QT make error
11 posts / 0 new
anyone know how i can fix this error? this is after i type make in the /build_avr32/qt-embedded-linux-opensource-src-4.4.3
directory.
../JavaScriptCore/kjs/collector.cpp:355: error: 'pthread_getattr_np' was not declared in this scope
make[1]: *** [.obj/release-shared-emb-avr32/collector.o] Error 1
make[1]: Leaving directory `/home/geno/buildroot-avr32-v2.3.0/build_avr32/qt-embedded-linux-opensource-src-4.4.3/src/3rdparty/webkit/WebCore'
make: *** [sub-webkit-make_default-ordered] Error 2
thanks for the help.
You are missing 'pthread_getattr_np' as a refeance... You should probablt link in the ptread lib. Have you just remoed qt from buildroot or is it a clean src tree?
Life's to short for waiting on slow CPU's
No i did not remove QT from buildroot. i did do a
-make confclean- but i think i had the same error before i did -clean-. how do i fix this?
this build QT stuff is driving me nuts. anyone any ideas?
never mind. i got it
Hi artmedia,
I have the same problem with the actual buildroot-svn (r25413) and also qt 4.4.3.
How did you solve this problem?
thanx!
For starters you can disable webkit.
Hans-Christian
i used a patch...
replace your collector.cpp in the javacore or webkit directory with this one. just copy this code and make cpp out of it.
if you're haveing a hard time with this let me know and i'll send you the file and specific directory
than rebuild "make"
// -*- mode: c++; c-basic-offset: 4 -*-
*  This file is part of the KDE libraries
*  Copyright (C) 2003, 2004, 2005, 2006, 2007 Apple Inc. All rights reserved.
*  This library is free software; you can redistribute it and/or
*  modify it under the terms of the GNU Lesser General Public
*  License as published by the Free Software Foundation; either
*  version 2 of the License, or (at your option) any later version.
*  This library is distributed in the hope that it will be useful,
*  but WITHOUT ANY WARRANTY; without even the implied warranty of
*  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
*  Lesser General Public License for more details.
*  You should have received a copy of the GNU Lesser General Public
*  License along with this library; if not, write to the Free Software
*  Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
#include "config.h"
#include "collector.h"
#include "internal.h"
#include "list.h"
#include "value.h"
#include
#include
#include
#include
#include
#include
#if USE(MULTIPLE_THREADS)
#include
#endif
#if PLATFORM(DARWIN)
#include
#include
#include
#include
#include
#include "CollectorHeapIntrospector.h"
#elif PLATFORM(WIN_OS)
#include
#elif PLATFORM(UNIX)
#include
#include
#include
#ifdef __UCLIBC__
// versions of uClibc 0.9.28 and below do not have // pthread_getattr_np or pthread_attr_getstack.
#if __UCLIBC_MAJOR__ == 0 && \
    (__UCLIBC_MINOR__ < 9 || \
     (__UCLIBC_MINOR__ == 9 && __UCLIBC_SUBLEVEL__ <= 30)) #define UCLIBC_USE_PROC_SELF_MAPS 1 #include  extern int *__libc_stack_end; #endif #endif
#if PLATFORM(SOLARIS_OS)
#include
#endif
#if HAVE(PTHREAD_NP_H)
#include
#else
#include
#endif
#endif
#define DEBUG_COLLECTOR 0
#if !defined(MAP_ANON) && defined(MAP_ANONYMOUS)
#    define MAP_ANON MAP_ANONYMOUS
#endif
using std::max;
namespace KJS {
// tunable parameters
const size_t SPARE_EMPTY_BLOCKS = 2;
const size_t MIN_ARRAY_SIZE = 14;
const size_t GROWTH_FACTOR = 2;
const size_t LOW_WATER_FACTOR = 4;
const size_t ALLOCATIONS_PER_COLLECTION = 4000;
enum OperationInProgress { NoOperation, Allocation, Collection };
struct CollectorHeap {
  CollectorBlock** blocks;
  size_t numBlocks;
  size_t usedBlocks;
  size_t firstBlockWithPossibleSpace;
  size_t numLiveObjects;
  size_t numLiveObjectsAtLastCollect;
  size_t extraCost;
  OperationInProgress operationInProgress; };
static CollectorHeap heap = { 0, 0, 0, 0, 0, 0, 0, NoOperation };
// FIXME: I don't think this needs to be a static data member of the Collector class.
