atmega328p watchdog confusion
21 posts / 0 new
Hi all
I was designing a circuit and thought to implement watchdog system reset(not interrupt driven)in case of any accidental freezing of the MCU(The MCU will work in a very harsh environment).
Please take a look at the code below.
#include <avr/wdt.h>
    wdt_disable();
    some other setup
    wdt_enable(WDTO_8S);
        wdt_reset();
        some other task
Should this code work or should I turn on WDTON fuse?There are example on the web but they are not very clear and max example uses interrupt driven method.But my main target is only to reset the system in case of any freezing.
What is going to cause your processor to freeze?
???  What do you mean by "interrupt driven method"?  What do you want it to do for you?
Again, what do you expect it to do?  Will your posted fragment "work"?  It looks like it wil indeed enable the WDT.  There are some comments about your posted code, though.  In a "real" full application, doing a WDR blindly every main loop only tells you that the main loop is being run once in a while.  It doesn't help if e.g. your interrupts aren't firing so you get no timer ticks or sensor readings or host communications.  Do the reset with an "AND" of all important conditions.
Do a Google search for "ganssle watchdog".
I've said that before, and also about the AND in prior discussions.  Have you looked for those?
http://www.avrfreaks.net/comment...
http://www.avrfreaks.net/forum/w... [code looks identical to yours]
The CPU will work in a very high frequency RF environment.
So, what does that directly have to do with watchdog operation?
Is that environment creating noise, such that Absolute Maximum Ratings of the AVR are violated?  If so, anything can happen including chip damage.  When operationd >>within<< limits, then tell what you are trying to protect against.
From datasheet:
WDTON Fuse Unprogrammed:
In this mode, the Watchdog Timer is initially disabled, but can be enabled by writing the WDE bit to 1 without any restriction.
A timed sequence is needed when changing the Watchdog Time-out period or disabling an enabled Watchdog Timer.
WDTON Fuse Programmed:
In this mode, the Watchdog Timer is always enabled, and the WDE bit will always read as one. A timed sequence is needed when changing the Watchdog Time-out period.
Therefore, disabling the Watchdog Timer (to save power for example, mainly in sleep modes) is possible if the fuse is unprogrammed only.
Where to insert the instructions 'WDR' [equivalent to wdt_reset(), I guess], in a code, needs to be considered carefully.
And what to do after an MCU reset by the Watchdog also depends on the application.
        wdt_reset();
        some other task
Impossible to say whether that will work without knowing what "some other task" is and how long it may be away doing it.
While you can opt for a single wdt_reset() in the core loop in main() that then relies on everything that is invoked in main() getting back within the WDT period. If things you call to are themselves "blocking" then you may want to wdt_reset()s in the loops where they block too.
I have wdt_reset() many times within the while loop.There are so many modules in my program.I just wanted to know how to initiate it.That's why i posted this skeleton code.
I was having trouble with the wdt_disable().With wdt disable,the cpu was stuck in a never ending reset.So i omitted it and now the reset is working as expected.I tested with a delay_ms more than wdt delay and also implemented it in my final coding...
Did you read the user manual?:
Note in particular the paragraph that starts "Note that for newer devices...". That applies to a 328P
(You put the wdt_disable() in .init3 and not at the start of main() so it is on the "other side" of the _do_copy_data() and _do_clear_bss() loops)
According to AVR132,there is no need to disable the wdt if i only want to reset the system.That's why I omitted the wdt_disable().Is my understanding correct?
The paragraph you highlighted is the exact reason the manual says:
Note that for newer devices (ATmega88 and newer, effectively any AVR that has the option to also generate interrupts), the watchdog timer remains active even after a system reset (except a power-on condition), using the fastest prescaler value (approximately 15 ms). It is therefore required to turn off the watchdog early during program startup, the datasheet recommends a sequence like the following:
#include <stdint.h>
uint8_t mcusr_mirror __attribute__ ((section (".noinit")));
void get_mcusr(void) \
__attribute__((naked)) \
__attribute__((section(".init3")));
mcusr_mirror = MCUSR;
MCUSR = 0;
wdt_disable();
Saving the value of MCUSR in mcusr_mirror is only needed if the application later wants to examine the reset source, but in particular, clearing the watchdog reset flag before disabling the watchdog is required, according to the datasheet.
