[Give away] KS0108-diplay driver
2 posts / 0 new
Hello all!
I have finished my diver code for a KS0108 display and here is the code!
I hope some one may have use of it.
See pics for examples of what it can do:
http://img187.imageshack.us/img1...
Enjoy! :D
Note: The line and circle code is not mine from the beginning.
I found them on Wikipedia and made them work with my code.
- Note -
This code is made for a AVR Mega168 running at 8MHz.
I can not promise that it will work on other µC.
Info - How to use the commands.
1. LCD_Fill_Screen();
This command will fill the screen with pixels.
2. LCD_Clear_Screen();
This command will clear the screen of pixels.
3. LCD_Draw_Dot(x, y);
This command will draw a dot at the specified x, y location.
4. LCD_Clear_Dot(x, y);
This command will clear a dot at the specified x, y location.
5. LCD_Draw_Line(x1, y1, x2, y2, clr);
This command will draw a line from the specified cordinates (x1, y1) to the specified cordinates (x2, y2).
If clr is 1 it will clear all pixels of the line and if it is 0 it will draw a line.
6. LCD_Draw_Rect(x1, y1, x2, y2, fill, clr);
This command will draw a box from the specified cordinates (x1, y1) to the specified cordinates (x2, y2).
if fill is 1 it will fill the box and if it is 0 it will just make the outline of a box.
If clr is 1 it will clear all pixels of the box and if it is 0 it will draw the box.
7. LCD_Draw_Circle(x, y, R);
This command will draw a circle at the specified cordinates (x, y) with the radius 'R'.
8. LCD_Write_Char(x, y, 'char');
This command will draw a character ('char') at the specified cordinates (x, y), the x and y cordinates determins the character's top-left pixel.
9. LCD_Write_String(x, y, "string");
This command will draw a string ("string") at the specified cordinates (x, y), the x and y cordinates determins the string's top-left pixel.
#include
#include
#include
#define F_CPU					8000000
// ---- LCD Definitions ----
#define LCD_DATA_PORT 			PORTD
#define LCD_DATA_PIN 			PIND
#define LCD_DATA_DDR 			DDRD
#define LCD_CONTROL_PORT 		PORTC
#define LCD_CONTROL_PIN 		PINC
#define LCD_CONTROL_DDR 		DDRC
#define LCD_RS 					0
#define LCD_RW		 			1
#define LCD_ENABLE 				2
#define LCD_CS1_PIN 			3
#define LCD_CS2_PIN 			4
#define LCD_RESET				5
#define LED_PORT				PORTB
#define LED_PIN					0
#define PWM_PIN					1
#define DISPLAY_ON				0b00111111
#define DISPLAY_OFF				0b00111110
#define DISPLAY_STATUS_BUSY		0b10000000
#define DISPLAY_STATUS_ON_OFF	0b00100000
#define DISPLAY_STATUS_RESET	0b00010000
#define DISPLAY_LINE			0b11000000
#define ADDRESS_X				0b01000000
#define ADDRESS_Y				0b10111000
#define SET_CS1() 				(LCD_CONTROL_PORT |= (1<<LCD_CS1_PIN))
#define CLEAR_CS1() 			(LCD_CONTROL_PORT &= ~(1<<LCD_CS1_PIN))