// Just a private global like "heap" above would be fine.
size_t Collector::mainThreadOnlyObjectCount = 0;
bool Collector::memoryFull = false;
static CollectorBlock* allocateBlock()
    vm_address_t address = 0;
    vm_map(current_task(), &address, BLOCK_SIZE, BLOCK_OFFSET_MASK, VM_FLAGS_ANYWHERE, MEMORY_OBJECT_NULL, 0, FALSE, VM_PROT_DEFAULT, VM_PROT_DEFAULT, VM_INHERIT_DEFAULT); #elif PLATFORM(WIN_OS)
     // windows virtual address granularity is naturally 64k
    LPVOID address = VirtualAlloc(NULL, BLOCK_SIZE, MEM_COMMIT | MEM_RESERVE, PAGE_READWRITE); #elif HAVE(POSIX_MEMALIGN)
    void* address;
    posix_memalign(&address, BLOCK_SIZE, BLOCK_SIZE);
    memset(address, 0, BLOCK_SIZE);
#else
    static size_t pagesize = getpagesize();
    size_t extra = 0;
    if (BLOCK_SIZE > pagesize)
        extra = BLOCK_SIZE - pagesize;
    void* mmapResult = mmap(NULL, BLOCK_SIZE + extra, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANON, -1, 0);
    uintptr_t address = reinterpret_cast(mmapResult);
    size_t adjust = 0;
    if ((address & BLOCK_OFFSET_MASK) != 0)
        adjust = BLOCK_SIZE - (address & BLOCK_OFFSET_MASK);
    if (adjust > 0)
        munmap(reinterpret_cast(address), adjust);
    if (adjust < extra)
        munmap(reinterpret_cast(address + adjust + BLOCK_SIZE), extra - adjust);
    address += adjust;
    memset(reinterpret_cast(address), 0, BLOCK_SIZE); #endif
    return reinterpret_cast(address);
static void freeBlock(CollectorBlock* block) {
    vm_deallocate(current_task(), reinterpret_cast(block), BLOCK_SIZE); #elif PLATFORM(WIN_OS)
    VirtualFree(block, BLOCK_SIZE, MEM_RELEASE); #elif HAVE(POSIX_MEMALIGN)
    free(block);
#else
    munmap((char *)block, BLOCK_SIZE);
#endif
void Collector::recordExtraCost(size_t cost) {
    // Our frequency of garbage collection tries to balance memory use against speed
    // by collecting based on the number of newly created values. However, for values
    // that hold on to a great deal of memory that's not in the form of other JS values,
    // that is not good enough - in some cases a lot of those objects can pile up and
    // use crazy amounts of memory without a GC happening. So we track these extra
    // memory costs. Only unusually large objects are noted, and we only keep track
    // of this extra cost until the next GC. In garbage collected languages, most values
    // are either very short lived temporaries, or have extremely long lifetimes. So
    // if a large value survives one garbage collection, there is not much point to
    // collecting more frequently as long as it stays alive.
    heap.extraCost += cost;
void* Collector::allocate(size_t s)
  ASSERT(JSLock::lockCount() > 0);
  ASSERT(JSLock::currentThreadIsHoldingLock());
  ASSERT(s <= CELL_SIZE);
  UNUSED_PARAM(s); // s is now only used for the above assert
  ASSERT(heap.operationInProgress == NoOperation);
  // FIXME: If another global variable access here doesn't hurt performance
  // too much, we could abort() in NDEBUG builds, which could help ensure we
  // don't spend any time debugging cases where we allocate inside an object's
  // deallocation code.