Make a note that when the WD resets the MPU, it also "resets" its own timeout value to the smallest timeout, but remains enabled, so you need to quickly disable it or reset its timeout value upon reset.
At least it does for the 328/168/88/48 family.....
Ok...as my understanding goes,this is as follows(Please check the comments).Please correct me If i am wrong.
#include <stdint.h>
__attribute__((section(".init3")));//This is the function definition
void get_mcusr(void)//This is the declaration
MCUSR = 0;
wdt_disable();
Now,where should I call the function get_mcuscr()?Should I call it at the first line of main?
that drops the code into .init3 as described in:
A simple example shows how this works. If I write a virtually "empty" C program first:
C:\SysGCC\avr\bin>type avr.c
char text[] = "hello";
uint8_t buffer[10];
int main(void) {
        while(1);
C:\SysGCC\avr\bin>avr-gcc -mmcu=attiny13 -Os avr.c -o avr.elf
C:\SysGCC\avr\bin>avr-objdump -d avr.elf
avr.elf:     file format elf32-avr
Disassembly of section .text:
00000000 <__vectors>:
   0:   09 c0           rjmp    .+18            ; 0x14 <__ctors_end>
   2:   21 c0           rjmp    .+66            ; 0x46 <__bad_interrupt>
   4:   20 c0           rjmp    .+64            ; 0x46 <__bad_interrupt>
   6:   1f c0           rjmp    .+62            ; 0x46 <__bad_interrupt>
   8:   1e c0           rjmp    .+60            ; 0x46 <__bad_interrupt>
   a:   1d c0           rjmp    .+58            ; 0x46 <__bad_interrupt>
   c:   1c c0           rjmp    .+56            ; 0x46 <__bad_interrupt>
   e:   1b c0           rjmp    .+54            ; 0x46 <__bad_interrupt>
  10:   1a c0           rjmp    .+52            ; 0x46 <__bad_interrupt>
  12:   19 c0           rjmp    .+50            ; 0x46 <__bad_interrupt>
00000014 <__ctors_end>:
  14:   11 24           eor     r1, r1
  16:   1f be           out     0x3f, r1        ; 63
  18:   cf e9           ldi     r28, 0x9F       ; 159
  1a:   cd bf           out     0x3d, r28       ; 61
0000001c <__do_copy_data>:
  1c:   10 e0           ldi     r17, 0x00       ; 0
  1e:   a0 e6           ldi     r26, 0x60       ; 96
  20:   b0 e0           ldi     r27, 0x00       ; 0
  22:   ee e4           ldi     r30, 0x4E       ; 78
  24:   f0 e0           ldi     r31, 0x00       ; 0
  26:   02 c0           rjmp    .+4             ; 0x2c <__do_copy_data+0x10>
  28:   05 90           lpm     r0, Z+
  2a:   0d 92           st      X+, r0
  2c:   a6 36           cpi     r26, 0x66       ; 102
  2e:   b1 07           cpc     r27, r17
  30:   d9 f7           brne    .-10            ; 0x28 <__do_copy_data+0xc>
00000032 <__do_clear_bss>:
  32:   20 e0           ldi     r18, 0x00       ; 0
  34:   a6 e6           ldi     r26, 0x66       ; 102
  36:   b0 e0           ldi     r27, 0x00       ; 0
  38:   01 c0           rjmp    .+2             ; 0x3c <.do_clear_bss_start>
0000003a <.do_clear_bss_loop>:
  3a:   1d 92           st      X+, r1
0000003c <.do_clear_bss_start>:
  3c:   a0 37           cpi     r26, 0x70       ; 112
  3e:   b2 07           cpc     r27, r18
  40:   e1 f7           brne    .-8             ; 0x3a <.do_clear_bss_loop>
  42:   02 d0           rcall   .+4             ; 0x48 <main>
  44:   02 c0           rjmp    .+4             ; 0x4a <_exit>
00000046 <__bad_interrupt>:
  46:   dc cf           rjmp    .-72            ; 0x0 <__vectors>
00000048 <main>:
  48:   ff cf           rjmp    .-2             ; 0x48 <main>
0000004a <_exit>:
  4a:   f8 94           cli
0000004c <__stop_program>:
  4c:   ff cf           rjmp    .-2             ; 0x4c <__stop_program>