#define SET_CS2() 				(LCD_CONTROL_PORT |= (1<<LCD_CS2_PIN))
#define CLEAR_CS2() 			(LCD_CONTROL_PORT &= ~(1<<LCD_CS2_PIN))
#define SET_ENABLE()			(LCD_CONTROL_PORT |= (1<<LCD_ENABLE))
#define CLEAR_ENABLE()			(LCD_CONTROL_PORT &= ~(1<<LCD_ENABLE))
#define SET_RW() 				(LCD_CONTROL_PORT |= (1<<LCD_RW))
#define CLEAR_RW() 				(LCD_CONTROL_PORT &= ~(1<<LCD_RW))
#define SET_RS() 				(LCD_CONTROL_PORT |= (1<<LCD_RS))
#define CLEAR_RS() 				(LCD_CONTROL_PORT &= ~(1<<LCD_RS))
const unsigned char char_array[26][5] PROGMEM =
	{0b01111110, 0b10010000, 0b10010000, 0b10010000, 0b01111110}, //A
	{0b11111110, 0b10010010, 0b10010010, 0b10010010, 0b01101100}, //B
	{0b01111100, 0b10000010, 0b10000010, 0b10000010, 0b01000100}, //C
	{0b11111110, 0b10000010, 0b10000010, 0b01000100, 0b00111000}, //D
	{0b11111110, 0b10010010, 0b10010010, 0b10010010, 0b10000010}, //E
	{0b11111110, 0b10010000, 0b10010000, 0b10010000, 0b10000000}, //F
	{0b01111100, 0b10000010, 0b10010010, 0b10010010, 0b01011100}, //G
	{0b11111110, 0b00010000, 0b00010000, 0b00010000, 0b11111110}, //H
	{0b10000010, 0b11111110, 0b10000010, 0, 0}, 				   //I
	{0b00001100, 0b00000010, 0b00000010, 0b00000010, 0b11111100}, //J
	{0b11111110, 0b00010000, 0b00101000, 0b01000100, 0b10000010}, //K
	{0b11111110, 0b00000010, 0b00000010, 0b00000010, 0b00000010}, //L
	{0b11111110, 0b01000000, 0b00100000, 0b01000000, 0b11111110}, //M
	{0b11111110, 0b01000000, 0b00111000, 0b00000100, 0b11111110}, //N
	{0b01111100, 0b10000010, 0b10000010, 0b10000010, 0b01111100}, //O
	{0b11111110, 0b10010000, 0b10010000, 0b10010000, 0b01100000}, //P
	{0b01111000, 0b10000100, 0b10000100, 0b10000110, 0b01111010}, //Q
	{0b11111110, 0b10010000, 0b10011000, 0b10010100, 0b01100010}, //R
	{0b01100100, 0b10010010, 0b10010010, 0b10010010, 0b01001100}, //S
	{0b10000000, 0b10000000, 0b11111110, 0b10000000, 0b10000000}, //T
	{0b11111100, 0b00000010, 0b00000010, 0b00000010, 0b11111100}, //U
	{0b11100000, 0b00011100, 0b00000010, 0b00011100, 0b11100000}, //V
	{0b01111100, 0b00000010, 0b00011100, 0b00000010, 0b01111100}, //W
	{0b10000010, 0b01101100, 0b00010000, 0b01101100, 0b10000010}, //X
	{0b11100000, 0b00010000, 0b00011110, 0b00010000, 0b11100000}, //Y
	{0b10000110, 0b10001010, 0b10010010, 0b10100010, 0b11000010}  //Z
const unsigned char schar_array[26][5] PROGMEM =
	{0b00011110, 0b00100100, 0b00100100, 0b00011110, 0},		   //a
	{0b00111110, 0b00101010, 0b00101010, 0b00010100, 0}, 		   //b
	{0b00011100, 0b00100010, 0b00100010, 0b00100010, 0}, 		   //c
	{0b00111110, 0b00100010, 0b00100010, 0b00011100, 0}, 		   //d
	{0b00111110, 0b00101010, 0b00101010, 0b00100010, 0}, 		   //e
	{0b00111110, 0b00101000, 0b00101000, 0b00100000, 0}, 		   //f
	{0b00011100, 0b00100010, 0b00101010, 0b00101100, 0}, 		   //g