  // collect if needed
  size_t numLiveObjects = heap.numLiveObjects;
  size_t numLiveObjectsAtLastCollect = heap.numLiveObjectsAtLastCollect;
  size_t numNewObjects = numLiveObjects - numLiveObjectsAtLastCollect;
  size_t newCost = numNewObjects + heap.extraCost;
  if (newCost >= ALLOCATIONS_PER_COLLECTION && newCost >= numLiveObjectsAtLastCollect) {
    collect();
  ASSERT(heap.operationInProgress == NoOperation); #ifndef NDEBUG
  // FIXME: Consider doing this in NDEBUG builds too (see comment above).
  heap.operationInProgress = Allocation; #endif
  // slab allocator
  size_t usedBlocks = heap.usedBlocks;
  size_t i = heap.firstBlockWithPossibleSpace;
  CollectorBlock *targetBlock;
  size_t targetBlockUsedCells;
  if (i != usedBlocks) {
    targetBlock = heap.blocks[i];
    targetBlockUsedCells = targetBlock->usedCells;
    ASSERT(targetBlockUsedCells <= CELLS_PER_BLOCK);
    while (targetBlockUsedCells == CELLS_PER_BLOCK) {
      if (++i == usedBlocks)
        goto allocateNewBlock;
    heap.firstBlockWithPossibleSpace = i;
  } else {
allocateNewBlock:
    // didn't find one, need to allocate a new block
    size_t numBlocks = heap.numBlocks;
    if (usedBlocks == numBlocks) {
      numBlocks = max(MIN_ARRAY_SIZE, numBlocks * GROWTH_FACTOR);
      heap.numBlocks = numBlocks;
      heap.blocks = static_cast(fastRealloc(heap.blocks, numBlocks * sizeof(CollectorBlock *)));
    targetBlock = allocateBlock();
    targetBlock->freeList = targetBlock->cells;
    targetBlockUsedCells = 0;
    heap.blocks[usedBlocks] = targetBlock;
    heap.usedBlocks = usedBlocks + 1;
    heap.firstBlockWithPossibleSpace = usedBlocks;
  // find a free spot in the block and detach it from the free list
  CollectorCell *newCell = targetBlock->freeList;
  // "next" field is a byte offset -- 0 means next cell, so a zeroed block is already initialized
  // could avoid the casts by using a cell offset, but this avoids a relatively-slow multiply
  targetBlock->freeList = reinterpret_cast(reinterpret_cast(newCell + 1) + newCell->u.freeCell.next);
  targetBlock->usedCells = static_cast(targetBlockUsedCells + 1);
  heap.numLiveObjects = numLiveObjects + 1;
#ifndef NDEBUG
  heap.operationInProgress = NoOperation; #endif
  return newCell;
static inline void* currentThreadStackBase() { #if PLATFORM(DARWIN)
    pthread_t thread = pthread_self();
    return pthread_get_stackaddr_np(thread); #elif PLATFORM(WIN_OS) && PLATFORM(X86) && COMPILER(MSVC)
    // offset 0x18 from the FS segment register gives a pointer to
    // the thread information block for the current thread
    NT_TIB* pTib;
    __asm {
        MOV EAX, FS:[18h]
        MOV pTib, EAX
    return (void*)pTib->StackBase;
#elif PLATFORM(WIN_OS) && PLATFORM(X86_64) && COMPILER(MSVC)
    PNT_TIB64 pTib = reinterpret_cast(NtCurrentTeb());
#elif PLATFORM(WIN_OS) && PLATFORM(X86) && COMPILER(GCC)
    NT_TIB* pTib;
    asm ( "movl %%fs:0x18, %0\n"
          : "=r" (pTib)
#elif PLATFORM(SOLARIS_OS)
    stack_t s;
    thr_stksegment(&s);
    return s.ss_sp;
#elif PLATFORM(HPUX_OS)
    _pthread_stack_info_t stackInfo;
    _pthread_stack_info_np(thread, &stackInfo);
    return stackInfo.stk_stack_base;
#ifdef UCLIBC_USE_PROC_SELF_MAPS
    // Read /proc/self/maps and locate the line whose address
    // range contains __libc_stack_end.
