PCINT: why my code on port C don't work?
3 posts / 0 new
I want use PCINT on port C.
My code compile but no ISR happen.
What is wrong?
-------------------- CODE ----------------------------------------------------
#include <avr/interrupt.h>
#define Port_C0_PinA0 A0       //PCINT8
volatile byte port_C_status=1;
volatile byte actual_Port_Value =0;
void setup(){
Serial.begin(9600);
pinMode(Port_C0_PinA0, INPUT);         //Set port in Pull Up Mode
digitalWrite (Port_C0_PinA0, HIGH);      //pull-up mode enabled
cli();     //Disable interrupt
bitSet(PCICR, 1);  //Enable PCINT Interrupt For port C
Serial.print("PCRCI= "); Serial.println(PCICR, BIN);
bitSet(PCMSK1, 0);   //mask for Pin A0
sei(); //Enable interrupt
void loop(){
//idle
//PORT C INTERRUPT MANAGER
ISR (PCINT1_vect)
 cli();
 actual_Port_Value = PINC;
 if ( bitRead(actual_Port_Value,0) ==1 && bitRead(port_C_status,0)==0 )  Serial.println("Analog Pin 0");
 sei();
}//isr
How to properly post source code: http://www.avrfreaks.net/comment...
Hi, you need to declare the interrupt:
attachInterrupt(digitalPinToInterrupt(pin), ISR, mode); // mode LOW, HIGH, RISING, FALLING or CHANGE
Beware that not all pins support interrupt.
