display temperature and humidity on lcd
59 posts / 0 new
Pages
"Read a lot.  Write a lot."
If you remove your sensors and remove them with potmeters, do you have stable values then?
Are the values stable in proteus?
Paul van der Hoeven.
http://www.hoevendesign.com
Well, to have a comfortable LCD, I do the following thing:
int oldvalue = -999 // values are assumed to be positive (humidity : it is true; temperature are seldom that low
int threshold = 6 // arbitrary value (depends on the variability of what is to measure
forever {
  value = measure()
  if (abs (value - oldvalue) > threshold {
   oldvalue = value;
   display(value); // is only displayed when significant changes occur
BTW : have you thought of about decoupling capacitors?
"threshold" here is hysteresis.
agree with the greek synonym but I think, from OP long  pesting histery that -s-he cannot turn a wikipedia  article into pseudocode, then code....
BTW : I never use running averages nor prder 1 filters (though easy to implement: hide peaks, steps; never did need).
threshold can be deduced from data, when stationary (it is the basis of background with constant light filtering in an image) as
k* mean (abs(measure - previousMeasure)) (k is often 6.0)
Have you corrected the pin 20/21 issue?   they should not be tied together!
The AREF pin should only have a 100nf to ground tie to it.
While the AVCC should be connected to VCC and have a 100nf to ground....
If you believe that the LM35's output is oscillating (and it may because of draughty air flow), you could insert a first order low pass filter in between the LM35's output and your ADC input. If it does not improve, you can blame your software I guess.
Your idea of LM35 oscillating puzzles me:
Did OP and Proteus read and comply with
www.ti.com/lit/ds/symlink/lm35.pdf
"TI recommends adding a 0.1 μF from V+ to GND to bypass the power
supply voltage. Larger capacitances maybe required and are dependent on the power-supply noise." , chap9,  very head of the page..
Edited : each and evry chip should hav e at least 1 decoupling capacitors, except avr (need at least 2) . Hope Proteus h an arm, to solder them, if OP forgot...
Adding an analog RC filter between LM35 and AVR would either :
need another PCB
or
add loose connections to a lousy broadbeard. In thsi context, would be like adding typhus to cholera.
OTOH, avr can simulate 1rst order filters with one liners (say value2Display = alpha * value2Display + (1 -alpha) *valueMeasured;
alpha being, say 15/16 -4 bits : never will overflow; 1-alpha is trival; formula can be simplified, divisions optimized if needed).
I bet porteus can simulate avr simulating ....
Pages
