watch dog timer won't disable in AVR Studio
9 posts / 0 new
Using an ATmega640. It worked fine.
Enabled WDT using latest version of AVR Studio b623 using Fuses tab.
My ATmega640 would then reset crazy fast. As expected.
Now I go back to Fuses and remove the check to WDT.
My ATmega640 still resets crazy fast. Despite AVR Studio claiming its off, it won't actually turn WDT off!
(power supply is fine)
Anyone seen this problem or know what I'm doing wrong?
How do YOU make a robot?
http://www.societyofrobots.com
And you did actually click the Program button after that?
Thanks for your confidence in me :?
Yeap I clicked the program button. Many times. :P
Can you correctly read the AVR signature? If not, the indication of the WDTON fuse state might be wrong.
Did you also erase the chip to remove any program code that might be misbehaving?
Can you high voltage parallel program your AVR to positively clear the WDTON fuse, even if the AVR clock fuses are messed up, etc.?
Try to verify that you are actually changing your program on the device. Lengthen the WDT time out and see if the changes the period. Have you changed any other flags?
A
AVR Studio 4 Ver. 4.18 684
avr-gcc Ver. 4.3.0
ISIS 7
ELECTRA
Nothing personal. Going on my own experience. See eg http://www.avrfreaks.net/index.p... :D
Not sure about this one, but also be sure to power cycle the target (if you have not already). Seem to remember having a similar experience with a mega48. Backup batteries/supercaps can confuse the issue.
-carl
I know this is an old subject, however, I have just encountered the same problem and further information may be of use to others looking for a solution to this.
I enable the watch dog timer using and the function wdt_enable(WDTO_30MS);. When I restart the program, I call wdt_disable();. Watching the IO view I can see that the watchdog timer is NOT actually being disabled, despite the program having been reset through Atmel studio, or reset by cycling the power to the device.
Setting MCUSR to 0x00 (clearing the reset flags), before calling the wdt_disable() function successfully disables the watchdog timer.
Looking into this further, the datasheet for the atmega1280 I am using does explain why:
• Bit 3 - WDE: Watchdog System Reset Enable
WDE is overridden by WDRF in MCUSR. This means that WDE is always set when WDRF is
set. To clear WDE, WDRF must be cleared first. This feature ensures multiple resets during conditions
causing failure, and a safe start-up after the failure.
So does looking at the documentation for wdt_disable().
JJ
"Read a lot.  Write a lot."