Notice that because I included the variables "text[]" and "buffer[]" that this caused the compiler to build _do_copy_data() (to copy "hello" from flash to RAM) and _do_clear_bss() (to set all of buffer to 0x00) into the image. They are routines in ".init4" so they come after the initial setup code in .init2:
but before the code that actually calls main():
which is in .init9. So now when you add:
uint8_t buffer[10];
__attribute__((section(".init3"), naked)) void some_name_or_other(void) {
	DDRB = 0xAA;
int main(void) {
	while(1);
what happens is this:
  [SNIP]
0000001c <some_name_or_other>:
  1c:   8a ea           ldi     r24, 0xAA       ; 170
  1e:   87 bb           out     0x17, r24       ; 23
00000020 <__do_copy_data>:
  20:   10 e0           ldi     r17, 0x00       ; 0
  22:   a0 e6           ldi     r26, 0x60       ; 96
  24:   b0 e0           ldi     r27, 0x00       ; 0
  26:   e2 e5           ldi     r30, 0x52       ; 82
  28:   f0 e0           ldi     r31, 0x00       ; 0
  [SNIP]
The new code has been squeezed in between .init2 and .init4 so it is after the initial setup but before the _do_stuff() loops. It is not called and it's function name does not matter as it just appears "inline" between those other two .init sections. The use of "naked" in the __attribute__ was to say don't put usual function prologue and epilogue on this code. In particular this means it does not have a "RET" on the end as normal function code would (because at that point in .init3 nothing has CALLd so a RET would be disastrous).
Thanks a lot for the in depth explanation.I don't want the MCUCR backup.So,now i will write the code like this below.
void wdt_init(void) __attribute__((naked)) __attribute__((section(".init3")));
void wdt_init(void)
	MCUSR = 0;
	wdt_disable();
//other init
//tasks
wdt_reset();
//some other tasks
Is it ok now?
I implemented wdt_disable() as I mentioned in the previous post!Now I can see some random resets in the circuit.When I didn't implemented the wdt_disable(),the circuit was running properly.Why this is happening?Now my main.c code is as follows...
 * sigalert_v1.0.c
 * Created: 12-12-2017 13:09:07
 * Author : SHARANYA
#include <util/delay.h>
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include <avr/interrupt.h>
#include "uart.h"
#include "twi.h"
#include "mcp3424.h"
#include "simcom.h"
#include "ds18b20.h"
#define sensor_pin PINB
#define sensor_ddr DDRB
#define sensor_port PORTB
#define sensor_1 1
#define sensor_2 2
#define sensor_3 3
#define sensor_4 4
#define sensor_5 5
void wdt_init(void)
	MCUSR = 0;
	wdt_disable();
volatile uint8_t sensor_change = 0;
void enbl_pcintr0(void)
	PCICR |= (1<<PCIE0);
	PCMSK0 |= (1<<PCINT1);
	sei();
void disbl_pcintr0(void)
	PCICR = 0X00;
	PCMSK0 = 0X00;
	cli();
ISR (PCINT0_vect)
	sensor_change = 1;
uint8_t check_sensor(uint8_t sensor_no)
	uint8_t state;
	if(bit_is_set(sensor_pin,sensor_no))
	_delay_ms(20);
	state = 1;
	state = 0;
	return state;
void check_state(void)
	wdt_reset();
	double temp = 0;
	if(check_sensor(sensor_1))
		sim900_sendsms(8,0,0,"Alert,door open!!");
		sensor_change = 0;
		wdt_reset();
		_delay_ms(5000);
		wdt_reset();
	else if(sensor_change)
		sim900_sendsms(8,0,0,"Alert,door movement detected!!");
		sensor_change = 0;
		wdt_reset();
		_delay_ms(5000);
		wdt_reset();
	temp = read_temp();
	if(temp == 0)
		sim900_sendsms(8,0,0,"Error!!check temp sensor & connection");
		wdt_reset();
		_delay_ms(5000);
		wdt_reset();
	else if(temp>hrt)
		sim900_sendsms(8,0,0,"Alert!!High temp detected...");
		wdt_reset();
		_delay_ms(5000);
