ADC Frequency
4 posts / 0 new
Hello. I'm not sure this post is in the right forum ... I use ATMega8-16 rated at 16 MHz and I'm surprises to see that ADC frequency is not conform to spec. Error is probably of my own ... Frequency is theorically 16 MHz / (2^^n) with in normal running 13 clocks per data numerized. In fact, according to n = 1 ... 7,  I found on scope (and also in simulation with Avr Studio) that total time used for one digitalization is 2 ^^ n multiply by
26, 20, 17, 15, 14, 14, 14 with n = 1 ... 7. Where is the error ?
Note the adc has a upper clock spec of around 153kHz so the conversion rate is only around 15kHz
Well technically it's 200kHz (to maintain 10 bits).
Problem is that 16MHz is a bad choice for ADC usage. 16MHz / 64 is 250kHz. Which is too fast while if you use /128 that only gives 125kHz.
A better choice of crystal might be something like 12.8MHz because 12.8MHz / 64 = 200kHz which will get the maximum 15.38kHz conversion rate. So a conversion time of 65us.
I have no idea why one would choose the ancient old dinosaur "mega8" if ADC performance is important. The Xmega range are far better suited for ADC use.
Many thanks for replies.
