Interfacing USART from 3v 'mega to 5v 'mega
6 posts / 0 new
I need to interface two AVRs via their TX/RX USART pins. The catch is, one is running at 3v (the AVR on my SunSPOT's i/o board), and one is running at 5v (the AVR inside a Robotis Dynamixel motor). I know somebody makes a nice DIP IC to sit between them and do all the level conversion transparently, and it's probably from TI (though Maxim almost certainly has one or more in non-DIP form)... but which specific one is it?
Oh, I almost forgot... it has to be fast enough to support 1mbps (115kbps isn't good enough).
There's no place like ~/
http://para.maxim-ic.com/cache/e...
All MAxim has to offer ;) maybe you can find something in the list
http://www.maxim-ic.com/quick_vi...
MAX3394E seems OK for you. 2 channels, 6Mbps. 1.2-5.5V
Actually, this might make it easier... or harder...
I just realized that since the Bioloid serial uses only a single pin (using a 74hc126 and 74hc04 to route that single lead to tx or rx at the controller end), what I REALLY need is a chip that can bidirectionally convert a single line (putting the 74hc126 and 74hc04 on the "3v" side and eliminating the need to level-shift between the 3v mega and the logic chips themselves).
If it matters, I CAN tell the level-translator chip which direction data is supposed to be flowing (one of the AVR's output pins goes high or low to pick one of the two drivers on the 74hc126 -- see http://robosavvy.com/forum/viewt... for an example).
Or... would I be better off putting the 74hc126 and 74hc04 on the "5v" side, and level-shifting 3 pins... two output pins (from the 3v sunspot's AVR's TX and one other i/o pin) and one input pin (to the 3v sunspot's AVR's RX pin).
Another question... if I had a Maxim level-conversion IC like the MAX3370 sitting between TX3v and RX5v, and between RX3v and TX5v, would it be considered "open-drain" or "push-pull"? How about if I had a single MAX3370 between a 74hc126 running at 3v and the Bioloid Dynamixel's 5v half-duplex serial line?
@miamicanes
This sounds a lot like a bidir I2C/TWI levelshifter , but at 1Mbit i dont know ...
Have a "Search" :-)
Well Philips has made a 1Mbit I2C standard called fm+
http://www.embedded.com/showArti...
/Bingo
Well, I went ahead and ordered a few SN74LVC1T45DBVR level shifters to get my order in before the 3pm CST Mouser deadline for same-day shipping.
Basically, you connect both power supplies to the chip (one determines the output level for pin 'A', the other determines the output level for pin 'B') and set a pin low or high to tell it whether you want it to read data from pin A and output it to pin B, or read data from pin B and output it to pin A. Allegedly, at Vcc=3.0v, they can handle somewhere between 220mbps and 420mbps (not sure since the example they gave was 3.3v to 5.0v = 420, and 2.5v->3.3v=220mbps).
I also ordered a few TI PCA9306DCTR chips, which are explicitly designed to sit between an I2C bus running at one voltage and a client running at different one.
I did, however, trip across a pair of new Maxim chips that look interesting for future projects... the MAX7300 and MAX7301. They're 28-port i/o expanders that appear to include just about every meaningful feature and option you could possibly want in one... in i2c and SPI versions. Unfortunately, they aren't available yet.
