Simple UV Exposure Timer
4 posts / 0 new
Simple exposure timer with relay output to control a UV source.
With the realy output pretty much any UV source can be controlled as long as you make sure that the relay is correctly rated for the job.
In my project i use a UV LED pannel, construction of which can be found at
http://www.instructables.com/id/...
Thank you, was needed an example of how assembled a exposure box... can extend the time to exposure???
Hi Sax,
the box can be made from the instructable web site, or as i did just knock one up of your own design. The design on the instructable web site shows a double sided design, which is better than mine as mine is only single sided. I simply expose one side at a time.
As for extending the exposure time, change the prescalar value at the top of the uv-timer.c file, currently it is
#define PRESCALAR 100*30
for 30 seconds a segment, change this to 100*60 for 60seconds persegment.
From what i understand, most pre-sesnsitized pcb board only take from 30s to 5mins to expose so thats why chose those the values. Also it divided by 10 for the 10 segment display.
Here's a simple UV exposure unit I made from MDF and some pieces of square section wood:
http://www.leonheller.com/Photos/UV%20unit.jpg
A sheet of glass rests on the upper wood strips. The wood and MDF are held together with wood screws and adhesive.
I use an exposure time of 11 minutes. I keep meaning to add another UV tube, it should reduce the exposure time to five minutes or so.
Leon
Leon Heller G1HSM
