AVR Programmer Questions
13 posts / 0 new
I'm very new to embedded systems, having been on the Arduino bandwagon for a while I am now finally getting my feet wet at the chip level. While reading Elliot Williams' "AVR Programming" book (among other resources) I'm methodically setting up my toolchain. I purchased SparkFun's AVR Pocket Programmer and it works great with AVRDUDE. I have been able to configure it to program a chip from both Windows and 'nix environments, it's a pretty great tool. But I am interested in following in the footsteps of those of you who do this for a living, that is, I would like to use the tools that are the standard in this community. With that said, I went and downloaded Atmel Studio and configured it to use the AVR Pocket Programmer through and External Tool, but it "feels" clunky as it just runs AVRDUDE after a build. It seems that using this programmer removes a bunch of capabilities that I may be interested in, for example, reading the fuses on the chip from the Device Programming windows (ctrl-shft-p)). So, two questions:
1) Are there other important things I can't do with Atmel Studio 7 in conjunction of a non-supported AVR programmer?
2) What programmer does the community use for professional work? Are there any that are affordable? Say, < $100?
Thanks for the help
I use these...
https://www.pololu.com/product/3170
...cheap enough to keep several on the bench.
I have three programmers that I use, Atmel ICE (replaced the once king AVRisp-mkii), AVRdragon, and a cheap Chinese USBASP.
The first two are support native in AS7.
For professional work: get an Atmel ICE - no question.
Even for a serious hobbyist.
Thanks for all the replies, everyone, thank you. Awneil, the Atmel ICE is likely what I need. I'm def. not a pro, but I would consider myself a serious hobbyist as my workshop at home is pretty intense. I just really like learning about this stuff (I'm a software guy by day). After looking around, it appears that this is the model you are referring to, is that correct? https://www.digikey.com/product-...
Thanks again to everyone who replied, dealing with us noobs isn't easy.
Yes - although there are various "packages" with more/fewer "accessories" included.
The main point is that it's not just a programmer - it also gives you debugging.
EDIT
I should add that it's also not just for AVR - will also do SAM.
Understood, thank you!
I think that you could get a 40x2 LCD HD44780-based character display and have the program write register and variable values to it, or use the USART to send characters to a PC terminal.  The Arduino Software Serial library works up to 115200 baud.  You can get a whole screenful of debugging information quickly at that speed.  I use a cheap eBay USBasp programmer with AVRdude.exe to do ISP writing to the AVR.
@Simonetta, that sounds great. But I think it's a bit of a stretch for my current skill level. Though I will have to learn how to use the ATATAMEL-ICE, it's likely that it will work out of the box, whereas if I implemented your solution I would never know if it were me that was screwing up! (and we all know it would be me....) But great idea, maybe I can try that once I get a few months under my belt.
@awneil, I bought the ATATAMEL-ICE this evening, a bit pricer than I was looking to spend but thanks for the advice. It's exactly what I was looking for and I'm looking forward to it's arrival.
Having a Debug probe (eg, Atmel ICE) does not preclude also using things like LCD, serial, LEDs, etc to give visibility of what your code is doing.
They are all valuable tools/techniques, and each has its place.
EDIT
See: http://www.avrfreaks.net/comment...
Mister Potato Head! Mister Potato Head! Back doors are not secrets!
"Read a lot.  Write a lot."
!?!  Starting your Super Bowl pre-game festivities a bit early?
Nope.  I'm sure the OP will be along shortly to explain ;-)
Hint:  Look at his avatar.
