A Counter with precise delay in Atmega 2560
22 posts / 0 new
Hello...My task is to initialize the Timer 1 in Normal mode with initial count value of 0 and a frequency division factor of 256 and to display on the first row and first column of LCD, the number of times, the Timer has overflowed and on 5th such overflow, stop the timer and indicate this by turning ON buzzer for 2 seconds.
#define F_CPU 14745600
#include <avr/interrupt.h>
#include <util/delay.h>
#include "lcd.h"		// user-defined header file - it is included in project folder
volatile unsigned int counter=0; // A global variable to act as a counter
 void buzzer_on (void)
	unsigned char port_restore = 0;
	port_restore = PINC;
	port_restore = port_restore | 0x08;
	PORTC = port_restore;
void buzzer_off (void)
  // PORTC=;      // Set PC3 to "0", making sure that other port pin values are unaffected.
 port_restore = port_restore & 0xF7;
void lcd_port_config (void)
		DDRC =	DDRC | 0xF7;	//all the LCD pin's direction set as output
		PORTC=	PORTC & 0x80; 	// all the LCD pins are set to logic 0 except PORTC 7
void timer1_init(void)
	TCCR1A = 0x00;	 // Timer 1 mode selection (Use Normal mode)
	TCCR1B = 0x00;  //Timer 1 mode selection
	TCNT1H = 0x1F; 	 //Counter higher 8 bit value
	TCNT1L = 0x01; 	 //Counter lower 8 bit value
	TCCR1B=  0x04;	 //start Timer by selecting prescalar factor 256 (avoid overwriting mode selection bits)
ISR(TIMER1_OVF_vect)
	//TIMER1 has overflowed
	if(counter<=5)
	counter=counter+1;   // increment counter variable every time, the overflow occurs.
	TCNT1H =0x1F;	//reload counter high value
	TCNT1L =0x01;	//reload counter low value
void interrupt_init()
	cli();    //Clears the global interrupts
	TIMSK1 = 0x01;  //TIMER 1 overflow interrupt enable
	sei();   //Enables the global interrupts
void indicate_and_buzz(void)
	//int column=1;
	//for(int i=1;i<=5;i++)
		lcd_numeric_value(1,1,counter,3);
	buzzer_on();
	_delay_ms(2000);
	buzzer_off();
//Please do not make any changes in the main function
int main (void)
	lcd_port_config();
	lcd_init();
	interrupt_init();
//	lcd_init();    // function is defined in the header file "lcd.h"
	timer1_init();
	indicate_and_buzz();
help me with this
Pushing for a response 7 minutes after first posting isn't going to win you any friends.  If you tell us when you have to hand in your homework we will give you a response.
David
Don't you need to wait until the value of counter changes before you display it, or does
do that for you?
...and posting in the wrong forum doesn't help either. I'll move the thread.
@Raving Lunatic...yes i have to wait until the counter changes its value..so where can I write lcd_numeric_value() function so that the lcd will display the value of counter starting from 1?
Since when does "Level" mean "name"?
And since when did the word "please" get dropped from requests for help?
Make sure any variables shared by irq & non-irq  code are declared  as volatile (ex, your counter variable).
you are not monitoring/checking the counter overflow anywhere at all...so nothing has any idea if 5 have occurred & it is then time to sound the alarm.
It will set everything up , then  do something to the display 5 times and buzz, regardless of whether the timer did anything at all.
how about simply:
PORTC |= (1<<PC3)  //set pin
PORTC &= ~(1<<PC3) //clear pin
Here, I have Edited my code. I have checked the overflow value but i have no idea how to stop timer or how to get out from while loop. Here i have got number displaying from 0 to 6. but buzzeon() and buzzeroff() is not executed.
I hope you didn't edit the code in your original post....
You initialised the timer so do the opposite and you have a while condition which is checking the value of 1 and it will always be 1 so change the condition to something that you can change.
When is your assignment due in?
David
How about (generically, not exact code):
the loop:
display present count
if count equals 5
     [stop timer &
     sound buzzer]
since the timer is stopped, the count will stay halted forever
There are many other arrangements possible...this example, the loop keeps going , "doing nothing"
Note, this rewrites the display at a very high speed (the loop), which is inefficient or may cause flickering (depending on the lcd code)....ideally you only write to the display when there is a new number...but start simple
i tried this code, but iam getting an error undefined reference to 'lcd_numeric_value'. how to solve it if any one knows pls help us
ranju
while(counter<=2)
lcd_print(1,1,counter,5);
with lcd_print funtion i have cleared my error.
ranju
my task is to initialize Timer 1 in Normal mode with a frequency division factor of 64. Using Timer 1, display a stopwatch with time starting from 00000 to 20000 (0 s to 20 s, time displayed in milliseconds). Display time in milliseconds up to five digits.
iam not getting the counter value increment. pls help me with this code.
TCCR1B=  0x03; //start Timer by selecting prescalar factor 256 (avoid overwriting mode selection bits)
if(counter<=20)
void time_calc(int counter)
for(int j=0;j<=20;j++)
_delay_ms(1000);
int main (void)
lcd_port_config();
interrupt_init();
lcd_init();                 //function is defined in the header file lcd.h
timer1_init();
time_calc(counter);
ranju
Are you in the same class as poojapatel? Why are you hijacking his thread?
we are not in the same class, we just tried that code to solve the query.
ranju
I am wondering
is there
a really
good
reason  that  you
put way too
much
spacing in your
code
that it
is impossible
to see  on
the
screen
at one
time
and understand
what
you have
written
I condensed
volatile unsigned int counter=0; // Global variable
void lcd_port_config (void){
	DDRC = DDRC | 0xF7; //all LCD pin's set as output
	PORTC= PORTC & 0x80; //all LCD pins are set to logic 0 except PORTC 7
void timer1_init(void){
	TCCR1B=  0x03; //start Timer, prescalar factor 256 (avoid overwriting mode selection bits)
ISR(TIMER1_OVF_vect){
	if(counter<=20)
		{counter=counter+1;}   // increment counter every overflow
void interrupt_init(){
void time_calc(int counter){
	for(int j=0;j<=20;j++){
	   _delay_ms(1000);}
int main (void){
	lcd_port_config();
	interrupt_init();
	timer1_init();
	time_calc(counter);
my doubt is how to calculate the total time elapsed from the above code
ranju
Do you want your timing defined by the IRQ or   _delay_ms(1000);....pick one or the other
yes i tried, but it is not working.
ranju