	{0b00111110, 0b00001000, 0b00001000, 0b00111110, 0}, 		   //h
	{0b00100010, 0b00111110, 0b00100010, 0, 0}, 				   //i
	{0b00000100, 0b00100010, 0b00100010, 0b00111100, 0}, 		   //j
	{0b00111110, 0b00001000, 0b00010100, 0b00100010, 0}, 		   //k
	{0b00111110, 0b00000010, 0b00000010, 0b00000010, 0}, 		   //l
	{0b00111110, 0b00010000, 0b00001000, 0b00010000, 0b00111110}, //m
	{0b00111110, 0b00010000, 0b00001000, 0b00000100, 0b00111110}, //n
	{0b00011100, 0b00100010, 0b00100010, 0b00100010, 0b00011100}, //o
	{0b00111110, 0b00101000, 0b00101000, 0b00010000, 0}, 		   //p
	{0b00011000, 0b00100100, 0b00100110, 0b00011010, 0}, 		   //q
	{0b00111110, 0b00101000, 0b00101000, 0b00010110, 0}, 		   //r
	{0b00010010, 0b00101010, 0b00101010, 0b00100100, 0}, 		   //s
	{0b00100000, 0b00100000, 0b00111110, 0b00100000, 0b00100000}, //t
	{0b00111100, 0b00000010, 0b00000010, 0b00111100, 0}, 		   //u
	{0b00110000, 0b00001100, 0b00000010, 0b00111100, 0}, 		   //v
	{0b00111100, 0b00000010, 0b00001100, 0b00000010, 0b00111100}, //w
	{0b00100010, 0b00010100, 0b00001000, 0b00010100, 0b00100010}, //x
	{0b00110000, 0b00001000, 0b00001110, 0b00001000, 0b00110000}, //y
	{0b00100110, 0b00101010, 0b00101010, 0b00110010, 0} 		   //z
const unsigned char num_array[10][5] PROGMEM =
	{0b01111100, 0b10000010, 0b10000010, 0b10000010, 0b01111100}, //0
	{0b01000010, 0b11111110, 0b00000010, 0, 0},				   //1
	{0b01001110, 0b10001010, 0b10010010, 0b10010010, 0b01100010}, //2
	{0b01000100, 0b10000010, 0b10010010, 0b10010010, 0b01101100}, //3
	{0b11110000, 0b00010000, 0b00010000, 0b00010000, 0b11111110}, //4
	{0b11110010, 0b10010010, 0b10010010, 0b10010010, 0b10001100}, //5
	{0b01111100, 0b10010010, 0b10010010, 0b10010010, 0b01001100}, //6
	{0b10000000, 0b10000000, 0b10011110, 0b10110000, 0b11100000}, //7
	{0b01101100, 0b10010010, 0b10010010, 0b10010010, 0b01101100}, //8
	{0b01100000, 0b10010000, 0b10010000, 0b10010000, 0b01111110}  //9
const unsigned char sign_array[22][5] PROGMEM =
	{0b01110000, 0b10001010, 0b01110000, 0, 0}, 				   // !
	{0b11000110, 0b11001000, 0b00010000, 0b00100110, 0b11000110}, // %
	{0b00000010, 0b00001100, 0b00110000, 0b11000000, 0}, 		   // /
	{0b01111100, 0b10000010, 0, 0, 0}, 						   // (
	{0b10000010, 0b01111100, 0, 0, 0}, 						   // )
	{0b11111110, 0b10000010, 0, 0, 0}, 						   // [
	{0b10000010, 0b11111110, 0, 0, 0}, 						   // ]
	{0b00010000, 0b01101100, 0b10000010, 0, 0}, 				   // {
	{0b10000010, 0b01101100, 0b00010000, 0, 0}, 				   // }
	{0b00101000, 0b00101000, 0b00101000, 0, 0}, 				   // =
	{0b01100000, 0b10000000, 0b10001010, 0b10010000, 0b01100000}, // ?
	{0b00010000, 0b00111000, 0b00010000, 0, 0}, 				   // +
	{0b00010000, 0b00010000, 0b00010000, 0, 0}, 				   // -
	{0b00000010, 0, 0, 0, 0}, 									   // .
