Input I/O voltage for SPI flash - AT45DB321D?
12 posts / 0 new
I am designing a PCB using the AT45DB321D FLASH. The controller I am using to connect it via SPI runs at 3.3V, so the SPI pins will be driven at 3.3V
Is it fine to use this IC at I/O voltage as 3.3V?
The datasheet says that the supply voltage can be between 2.7 to 3.5 V, but does not mention if the I/O voltage can be the same.
It only mentions that it is a 2.7V flash IC.
Please help in this regard.
Thanks.
EDIT:  Link to Datasheet:  https://media.digikey.com/pdf/Da...
Whatever your Vcc is, that will also be your Vi/o as well.
See my next post.
JIm
AT45 has always been a 3.3V device hasn't it? Surely 2.7 to 3.5 is the guaranteed operational window but optimal withing that is 3.3V
(I imagine most "3.3V" chips specify a similar "acceptable range" too).
As a gross generalisation almost all systems/components are going to be one of 5V or 3.3V. AT45 falls into the latter.
Thanks Jim.
Cliff, from page 2 of teh datasheet:
The Atmel AT45DB321D is a 2.5V or 2.7V, serial interface, sequential access flash memory
But if you look at the electrical characteristics page :
It would appear that its a CMOS level so the datasheet is a little vague on page 2
But the very first bullet point on page 1 says:
● Single 2.5V - 3.6V or 2.7V - 3.6V supply
And, in the 2nd paragraph of p2:
 The device operates from a single power supply, 2.7V to 3.6V, for both the program and read operations.
So it seem pretty clear that they are using "2.7V" as an abbreviation for "2.7V to 3.6V"; and "2.5V" as an abbreviation for "2.5V to 3.6V"
On p29, Table 16-1. DC and AC Operating Range, is pretty clear that they both go up to 3.6V
And Table 16-2. DC Characteristics, clearly shows that the IO voltages are relative to VCC
Andy,
If the operating voltage is between 2.5 and 3.6, then why write:
to begin with?
 Or this too for that matter:
Since the DC characteristics clearly as noted in both yours and my posts that the I/O is relative to Vcc?
JIm
Depends on:
David (aka frog_jr)
#3
No the first was 5V, (like those on the stk500)
jgmdesign wrote:
Andy,
to begin with?
Yes, it does all seem to be rather poorly thought-through and inconsistent.
It looks like there are 2 versions of the chip:
  • The "standard" one does 2.7 - 3.6;
  • The "extended" one goes down to 2.5 (same top limit).
awneil wrote:
It looks like there are 2 versions of the chip: The "standard" one does 2.7 - 3.6; The "extended" one goes down to 2.5 (same top limit).
Yeah, that was pointed out in post #9.  Based on the opening statement on Page 2 of the datasheet it would be a better read if it said there are two varieties blah blah blah as opposed to the current wording.
Oh well,
Agreed.
