Printf doesn't work in Start generated project
7 posts / 0 new
Build the EDBGUART demo for the E70 xpld.
Tried to insert a printf statement. included stdint.h and uinstd.h
Severity    Code    Description    Project    File    Line
Error        ld returned 1 exit status    E70EDBGUART0    collect2.exe    0
Error        undefined reference to `_write'    E70EDBGUART0    C:\Users\J.Stampfl\Documents\Atmel Studio\7.0\E70EDBGUART0\E70EDBGUART0\Debug\writer.c    1
Error        recipe for target 'E70EDBGUART0.elf' failed    E70EDBGUART0    C:\Users\J.Stampfl\Documents\Atmel Studio\7.0\E70EDBGUART0\E70EDBGUART0\Debug\Makefile    343
Error        undefined reference to `_read'    E70EDBGUART0    C:\Users\J.Stampfl\Documents\Atmel Studio\7.0\E70EDBGUART0\E70EDBGUART0\Debug\readr.c    1
The EDBG UART project from START uses the driver's io_read() and io_write() functions only.  To add printf() capability you need to add support for stdio redirect in the project.
Go back into Start via the menus and add the middleware:  Project->Reconfigure Atmel Start Project->Add software component->Middleware->Utility->stdio redirect.  This adds the _read() and _write() functions to [project folder]->stdio_redirect->gcc->read.c and write.c.  These functions eventually call io_read() and io_write() on your behalf.
I already thought of looking for middleware.  Just didn't notice the "utilities" folder.  Now My program compiles. But printf("here\r\n"); doesn't print.
	uint8_t recv_char;
	atmel_start_init();
	usart_async_register_callback(&EDBG_COM, USART_ASYNC_TXC_CB, tx_cb_EDBG_COM);
	usart_async_register_callback(&EDBG_COM, USART_ASYNC_RXC_CB, rx_cb_EDBG_COM);
	usart_async_register_callback(&EDBG_COM, USART_ASYNC_ERROR_CB, err_cb_EDBG_COM);
	usart_async_enable(&EDBG_COM);
	io_write(&EDBG_COM.io, example_hello_world, 15);
	while (1) {
		if (data_arrived == 0) {
			continue;
	printf("here\r\n");
		while (io_read(&EDBG_COM.io, &recv_char, 1) == 1) {
			while (io_write(&EDBG_COM.io, &recv_char, 1) != 1) {
		data_arrived = 0;
Hello jstampfl,
it does work for me, are you using different I/O descriptor for
usart_sync_enable();
and
stdio_io_init ();
in stdio_start.c file
How about showing your code?
Here is my code :
#include <atmel_start.h>
#include "stdio_start.h"
struct io_descriptor *io;
void TARGET_IO_example(void)
usart_sync_get_io_descriptor(&TARGET_IO, &io);
usart_sync_enable(&TARGET_IO);
/* Initializes MCU, drivers and middleware */
atmel_start_init();
TARGET_IO_example();
io_write(io, (uint8_t *)"Hello World!", 12);
printf("\r\nHello ATMEL World!\r\n");
while (1) {