	{0b00100100, 0, 0, 0, 0}, 									   // :
	{0b00000010, 0b00000010, 0b00000010, 0b00000010, 0b00000010}, // _
	{0b11000000, 0, 0, 0, 0}, 									   // ´
	{0b11111110, 0, 0, 0, 0}, 									   // |
	{0b01000000, 0b10100000, 0b01000000, 0, 0},				   // *
	{0b00100000, 0b01000000, 0b10000000, 0b01000000, 0b00100000}, // ^
	{0b00010000, 0b00101000, 0b01000100, 0, 0},				   // <
	{0b01000100, 0b00101000, 0b00010000, 0, 0}					   // >
void LCD_Init(void);
void LCD_Wait(void);
void LCD_RTS(void);
void LCD_Fill_Screen(void);
void LCD_Clear_Screen(void);
void LCD_Send_Cmd(unsigned char);
void LCD_Send_Data(unsigned char);
void LCD_Set_Pos(unsigned char, unsigned char);
void LCD_Draw_Dot(unsigned char, unsigned char);
void LCD_Clear_Dot(unsigned char, unsigned char);
void LCD_Draw_Line(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char);
void LCD_Draw_Rect(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char);
void LCD_Draw_Circle(unsigned char, unsigned char, unsigned char);
void LCD_Write_Char(unsigned char, unsigned char, char);
void LCD_Write_String(unsigned char, unsigned char, char *);
unsigned char LCD_Read_Data(void);
unsigned int abs(int);
volatile unsigned char lcd_x = 0, lcd_y = 0;
	LCD_Init();
	LCD_RTS();
	LCD_Write_String(4, 13, "Battery Info");
	LCD_Write_String(4, 22, "Waiting for battery");
	LCD_Write_String(4, 34, "Timer: 00:00:00");
	LCD_Write_String(4, 43, "Charge: 0%");
	while(1);
	return 0;
void LCD_RTS(void)
	LCD_Clear_Screen();
	LCD_Draw_Line(1, 0, 126, 0, 0);
	LCD_Draw_Line(1, 63, 126, 63, 0);
	LCD_Draw_Line(0, 1, 0, 62, 0);
	LCD_Draw_Line(127, 1, 127, 62, 0);
	LCD_Draw_Dot(1, 1);
	LCD_Draw_Dot(1, 62);
	LCD_Draw_Dot(126, 1);
	LCD_Draw_Dot(126, 62);
	LCD_Draw_Line(2, 10, 125, 10, 0);
	LCD_Draw_Line(1, 9, 2, 9, 0);
	LCD_Draw_Line(1, 11, 2, 11, 0);
	LCD_Draw_Line(125, 9, 126, 9, 0);
	LCD_Draw_Line(125, 11, 126, 11, 0);
	LCD_Draw_Line(2, 31, 125, 31, 0);
	LCD_Draw_Line(1, 30, 2, 30, 0);
	LCD_Draw_Line(1, 32, 2, 32, 0);
	LCD_Draw_Line(125, 30, 126, 30, 0);
	LCD_Draw_Line(125, 32, 126, 32, 0);
	LCD_Draw_Line(2, 52, 125, 52, 0);
	LCD_Draw_Line(1, 51, 2, 51, 0);
	LCD_Draw_Line(1, 53, 2, 53, 0);
	LCD_Draw_Line(125, 51, 126, 51, 0);
	LCD_Draw_Line(125, 53, 126, 53, 0);
	LCD_Write_String(8, 2, "Charger powered by AVR");
	LCD_Write_String(10, 54, "www.airsoftsverige.com");
void LCD_Init(void)
	LCD_CONTROL_DDR = 0xFF;
	LCD_DATA_DDR = 0xFF;
	LCD_CONTROL_PORT &= ~(1<<LCD_RESET);
	_delay_loop_2(20);
	LCD_CONTROL_PORT |= (1<<LCD_RESET);
	SET_CS1();
	CLEAR_CS2();
	LCD_Send_Cmd(DISPLAY_ON);
	SET_CS2();
	CLEAR_CS1();
	SET_CS1();
	SET_CS2();
void LCD_Wait(void)
	LCD_DATA_DDR = 0x00; 	// Set DDR to input.
