zoAvrLib
7 posts / 0 new
Hello everybody :).
Today I published the following two projects:
- zoAvrLib (Mega AVR function library for AVR-GCC)
- supermodified (Transform a hobby servo to a full DC motor controller)
Source code, schematics etc are included.
Any questions/clarifications are welcome.
As I intend to constantly improve them,
I would very much appreciate comments, feedback
on functionality/wanted features etc.
I do not want to hide that I am the co-owner of a small company that sells the supermodified PCBs. I still think that the source code provided in the projects might be of interest to many.
The zoAvrLib is not commercial in any way.
Thanks in advance!
Giannis
This intrigued me as you don't actually say what kind of functionality. I thought your project description would sate my curiosity - but it doesn't either. For others the actual Zip contains:
zoBuffer.c
zoBuffer.h
zoError.c
zoError.h
zoI2c.c
zoI2c.h
zoMcu.h
zoString.h
zoSystemTimer.c
zoSystemTimer.h
zoTypes.h
zoUart.c
zoUart.h
That may give some hint of what the library offers but without extracting the .h's it's still a bit of mystery. (the names hint at good things though!)
Online documentation for the Library can be found here:
http://www.01mech.com/sites/default/files/zoAvrLibHtml/index.html
Ah, that's more like it. But just to note that:
http://www.01mech.com/sites/defa...
mentions a zoAdc.h that is NOT in the .zip. BTW why on earth have you done this:
typedef uint8_t  u08
  unsigned 8-bit integer
typedef int8_t  s08
typedef uint16_t  u16
  unsigned 16-bit integer
typedef int16_t  s16
typedef uint32_t  u32
  unsigned 32-bit integer
typedef int32_t  s32
typedef uint64_t  u64
  unsigned 64-bit integer
typedef int64_t  s64
The whole point of stdint.h is to provide standard type names - why over-ride this?
There is actually a bigger picture behind this.
I use the same typedefs in other libraries (and compilers) I have
(eg TI's microcontrollers) for uniformity.
In the near future I plan on publishing these too.
But it was in 1999 that the C99 standard introduced stdint.h? Would it not make sense to adopt it after eleven years?
You are right :).
I am now convinced that it would be best this way.
(I am a bit stubborn I guess...)
In the next revision I will update this.
Thanks!
