worth while IPv6
18 posts / 0 new
Is it worth while writing creating a IPv6 stack for embedded systems?
Most people would tell you it's not worth while writing or creating your own IPv4 stack ...
I'm talking about an IPv6 not IPv4
I think you missed the sarcasm!
How in the hell did I, I'm Irish
Any input would be appreciated guys...
Any relevant input?
I'll attempt wink
IPv6 is already in some frameworks and RTOS.
8b and 16b MCU in deeply embedded systems can implement standard I/O to a 32b MCU or MPU that has IPv6.
Microchip Technology Inc
Microchip
MPLAB Harmony
http://www.microchip.com/mplab/mplab-harmony
TCP/IP Network Stack and WiFi support
The BSD layer compatibility has been greatly improved, new dynamic socket options have been added as well as IPv6 support.
The Contiki OS
Contiki: The Open Source OS for the Internet of Things
http://www.contiki-os.org/
Full IP Networking
The Contiki IPv6 stack, developed by and contributed to Contiki by Cisco, is fully certified under the IPv6 Ready Logo program.
I have friends in the internet business who claim that ipv6 is important and necessary, especially for things like IoT where there are potentially a trillion devices.
Personally, I'm not convinced - the workarounds (NAT, etc) in IPv4 seem to work really well.
well that makes it official then... even Irish have off days
Because of NAT I too doubt the need for IPv6.
Think about all your own uses of IP in your house or office? Are you really messing with anything but four part IPV4 addressing? In fact I'd go as far as to say that almost everything you do/configure is probably somewhere under 192.168.x.x
Sure you may set up some DNS servers (probably 8.8.8.8 and 8.8.4.4 in fact!) with a more global IP range but even then it's still IPv4 not v6.
Maybe the Cisco's of this world and the others that provide the "backbone" of the internet concern themselves with IPv6 - but domestic use? Even more so, "embedded micro" domestic use ? I don't think so.
The premise for this argument is that every single "Thing" in the Internet of "Things" needs to have its own, globally-unique, globally-addressable IP address.
Neither am I.
I think the basic premise is flawed.
I don't see the point in being able to directly address every single lightbulb in my from anywhere in the world.
It seems far more sensible that I address my house, and then the things within it are just "sub addresses" of my house - which is what NAT effectively gives us.
More to the point, I see a need to >>prevent<< direct access to every single light bulb from anywhere in the world.  Do you trust the light bulb manufacturer to get security right?  Or do you do the sensible thing and put it behind a routing/NATting firewall?  Will you have a trillion light bulbs behind that firewall?
"Read a lot.  Write a lot."
... or more than that as an IoT edge device.
embedded.com
IoT security: Putting trust in the edge
October 30, 2017
https://www.embedded.com/electronics-blogs/embedded-view/4459023/IoT-security--Putting-trust-in-the-edge
... ARM has drawn a line in the sand for IoT security – a line that passes straight through the edge that separates IoT terminal nodes from the cloud.
IoT edge devices are emerging as a kind of catch-all device, defined variously as local data aggregators, device controllers, data/state buffers, fog computing appliances, cloud gateways, and more.
Designed to provide developers with a concrete roadmap to IoT security, the ARM PSA [Platform Security Architecture] combines a security use-case analysis with hardware/firmware specifications and an open-source reference implementation ...
FreedomBox combines firewall and some local device access with (planned) mesh networking :
Debian
Debian
FreedomBox
Introduction
https://wiki.debian.org/FreedomBox/Introduction
Advanced usage: Smart Home Router
FreedomBox provides a VPN server ... to securely access various devices at home.
In the future, FreedomBox intends to deliver support for alternative ways of connecting to the Internet such as Mesh networking.
Feck it!  I think I will implement IPv6.  Only problem is finding tools to test and debug development.
Thanks for the input lads.
Wm.
Is it worth while to replace the Internet?
Yes
RT
‘By the people, for the people’: Kim Dotcom to launch alternative internet
Published time: 22 Nov, 2017 10:56 Edited time: 23 Nov, 2017
https://www.rt.com/news/410606-kim-dotcom-meganet-internet/
Megaupload founder Kim Dotcom says he will help facilitate an unobstructed internet, free from prying eyes, through MegaNet, which will operate without IP addresses.
Just wondering:
What is your reason for wanting IPV6 for your project?
Not for domestic use probably (See all above).
Is it for some remote node directly connected to Internet?
If power consumption (battery) is not a too great concern I'd probably use some Linux capable hardware. That stuf starts at USD 5 nowaday's.
Wireshark is great for debugging.
On linux there are also command line ethernet capture tools.
ESP8266 is about the cheapest hardware (USD2)  you can find with TCP/IP (Built in WiFi) and therefore it's popular with hachers / hobbyists.
A quick search showed some availabilty of IPv6 for that hardware.
https://github.com/esp8266/Ardui...
What kind of hardware do you have in mind?
Paul van der Hoeven.
http://www.hoevendesign.com
Zephyr Project
Zephyr Project
What is the Zephyr Project?
https://www.zephyrproject.org/what-is-zephyr/
Connected
Supports standards like 6Lowpan, CoAP, IPv4, IPv6, and NFC
Zephyr's Microchip and related boards are Arduino Due, SAM4S Xplained, and SAM E70 Xplained :
http://docs.zephyrproject.org/boards/boards.html
Mouser Electronics Česká republika - Elektronické soucástky Distributor
Mouser Electronics
Open Source RTOS Comes to IoT
On September 6, 2016 in Dev Tools, IoT by Lynnette Reese
https://www.mouser.com/blog/open-source-rtos-comes-to-iot
Recently, Intel released WindRiver’s “nano-kernel” RTOS, formerly called “Rocket,” to The Linux Foundation (LF) and was renamed “Zephyr.”
Edit: typo
Substratum
Decentralizing the Web
https://substratum.net/
WE ARE THE FOUNDATION OF THE DECENTRALIZED WEB.
Substratum is an open-source network that allows anyone to allocate spare computing resources to make the internet a free and fair place for the entire world.
https://substratum.net/why-substratum/
