XMEGA A1U - Is it possible to create a PCB with an embedded debug USB?
12 posts / 0 new
On the A1U eval board, there is a target USB and a debug USB. I was wondering if it was possible to keep this feature (the debug USB) when moving over to a pcb. I've read a bit into it, and it looks like it's just a few pins mapped to a USB port, but I am probably way off.
PenguinWasHere wrote:
the A1U eval board
You mean the XMEGA A1U Xplained Pro Evaluation Kit
Part Number: ATXMEGAA1U-XPRO
http://www.microchip.com/DevelopmentTools/ProductDetails.aspx?PartNO=atxmegaa1u-xpro
I don't think you can buy the EDBG chip anyhow, but why would you want to do this?
No:  it is a second microcontroller - effectively, an Atmel-ICE built onto the PCB.
See section 3.1. Embedded Debugger in the User Guide: http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-42211-XMEGA-A1U-Xplained-Pro_User-Guide.pdf
Again, why would you want to include that in a final product??
EDIT
typo
USB debug can be very useful on production hardware. Techs in the field can get diagnostic data out, load diagnostic firmware etc. No need for a bootloader, firmware update can't really fail as you can always retry with a built in programmer.
I've never seen that. If it were offered presumably people would be under-cutting Atmel-ICE sales right left and centre?
But I still don't see the point of putting, effectively, a full AtmelICE into the shipping product.
The usual approach would be to provide the debug header, so the "Techs in the field" can apply their AtmelICE ...
I wonder why nobody does that - especially considering the cheap ST-Link knock-offs you can buy on ebay, et al ...
(and a genuine ST-Link is only about twenty quid anyhow).
Did Atmel really manage to secure their EDBG so much better than ST ?
I thought that the EDBG chip was just an ordinary Atmel MCU, maybe a AT32UC3A4256.
If that is the case then cloning it shouldn't be difficult.
That's a feature of the MattairTech XMEGA128A1U board :
MattairTech LLC
MattairTech
Development Boards
MT-X1S ATxmega128a1u USB development board
https://www.mattairtech.com/index.php/development-boards/mt-x1s-atxmega128a1-u-usb-development-board.html
Revision B now available!
USB can now connect directly to the XMEGA USB pins.
The XMEGA can be programmed over USB using the optional onboard AVRISP mkII compatible PDI programmer.
Debug over PDI is proprietary though can be decoded:
https://sigrok.org/wiki/Protocol_decoder:Avr_pdi
Program over PDI is in the datasheet.
Edit: sigrok
Except that the code inside it is presumably "secure" (or at least as secure as the lockbits though I think there are some models of AVr32 that have a "vault" which is presumably something quite a lot more secure).
The reason there are no clones is that Atmel don't document their debug protocols though a lot of it has been reverse engineered.
Yes, it is - just like the ST-Link is just an ordinary STM32
Yes - that was my point in #6
But neither do ST - do they?
No idea - the last time I used an ST micro it was an FM-RDS decoding dedicated one based on STM-7 this was about '97..'99
I don't think that will stop anyone... Last time I looked they were doing simple things like placing a metal plate over the lock bits to prevent erasure with UV, which is easily circumvented by holding the UV light at an angle so it bounces under it.
