STK200 Signature errors, and Lockbit trouble
2 posts / 0 new
If you have had trouble with some of the problems below, the cure is here.
Upgrade the isp.ini with this new bebugged version!
rgds
webmaster
avrfreaks.net
The Patch file corrects:
- AT90S8535 Lock Bit Programming
- AT90S1200 Signature Byte Check
- AT90S2323 Signature Byte Check
- AT90S4434 Signature Byte Check
- ATmega103 Signature Byte Check
- ATmega603 Signature Byte Check
How to use:
- Install AVR ISP version 2.65.
- Replace the initialization file (isp.ini) with the one from this patch.
How it works:
The 'isp.ini' file describes the complete programming sequence to the AVR ISP software. The original file had some bugs.
I have a problem with programming a AT90s1200 device.
I get always programming error at 45%.
I can erase en reed the device, but i can't program them.
I have a STK200 kit and Windows Millenium.
admin's test signature
