Not a variation on 5x7 led display
6 posts / 0 new
This was my first project (about 6 months ago), and as such it brings nothing new to the mix. It is pretty much a beginner project, teaching you how to experiment with POV (Persistence of Vision), use of a LINE driver (transistor or darlingtons), and use of EEPROM.
It's missing a serial port, but has a keypad entry method using 5 buttons.
Project page :http://www.avrfreaks.net/index.php?module=Freaks%20Academy&func=viewItem&item_type=project&item_id=1555
Youtube: http://www.youtube.com/watch?v=Umy0rV2MsZA
There are a million variations all much more minimalist than my implementation, of the same idea. The reason I chose it as a first project was because I wanted to understand a similar display's operation at work.
A few related threads: http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=73882
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=69118
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=48445
Conrad Braam - www.softcircuitry.blogspot.com - www.plcsimulator.org
Always start off poorly, that way when you finally figure it out, you can get a few surprise hits in.
The diagram attached to the project has a mistake (obvious once you read the code) row 6 and 7 are really PD5 and PD6 as attached above. Because the project was simply transferred from Breadboard to strip-board, its pretty much wired one pin at a time. In the diagram I only showed 1 transistor, when in fact you need 1 for each column (a total of 5). When I initially built it on breadboard, I also ended up using a driver-array chip to save breadboard space as well as my sanity - using a darlington array is the only way to go if you want to add more LED units.
To work out the pins, you need to draw the diagram in 2 ways, one for just row/column, and then with the pin mappings
ROW : AVR pin LED
PD0 = 2 to 12
PD1 = 3 to 11
PD2 = 4 to 2
PD3 = 5 to 9
PD4 = 6 to 4
PD5 = 11 to 5
PD6 = 12 to 6
COL : AVRpin : LED
PC0 = 23 to 1
PC1 = 24 to 3
PC2 = 25 to 10
PC3 = 26 to 7
PC4 = 27 to 8
edit-message push-buttons:
PORTB -
UP -x -x
DOWN -x -x
LEFT -x -x
RGHT -x -x
EXIT -x -x
Since mistakes are all part of the hobby for me (I have a very different day-job) I invite you to make a couple of mistakes yourself. I cannot guarantee you will find or use the same parts, but if you mail me some samples, I will happily test and debug them for you (LOL). As with any hobby, the cheapest and most ingenious component mix is it's own reward.
Possible column driver chip =ULN2803 or some 2n2222 transistors, if you choose to go without the column drivers, you will notice the ugly effect where letters like L with lots of leds in one column will have dim vertical strokes, and bright horizontal ones.
And what's there preventing the transistor or the led matrix or the AVR from exploding? :?
Aaah, glad someone asked, runs off tiny batteries. Practically I am not a guru at driving LEDs, I go more by getting the drop voltage than by working out the current; so I am not showing 1KOhm transistor bias current limiters, alternatively if using a darlington array, I used 100 Ohm dropper on each collumn.
A big detail missing from my hand-drawn scrawl :oops: I wanted it to not use much power at all, which my finnished unit does, using just 3 small watch-batteries ...the project actually runs at 4 to 4.5 volts, more than enough to pop the LEDs one at a time. But I found the a value for droppers more by experimentation which did not cause the leds to burn too brightly, while if you run this off a regular 5v rail, it is no longer portable.
Thanks once again for the warning!!!
I would love to get an oscilloscope and get a proper average power consumption per LED worked out. Another problem I did not manage to overcome is the ghosting, even after giving the I/O lines longer to settle, I cannot figure out why you still get ghosting (another reason a 'scope would help). Any Ideas?
Any Ideas?
It has been discussed before, may want to do a bit of searching on this forum.
Basically you turn OFF the leds before changing the data. I have a few led boards on my website. :)
I also checked out John's site http://www.members.optusnet.com.au/ampertronics/signs.htm specifically should provide some inspiration, if not a source for a finished product that already does what you want.
