've sent the ones I found to you. They're IAR compiler files, but you'll probably be able to port them for such simple code.
Corinthian