    FILE *file = fopen("/proc/self/maps", "r");
    if (!file)
        return 0;
    __fsetlocking(file, FSETLOCKING_BYCALLER);
    char *line = NULL;
    size_t lineLen = 0;
    while (!feof_unlocked(file)) {
        if (getdelim(&line, &lineLen, '\n', file) <= 0)
            break;
        long from;
        long to;
        if (sscanf (line, "%lx-%lx", &from, &to) != 2)
            continue;
        if (from <= (long)__libc_stack_end && (long)__libc_stack_end < to) {
            fclose(file);
            free(line);
#ifdef _STACK_GROWS_UP
            return (void *)from;
#else
            return (void *)to;
#endif
    fclose(file);
    free(line);
    return 0;
#else
    static void *stackBase = 0;
    static size_t stackSize = 0;
    static pthread_t stackThread;
    if (stackBase == 0 || thread != stackThread) {
        pthread_attr_t sattr;
        pthread_attr_init(&sattr);
        // e.g. on FreeBSD 5.4, neundorf@kde.org
        pthread_attr_get_np(thread, &sattr); #else
        // FIXME: this function is non-portable; other POSIX systems may have different np alternatives
        pthread_getattr_np(thread, &sattr); #endif
        int rc = pthread_attr_getstack(&sattr, &stackBase, &stackSize);
        (void)rc; // FIXME: deal with error code somehow?  seems fatal...
        ASSERT(stackBase);
        pthread_attr_destroy(&sattr);
        stackThread = thread;
    return (void*)(size_t(stackBase) + stackSize); #endif #else #error Need a way to get the stack base on this platform #endif }
static pthread_t mainThread;
#endif
void Collector::registerAsMainThread()
    mainThread = pthread_self();
#endif
static inline bool onMainThread()
    return pthread_main_np();
#else
    return !!pthread_equal(pthread_self(), mainThread); #endif #else
    return true;
#endif
typedef mach_port_t PlatformThread;
struct PlatformThread {
    PlatformThread(DWORD _id, HANDLE _handle) : id(_id), handle(_handle) {}
    DWORD id;
    HANDLE handle;
#endif
static inline PlatformThread getCurrentPlatformThread() { #if PLATFORM(DARWIN)
    return pthread_mach_thread_np(pthread_self());
    HANDLE threadHandle = pthread_getw32threadhandle_np(pthread_self());
    return PlatformThread(GetCurrentThreadId(), threadHandle); #endif }
class Collector::Thread {
public:
  Thread(pthread_t pthread, const PlatformThread& platThread) : posixThread(pthread), platformThread(platThread) {}
  Thread* next;
  pthread_t posixThread;
  PlatformThread platformThread;
pthread_key_t registeredThreadKey;
pthread_once_t registeredThreadKeyOnce = PTHREAD_ONCE_INIT;
Collector::Thread* registeredThreads;
static void destroyRegisteredThread(void* data) {
  Collector::Thread* thread = (Collector::Thread*)data;
  // Can't use JSLock convenience object here because we don't want to re-register
  // an exiting thread.
  JSLock::lock();
  if (registeredThreads == thread) {
    registeredThreads = registeredThreads->next;
  } else {
    Collector::Thread *last = registeredThreads;
    Collector::Thread *t;
    for (t = registeredThreads->next; t != NULL; t = t->next) {
      if (t == thread) {
          last->next = t->next;
          break;
      last = t;
    ASSERT(t); // If t is NULL, we never found ourselves in the list.