		wdt_reset();
	if(read_volt()<=low_dc)
		sim900_sendsms(8,0,0,"Alert!!Low DC detected...");
		wdt_reset();
		_delay_ms(5000);
		wdt_reset();
	wdt_reset();
	sensor_ddr &= ~((1<<1)|(1<<2)|(1<<3)|(1<<4));//input for door sensors
	sensor_port |= (1<<1)|(1<<2)|(1<<3)|(1<<4);//pullup enable
	DDRB |= (1<<5);//Output for MOSFET
	PORTB &= ~(1<<5);//Turn the MOSFET ON to power up the modem
	uint8_t alert_state = 1;//by default,enable alert
	uint32_t timer_count = 0;//Init a timer counter.Send sms approx every 1hr later if alert found disable
	uart_init();
	sim900_init();
    while (1)
	wdt_reset();
	if(alert_state)
		check_state();
	sim900_chksms();
	if(err_res)
		sim900_init();
	switch (usrcmd_no)
	case 1:
		sim900_sendsms(1,0,read_temp(),0);
		usrcmd_no = 0;
		break;
	case 2:
		sim900_sendsms(2,0,read_amp(),0);
		usrcmd_no = 0;
		break;
	case 3:
		sim900_sendsms(3,0,read_volt(),0);
		usrcmd_no = 0;
		break;
	case 4:
		sim900_sendsms(4,0,low_dc,0);
		usrcmd_no = 0;
		break;
	case 5:
		sim900_sendsms(5,0,hrt,0);
		usrcmd_no = 0;
		break;
	case 6:
		alert_state = 1;
		timer_count = 0;
		sim900_sendsms(6,0,0,0);
		usrcmd_no = 0;
		break;
	case 7:
		alert_state = 0;
		timer_count = 0;
		sim900_sendsms(7,0,0,0);
		usrcmd_no = 0;
		break;
	case 8:
		sim900_sendsms(8,0,0,"Mobile no updated\r\n!!");
		usrcmd_no = 0;
		break;
	enbl_pcintr0();//Enable interrupt to detect door open/close during delay
	delay_s(30);//wait for 30s before next check
	disbl_pcintr0();//disable interrupt
	if(!(alert_state))
		timer_count++;
	if(!(alert_state) && (timer_count>=120))
		timer_count = 0;//reset timer count to send sms after 1hr
Is there something to do with fuse bits?Please help....
		wdt_reset();
		_delay_ms(5000);
		wdt_reset();
How long is your watchdog period?!?!? It surely cannot be more than 5 seconds. So this code is bound to cause the AVR to reset.
No sensible micro program is ever going to be using _delay_ms() calls anyway but if you do use it for 5 seconds you really need to do something like:
for (int i = 0; i < 50; i++) {
    _delay_ms(100);
    wdt_reset();
This way the WDR is done every 100ms. As long as that is well within the chosen WDT period it should be getting reset often enough.
But the fact is that a micro program that is going to use a watchdog should have that requirement designed in from the start. The watchdog is not something (like documentation!) that you can leave to the very last minute then pepper a few WDRs across the already written code. If it was designed in from the start then for every action of the code (where it waits for things like UDRE or RXC or whatever for example) you would be considering whether WDRs are needed. And you would never have chosen to use _delay_ms(5000)!
Did you somehow think that _delay_ms() contained WDRs perhaps? It doesn't. (apart from anything else they would skew the timing or at least have to be accounted for).
Ah, just scanned the code some more and spotted:
so if it is 8 seconds then you might get away with those 5 second delays. But I'd still break the _delay_ms() down with WDRs anyway
I have already done a wdt_reset after _delay_ms within a for loop at another header file which is used for larger delays(30s).So what is your suggestion to avoid this
Professional micro projects almost always run a timer (maybe more than one though a large number of activities can be "ganged" off just a single tick). Typically such time ISR run at something like 10ms ticks. If you want something to delay you just wait until some tick count has counted to 500 lots of 10ms or whatever.