	CLEAR_RS();				// Set Instruction/Data pin to low
	SET_RW();				// Set Read/Write to Read (high)
	SET_ENABLE();
	while((LCD_DATA_PIN & DISPLAY_STATUS_BUSY)); // Do loop until LCD isn't busy anymore
	CLEAR_ENABLE();
void LCD_Send_Cmd(unsigned char cmd)
	LCD_Wait(); 			// Wait for LCD to be ready for commands
	CLEAR_RW(); 			// Set Read/Write to Write (low)
	LCD_DATA_DDR = 0xFF;	// Set DDR to output
	LCD_DATA_PORT = cmd;	// Send the data
	SET_ENABLE();			// Pulse Enable
	_delay_loop_2(20);
	CLEAR_ENABLE();
void LCD_Send_Data(unsigned char data)
	SET_RS(); 				// Set Instruction/Data pin to high
	LCD_DATA_PORT = data;	// Send data
	_delay_loop_2(20);
	CLEAR_ENABLE();
	LCD_DATA_DDR = 0x00; 					// Set DDR to output
	SET_ENABLE();							// Set Enable high
	_delay_loop_2(20);
	CLEAR_ENABLE();							// Set Enable low
	unsigned char data = LCD_DATA_PIN;		// Get data
	return data;
void LCD_Set_Pos(unsigned char x, unsigned char y)
	lcd_x = x;
	lcd_y = y;
	unsigned char tmp = 0;
	if (lcd_x > 63)
		SET_CS2();
		CLEAR_CS1();
		tmp = (lcd_x - 64);
		SET_CS1();
		CLEAR_CS2();
		tmp = lcd_x;
	LCD_Send_Cmd(ADDRESS_X | tmp);
	LCD_Send_Cmd(ADDRESS_Y | lcd_y);
	SET_CS2();
	CLEAR_CS1();
	LCD_Send_Cmd(DISPLAY_LINE);
	SET_CS1();
	CLEAR_CS2();
	if (lcd_x > 63)
		SET_CS2();
		CLEAR_CS1();
		SET_CS1();
		CLEAR_CS2();
void LCD_Draw_Dot(unsigned char x, unsigned char y)
	LCD_Set_Pos(x, y/8);
	unsigned char tempdata = LCD_Read_Data();
	LCD_Send_Data(tempdata | (1<<(y % 8)));
void LCD_Clear_Dot(unsigned char x, unsigned char y)
	LCD_Send_Data(tempdata & ~(1<<(y % 8)));
	for(unsigned char y = 0; y < 8; y++)
		for(unsigned char x = 0; x < 128; x++)
			LCD_Set_Pos(x, y);
			LCD_Send_Data(0xFF);
			LCD_Set_Pos(x, y);
			LCD_Send_Data(0x00);
void LCD_Draw_Line(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, unsigned char clr)
	int deltax = abs(x2 - x1);
	int deltay = abs(y2 - y1);
	int x = x1;
	int y = y1;
	int xinc1;
	int xinc2;
	int yinc1;
	int yinc2;
	int den;
	int num;
	int numadd;
	int numpixels;
	if (x2 >= x1)
		xinc1 = 1;
		xinc2 = 1;
		xinc1 = -1;
		xinc2 = -1;
	if (y2 >= y1)
		yinc1 = 1;
		yinc2 = 1;
		yinc1 = -1;
		yinc2 = -1;
	if (deltax >= deltay)
		xinc1 = 0;
		yinc2 = 0;
		den = deltax;
		num = deltax / 2;
		numadd = deltay;
		numpixels = deltax;
		xinc2 = 0;
		yinc1 = 0;
		den = deltay;
		num = deltay / 2;
		numadd = deltax;
		numpixels = deltay;
	for (unsigned char curpixel = 0; curpixel <= numpixels; curpixel++)
		if (clr)
			LCD_Draw_Dot(x, y);
		num += numadd;
		if (num >= den)
			num -= den;
			x += xinc1;
			y += yinc1;
		x += xinc2;
		y += yinc2;
void LCD_Draw_Rect(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, unsigned char fill, unsigned char clr)
	if (fill != 0)
		for (int i = y1; i <= y2; i++)
			LCD_Draw_Line(x1, i, x2, i, clr);
		LCD_Draw_Line(x1, y1, x2, y1, clr);
		LCD_Draw_Line(x1, y2, x2, y2, clr);
		LCD_Draw_Line(x2, y1, x2, y2, clr);
		LCD_Draw_Line(x1, y1, x1, y2, clr);
void LCD_Draw_Circle(unsigned char x1, unsigned char y1, unsigned char radius)
	int f = 1 - radius;
	int ddF_x = 0;
	int ddF_y = -2 * radius;
	int x = 0;
	int y = radius;
	LCD_Draw_Dot(x1, y1 + radius);