  JSLock::unlock();
  delete thread;
static void initializeRegisteredThreadKey() {
  pthread_key_create(®isteredThreadKey, destroyRegisteredThread); }
void Collector::registerThread()
  pthread_once(®isteredThreadKeyOnce, initializeRegisteredThreadKey);
  if (!pthread_getspecific(registeredThreadKey)) { #if PLATFORM(DARWIN)
      if (onMainThread())
          CollectorHeapIntrospector::init(&heap);
#endif
    Collector::Thread *thread = new Collector::Thread(pthread_self(), getCurrentPlatformThread());
    thread->next = registeredThreads;
    registeredThreads = thread;
    pthread_setspecific(registeredThreadKey, thread);
#endif
#define IS_POINTER_ALIGNED(p) (((intptr_t)(p) & (sizeof(char *) - 1)) == 0)
// cell size needs to be a power of two for this to be valid #define IS_CELL_ALIGNED(p) (((intptr_t)(p) & CELL_MASK) == 0)
void Collector::markStackObjectsConservatively(void *start, void *end) {
  if (start > end) {
    void* tmp = start;
    start = end;
    end = tmp;
  ASSERT(((char*)end - (char*)start) < 0x1000000);
  ASSERT(IS_POINTER_ALIGNED(start));
  ASSERT(IS_POINTER_ALIGNED(end));
  char** p = (char**)start;
  char** e = (char**)end;
  CollectorBlock **blocks = heap.blocks;
  const size_t lastCellOffset = sizeof(CollectorCell) * (CELLS_PER_BLOCK - 1);
  while (p != e) {
    char* x = *p++;
    if (IS_CELL_ALIGNED(x) && x) {
      uintptr_t offset = reinterpret_cast(x) & BLOCK_OFFSET_MASK;
      CollectorBlock* blockAddr = reinterpret_cast(x - offset);
      for (size_t block = 0; block < usedBlocks; block++) {
        if ((blocks[block] == blockAddr) & (offset <= lastCellOffset)) {
          if (((CollectorCell*)x)->u.freeCell.zeroIfFree != 0) {
            JSCell* imp = reinterpret_cast(x);
            if (!imp->marked())
              imp->mark();
          break;
void Collector::markCurrentThreadConservatively()
    // setjmp forces volatile registers onto the stack
    jmp_buf registers;
#if COMPILER(MSVC)
#pragma warning(push)
#pragma warning(disable: 4611)
#endif
    setjmp(registers);
#if COMPILER(MSVC)
#pragma warning(pop)
#endif
    void* dummy;
    void* stackPointer = &dummy;
    void* stackBase = currentThreadStackBase();
    markStackObjectsConservatively(stackPointer, stackBase); }
static inline void suspendThread(const PlatformThread& platformThread) { #if PLATFORM(DARWIN)
  thread_suspend(platformThread);
  SuspendThread(platformThread.handle);
#else
#error Need a way to suspend threads on this platform #endif }
static inline void resumeThread(const PlatformThread& platformThread) { #if PLATFORM(DARWIN)
  thread_resume(platformThread);
  ResumeThread(platformThread.handle);
#else
#error Need a way to resume threads on this platform #endif }
typedef unsigned long usword_t; // word size, assumed to be either 32 or 64 bit
#if     PLATFORM(X86)
typedef i386_thread_state_t PlatformThreadRegisters;
#elif   PLATFORM(X86_64)
typedef x86_thread_state64_t PlatformThreadRegisters;
#elif   PLATFORM(PPC)
typedef ppc_thread_state_t PlatformThreadRegisters;
#elif   PLATFORM(PPC64)
typedef ppc_thread_state64_t PlatformThreadRegisters; #else #error Unknown Architecture #endif
#elif PLATFORM(WIN_OS)&& PLATFORM(X86)
typedef CONTEXT PlatformThreadRegisters; #else #error Need a thread register struct for this platform #endif
size_t getPlatformThreadRegisters(const PlatformThread& platformThread, PlatformThreadRegisters& regs) { #if PLATFORM(DARWIN)
#if     PLATFORM(X86)
  unsigned user_count = sizeof(regs)/sizeof(int);
  thread_state_flavor_t flavor = i386_THREAD_STATE;
  unsigned user_count = x86_THREAD_STATE64_COUNT;
  thread_state_flavor_t flavor = x86_THREAD_STATE64;
#elif   PLATFORM(PPC)
  unsigned user_count = PPC_THREAD_STATE_COUNT;
  thread_state_flavor_t flavor = PPC_THREAD_STATE;
  unsigned user_count = PPC_THREAD_STATE64_COUNT;
  thread_state_flavor_t flavor = PPC_THREAD_STATE64; #else #error Unknown Architecture #endif
  kern_return_t result = thread_get_state(platformThread, flavor, (thread_state_t)®s, &user_count);
  if (result != KERN_SUCCESS) {
    WTFReportFatalError(__FILE__, __LINE__, WTF_PRETTY_FUNCTION,
                        "JavaScript garbage collection failed because thread_get_state returned an error (%d). This is probably the result of running inside Rosetta, which is not supported.", result);
    CRASH();
  return user_count * sizeof(usword_t);
// end PLATFORM(DARWIN)
  regs.ContextFlags = CONTEXT_INTEGER | CONTEXT_CONTROL | CONTEXT_SEGMENTS;
  GetThreadContext(platformThread.handle, ®s);
  return sizeof(CONTEXT);
#else
#error Need a way to get thread registers on this platform #endif }
static inline void* otherThreadStackPointer(const PlatformThreadRegisters& regs) { #if PLATFORM(DARWIN)
#if __DARWIN_UNIX03
#if PLATFORM(X86)
  return (void*)regs.__esp;
  return (void*)regs.__rsp;
#elif PLATFORM(PPC) || PLATFORM(PPC64)
  return (void*)regs.__r1;
#else
#endif
#else // !__DARWIN_UNIX03
#if PLATFORM(X86)
  return (void*)regs.esp;
  return (void*)regs.rsp;
#elif (PLATFORM(PPC) || PLATFORM(PPC64))
  return (void*)regs.r1;
#else
#endif
#endif // __DARWIN_UNIX03
#elif PLATFORM(X86) && PLATFORM(WIN_OS)
  return (void*)(uintptr_t)regs.Esp;
#else
#error Need a way to get the stack pointer for another thread on this platform #endif }
static inline void* otherThreadStackBase(const PlatformThreadRegisters& regs, Collector::Thread* thread) { #if PLATFORM(DARWIN)
  (void)regs;
  return pthread_get_stackaddr_np(thread->posixThread);
// end PLATFORM(DARWIN);
  LDT_ENTRY desc;
  NT_TIB* tib;
  GetThreadSelectorEntry(thread->platformThread.handle, regs.SegFs, &desc);
  tib = (NT_TIB*)(uintptr_t)(desc.BaseLow | desc.HighWord.Bytes.BaseMid << 16 | desc.HighWord.Bytes.BaseHi << 24);
  ASSERT(tib == tib->Self);
  return tib->StackBase;
#else
void Collector::markOtherThreadConservatively(Thread* thread) {
  suspendThread(thread->platformThread);
  PlatformThreadRegisters regs;
  size_t regSize = getPlatformThreadRegisters(thread->platformThread, regs);
  // mark the thread's registers
  markStackObjectsConservatively((void*)®s, (void*)((char*)®s + regSize));
  void* stackPointer = otherThreadStackPointer(regs);
  void* stackBase = otherThreadStackBase(regs, thread);
  resumeThread(thread->platformThread);
#endif
void Collector::markStackObjectsConservatively()
  markCurrentThreadConservatively();
  for (Thread *thread = registeredThreads; thread != NULL; thread = thread->next) {
    if (!pthread_equal(thread->posixThread, pthread_self())) {
      markOtherThreadConservatively(thread);
#endif
typedef HashCountedSet ProtectCountSet;
static ProtectCountSet& protectedValues() {
    static ProtectCountSet staticProtectCountSet;
    return staticProtectCountSet;
void Collector::protect(JSValue *k)
    ASSERT(k);
    if (JSImmediate::isImmediate(k))
      return;
    protectedValues().add(k->asCell());
void Collector::unprotect(JSValue *k)
    ASSERT(k);
      return;
    protectedValues().remove(k->asCell());