	LCD_Draw_Dot(x1, y1 - radius);
	LCD_Draw_Dot(x1 + radius, y1);
	LCD_Draw_Dot(x1 - radius, y1);
	while(x < y)
		if(f >= 0)
			y--;
			ddF_y += 2;
			f += ddF_y;
		x++;
		ddF_x += 2;
		f += ddF_x + 1;
		LCD_Draw_Dot(x1 + x, y1 + y);
		LCD_Draw_Dot(x1 - x, y1 + y);
		LCD_Draw_Dot(x1 + x, y1 - y);
		LCD_Draw_Dot(x1 - x, y1 - y);
		LCD_Draw_Dot(x1 + y, y1 + x);
		LCD_Draw_Dot(x1 - y, y1 + x);
		LCD_Draw_Dot(x1 + y, y1 - x);
		LCD_Draw_Dot(x1 - y, y1 - x);
unsigned int abs(int num)
	if (num >= 0)
		return num;
		return -num;
void LCD_Write_Char(unsigned char x, unsigned char y, char ch)
	if (ch == ' ')
		lcd_x += 4;
		return;
	unsigned char ch_data[5] = {0, 0, 0, 0, 0};
	if((ch >= 'A') && (ch <= 'Z'))
		ch_data[0] = pgm_read_byte(&char_array[ch - 'A'][0]);
		ch_data[1] = pgm_read_byte(&char_array[ch - 'A'][1]);
		ch_data[2] = pgm_read_byte(&char_array[ch - 'A'][2]);
		ch_data[3] = pgm_read_byte(&char_array[ch - 'A'][3]);
		ch_data[4] = pgm_read_byte(&char_array[ch - 'A'][4]);
	else if((ch >= 'a') && (ch <= 'z'))
		ch_data[0] = pgm_read_byte(&schar_array[ch - 'a'][0]);
		ch_data[1] = pgm_read_byte(&schar_array[ch - 'a'][1]);
		ch_data[2] = pgm_read_byte(&schar_array[ch - 'a'][2]);
		ch_data[3] = pgm_read_byte(&schar_array[ch - 'a'][3]);
		ch_data[4] = pgm_read_byte(&schar_array[ch - 'a'][4]);
	else if((ch >= '0') && (ch <= '9'))
		ch_data[0] = pgm_read_byte(&num_array[ch - '0'][0]);
		ch_data[1] = pgm_read_byte(&num_array[ch - '0'][1]);
		ch_data[2] = pgm_read_byte(&num_array[ch - '0'][2]);
		ch_data[3] = pgm_read_byte(&num_array[ch - '0'][3]);
		ch_data[4] = pgm_read_byte(&num_array[ch - '0'][4]);
		unsigned char i = 0xFF;
		switch(ch)
			case '!': i = 0; break;
			case '%': i = 1; break;
			case '/': i = 2; break;
			case '(': i = 3; break;
			case ')': i = 4; break;
			case '[': i = 5; break;
			case ']': i = 6; break;
			case '{': i = 7; break;
			case '}': i = 8; break;
			case '=': i = 9; break;
			case '?': i = 10; break;
			case '+': i = 11; break;
			case '-': i = 12; break;
			case '.': i = 13; break;
			case ':': i = 14; break;
			case '_': i = 15; break;
			case '´': i = 16; break;
			case '|': i = 17; break;
			case '*': i = 18; break;
			case '^': i = 19; break;
			case '<': i = 20; break;
			case '>': i = 21; break;
			default: break;
		if (i != 0xFF)
			ch_data[0] = pgm_read_byte(&sign_array[i][0]);
			ch_data[1] = pgm_read_byte(&sign_array[i][1]);
			ch_data[2] = pgm_read_byte(&sign_array[i][2]);
			ch_data[3] = pgm_read_byte(&sign_array[i][3]);
			ch_data[4] = pgm_read_byte(&sign_array[i][4]);
	if (ch_data[0] != 0)
		for(unsigned char a = 0; a < sizeof(ch_data); a++)
			for(unsigned char i = 0; i < 8; i++)
				if ((ch_data[a] == 0) || ((x + a) == 127))
					return;
				if (ch_data[a] & 0x80)
					LCD_Draw_Dot((x + a), (y + i));
				ch_data[a] <<= 1;
void LCD_Write_String(unsigned char x, unsigned char y, char *s)
	while(s[i])
		LCD_Write_Char(x, y, s[i]);
		x = (lcd_x + 2);
		if (lcd_x == 127)
			return;
		i++;
Thanks!
//Emil - Korken
Sweden
Don't misunderstand my PIC, it's irony. ;)
It will be a complete post if you could add the schematics!!