void Collector::collectOnMainThreadOnly(JSValue* value) {
    ASSERT(value);
    if (JSImmediate::isImmediate(value))
      return;
    JSCell* cell = value->asCell();
    cellBlock(cell)->collectOnMainThreadOnly.set(cellOffset(cell));
    ++mainThreadOnlyObjectCount;
void Collector::markProtectedObjects()
  ProtectCountSet& protectedValues = KJS::protectedValues();
  ProtectCountSet::iterator end = protectedValues.end();
  for (ProtectCountSet::iterator it = protectedValues.begin(); it != end; ++it) {
    JSCell *val = it->first;
    if (!val->marked())
      val->mark();
void Collector::markMainThreadOnlyObjects()
    ASSERT(!onMainThread());
#endif
    // Optimization for clients that never register "main thread only" objects.
    if (!mainThreadOnlyObjectCount)
        return;
    // FIXME: We can optimize this marking algorithm by keeping an exact set of
    // "main thread only" objects when the "main thread only" object count is
    // small. We don't want to keep an exact set all the time, because WebCore
    // tends to create lots of "main thread only" objects, and all that set
    // thrashing can be expensive.
    size_t count = 0;
    for (size_t block = 0; block < heap.usedBlocks; block++) {
        ASSERT(count < mainThreadOnlyObjectCount);
        CollectorBlock* curBlock = heap.blocks[block];
        size_t minimumCellsToProcess = curBlock->usedCells;
        for (size_t i = 0; (i < minimumCellsToProcess) & (i < CELLS_PER_BLOCK); i++) {
            CollectorCell* cell = curBlock->cells + i;
            if (cell->u.freeCell.zeroIfFree == 0)
                ++minimumCellsToProcess;
            else {
                if (curBlock->collectOnMainThreadOnly.get(i)) {
                    if (!curBlock->marked.get(i)) {
                        JSCell* imp = reinterpret_cast(cell);
                        imp->mark();
                    if (++count == mainThreadOnlyObjectCount)
                        return;
bool Collector::collect()
  if (heap.operationInProgress != NoOperation)
    abort();
  heap.operationInProgress = Collection;
  bool currentThreadIsMainThread = onMainThread();
  // MARK: first mark all referenced objects recursively starting out from the set of root objects
#ifndef NDEBUG
  // Forbid malloc during the mark phase. Marking a thread suspends it, so
  // a malloc inside mark() would risk a deadlock with a thread that had been
  // suspended while holding the malloc lock.
  fastMallocForbid();
#endif
  if (Interpreter::s_hook) {
    Interpreter* scr = Interpreter::s_hook;
    do {
      scr->mark();
      scr = scr->next;
    } while (scr != Interpreter::s_hook);
  markStackObjectsConservatively();
  markProtectedObjects();
  List::markProtectedLists();
  if (!currentThreadIsMainThread)
    markMainThreadOnlyObjects();
#endif
#ifndef NDEBUG
  fastMallocAllow();
#endif
  // SWEEP: delete everything with a zero refcount (garbage) and unmark everything else
  size_t emptyBlocks = 0;
    CollectorBlock *curBlock = heap.blocks[block];
    size_t usedCells = curBlock->usedCells;
    CollectorCell *freeList = curBlock->freeList;
    if (usedCells == CELLS_PER_BLOCK) {
      // special case with a block where all cells are used -- testing indicates this happens often
      for (size_t i = 0; i < CELLS_PER_BLOCK; i++) {
          // special case for allocated but uninitialized object
          // (We don't need this check earlier because nothing prior this point
          // assumes the object has a valid vptr.)
            continue;
          ASSERT(currentThreadIsMainThread || !curBlock->collectOnMainThreadOnly.get(i));
            curBlock->collectOnMainThreadOnly.clear(i);
            --mainThreadOnlyObjectCount;
          imp->~JSCell();
          --usedCells;
          --numLiveObjects;
          // put cell on the free list
          cell->u.freeCell.zeroIfFree = 0;
          cell->u.freeCell.next = reinterpret_cast(freeList) - reinterpret_cast(cell + 1);
          freeList = cell;
    } else {
      size_t minimumCellsToProcess = usedCells;
        CollectorCell *cell = curBlock->cells + i;
        if (cell->u.freeCell.zeroIfFree == 0) {
        } else {
            JSCell *imp = reinterpret_cast(cell);
            imp->~JSCell();
            --usedCells;
            --numLiveObjects;
            freeList = cell;
    curBlock->usedCells = static_cast(usedCells);
    curBlock->freeList = freeList;
    curBlock->marked.clearAll();
    if (usedCells == 0) {
      emptyBlocks++;
      if (emptyBlocks > SPARE_EMPTY_BLOCKS) { #if !DEBUG_COLLECTOR
        freeBlock(curBlock);
#endif
        // swap with the last block so we compact as we go
        heap.blocks[block] = heap.blocks[heap.usedBlocks - 1];
        heap.usedBlocks--;
        block--; // Don't move forward a step in this case
        if (heap.numBlocks > MIN_ARRAY_SIZE && heap.usedBlocks < heap.numBlocks / LOW_WATER_FACTOR) {
          heap.numBlocks = heap.numBlocks / GROWTH_FACTOR;
          heap.blocks = (CollectorBlock **)fastRealloc(heap.blocks, heap.numBlocks * sizeof(CollectorBlock *));
  if (heap.numLiveObjects != numLiveObjects)
    heap.firstBlockWithPossibleSpace = 0;
  bool deleted = heap.numLiveObjects != numLiveObjects;
  heap.numLiveObjects = numLiveObjects;
  heap.numLiveObjectsAtLastCollect = numLiveObjects;
  heap.extraCost = 0;
  memoryFull = (numLiveObjects >= KJS_MEM_LIMIT);
  return deleted;
size_t Collector::size()
  return heap.numLiveObjects;
size_t Collector::numInterpreters()
  size_t count = 0;
    do {
      ++count;
      scr = scr->next;
  return count;
size_t Collector::numProtectedObjects()
  return protectedValues().size();
static const char *typeName(JSCell *val) {
  const char *name = "???";
  switch (val->type()) {
    case UnspecifiedType:
      break;
    case UndefinedType:
      name = "undefined";
      break;
    case NullType:
      name = "null";
      break;
    case BooleanType:
      name = "boolean";
      break;
    case StringType:
      name = "string";
      break;
    case NumberType:
      name = "number";
      break;
    case ObjectType: {
      const ClassInfo *info = static_cast(val)->classInfo();
      name = info ? info->className : "Object";
      break;
    case GetterSetterType:
      name = "gettersetter";
      break;
  return name;
HashCountedSet* Collector::rootObjectTypeCounts() {
    HashCountedSet* counts = new HashCountedSet;
        counts->add(typeName(it->first));
    return counts;
bool Collector::isBusy()
    return heap.operationInProgress != NoOperation; }
} // namespace KJS
...don't forget to uncomment the code
Note as a general rule you shouldn't try and make stuff outside of the buildroot framework - that is, never change in to a directory and run make yourself. There's a decent chance that buildroot will need to run make with an environment set or extra variables or something. If you want to rebuild something in buildroot then just remove the ".stamp_configured" and ".stamp_built" files from the build directory (eg build_avr32/qt-embedded-whatever) then run "make" in the top level buildroot folder.
-S.
artmedia, the patch works!, thank you. :lol:
